My STi vs LS1 WS6 Ram Air - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 48
This is a discussion on My STi vs LS1 WS6 Ram Air within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Had to chime in here. Based soley on my experience, in the quarter, the STi has the advantage. Been beat ...
  1. #31
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Based soley on my experience, in the quarter, the STi has the advantage. Been beat by only 1 LS1 (tubbed) and 1 WS6 (missed my 2nd-3rd shift) out of at least a dozen races.
    One slight correction...race from a roll is a measure of the HP/weight ratio, not just HP. Good case in point is a Lightning...a tub at the top end, but more HP than than an LS1.
    BTW...not a hater, just a realist. My stock Cuda doesn't like playing second fiddle in the quarter to my STi any more than my friends WS6 and 02 Cobra.
    Last comment...although I have ran at the strip with my STi, that is not it's forte. Take it to a road course or rally...then have some fun. It takes at least a Z06 to beat it there...and yes, that is by experience also.
    Anyone going to FATT May 21 at Summit Point Raceway? See you there...just be sure to wave that left arm out when you see me in your rear view mirror
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  3. #32
    Registered User MidnightFLAT4's Avatar
    Sep 2003
    Dayton Ohio, Chicago IL
    Z28 Coupe : 3411lbs MT (3433AT)
    WRX STi: 3263 MT
    Trans Am: 3495
    Z28 hp: appx 300whp 11.3lbs/hp
    Trans Am WS6 : 11.65lbs /hp
    STi hp: 260whp 12.55lbs hp
    You may think the Fbodys they are boats, but nothing compared to the 4679lb lightning.
    Stock for stock, LS1 wins from roll. Modded vs stock LS1, who knows? could be close. Modded LS1, rapes stock STi from roll.
    03 MBP WRX Sedan
    STi RA gearset October 4th,STi Trans Mount
    Cobb AccessECU STG II 16.4psi. Bosal DP, Catless OEM UP, 205/55 ZR16 Futura Ultra Z's.
  4. #33
    Registered User SGOSWRX's Avatar
    Nov 2001
    Florida
    WRX STi: 3263 MT
    Trans Am: 3495
    You fail to realize you are comparing rwd with awd. They use totally different dyno's and produce much different numbers.
    It is a very known fact that awd dyno's read much lower HP/Torque numbers compared to rear wheel drive dynoes.
    Heres a little tid bit about drag racing.
    My little 02 WRX, with only 225 whp (stage 2) beat plenty of 300whp LS1's at the track. All it took was my 13.3 @ 100mph to do it. And yes, I beat plenty of them with only 13.3 in the 1/4 mile.
    From a roll , we all know an LS1 has an advantage over an STi. No one as ever questioned that. Stock vs Stock , and LS1 is definately a faster car from a roll. That has never been disputed, yet to continue to try to prove it. Why?
    The original post was my STi (intake, full catless exhaust) running dead even with a WS6 up to 100-110mph. Which it did. And I will prove it again any day of the week.From this you have been trying to prove that a stock STi is slower than a stock WS6 from a roll?
  6. #34
    Sep 2003
    sweet you finally get it... LS1 has better power to weight, and STi has better traction. from a roll, LS1's are better... From a stop STi's are better.
    If you disagree with my numbers, and want to go with crank hp for comparison, it only gets better for the LS1, as they are over 340hp... the reason that awd dynos read lower, is because of drivetrain loss, not accuracy of the dyno. it takes energy to spin every moving part in the subaru drivetrain. while the LS1 only spins the driveshaft, and two tires thru a limited slip.
    blah blah blah, different dynos they are measuring wheel horsepower, the fact of the matter is, most STi's dyno 260ish and LS1's dyno 300ish... what should we compare numbers by, seat of the pants???
    Now all you have to do is race an auto with a stall, tires, and boltons, versus your modded STi, and youll see what i am talking about. LS1 owners are also frequently bitten by the mod bug.
    Good run against the LS1, but dont expect to win frequently, unless its from a dead stop...
    03 MBP WRX Sedan
  7. #35
    Nov 2001
    Florida
    Please try to understand who you are trying to educate on LS1's
    My former car was an LS1 z28. It was an automatic with 2.73 gears originally. I swapped out the rear end for a 3:42 gear set out of a 6 speed. I also had a Vig 3000 rpm stall.
    I also had an LS6 intake, MTi lid, mass air, stage 2 head/cam setup, full exhaust - headers, y - pipe, wide open Borla. I used Superchips custom programming to make it all work.
    This car was dynoed every inch of the way. I've also personally watched dozens of LS1's dynoed. I used to go to dyno days here locally for just LS1's. I would watch 10-15 LS1 being dynoed in one day. I also used to hang out with other LS1 owners and race almost every weekend.
    Knowing this about me, I hope you don't still think you can educate me on LS1.
  8. #36
    Registered User eightballrj's Avatar
    Oct 2002
    MS
    Ok, this weekend.... My buddy with a STi with a catback ran a '01 WS6 from a dig... The WS6 won by a quarter panel in the 1/4. Both drivers are very good. The kicker is that the WS6 had full catback, lid, predator tune, and I think headers. I argue with guys over at svtperformance all the time about this kind of stuff. A BONE STOCK SS, WS6, 03 Cobra versus a STi is a driver's race. I have heard of "hot" F-bodies going 12.8's stock. But that is CERTAINLY not the norm. As with Cobras seeing as low as 12.7's BONE STOCK. STi's have a HUGE advantage from a dig on the street. Those times posted by the RWD cars were on an obviously well prepared track. STi's can almost cut track 60ft's on the street. STOCK TIRED F-bodies and Cobras cannot claim this. Someone in a bone stock STi claiming 6 stock or slightly modded fbodies is by NO means a long shot. Cant we all just leave this topic alone?? It was dead a LONG time ago from being absolutely PUMMELED to death.
    RJ
    Car for sale for 13,500 with 60k on the car an 18k on the motor/tranny(Silver Sedan with 5spd)
  9. #37
    Registered User Simp's Avatar
    Apr 2003
    Orlando/Atlanta
    I second the AWD dyno thing, its not the dyno itself, guranteed. AWD just has greater drivetrain loss. 260whp is pretty good if you ask me, thats like a chipped S4 stock.
    2000 LS1 Camaro M6
  10. #38
    Sep 2003
    well i figured id educate you on the power to weight ratio.
    And i wanted to help you out with your dyno misconception... im suprised your happy with the STi after coming from a straight line animal.
    Oh well, enjoy the car...
    btw I just learned today that the STi brake pads run 300bucks for the fronts from the dealer!!!! holy crap
    cheers
    03 MBP WRX Sedan
  11. #39
    Registered User Shaitiger's Avatar
    Mar 2002
    Streamwood, IL
    Dude, quit it already .
    Obviously he wanted to go another route. There's nothing wrong with that.
    Team Mullet Racing
    2004 White Evolution VIII - Wingless and Altezzaless
    www.forgivendriven.com
    SOLD - Stage 4 WRX Wagon - 12.7 at 106mph - SOLD
  12. #40
    Nov 2001
    Florida
    You got that right. This topic has been beat to death. What makes this even more rediculous for me is that I raced a guy in my neighborhood with an LS1 Z28 over the weekend. I won't even dare post the results of this race out of fear of having to defend myself for the next 2 weeks. But I am now also running Turboxs's HPBC 16psi boost. The car pulls like a freight train now in 1-3 rd gear.
  13. #41
    Registered User ervv173's Avatar
    May 2003
    FL
    Boy this was one long, pointless thread. I dont see why people are so quick to pull up stats and argue about a real-life occurance they didnt witness. Its especially senseless when the original post wasnt at all cocky, and the poster has been reputable and even previously owned the car he raced against. Oh well,
    Great race, keep em comin.
  14. #42
    Feb 2004
    my first post:
    I think thats a valid race...
    my tt stealth with only filter and mbc could hang with my good friend's auto 2000 ss ls1 w/ no cats no muffler and lid mods. That is up to about 110 mph (even from a roll)
    He ran 13.00 on that setup.
    After 110 that ls1 will come straight back at you and pass your top end power draining awd equiped car. Worse for me cuz my stealth is pretty damn heavy.
    but I have a fix for all that
    thanks to you guys
  15. #43
    Jan 2002
    In the slow lane
    Originally posted by asus
    thanks to you guys
    Ohh.. let me guess.... a couple of TD04-13G turbos???
    02 WRX WRBP sedan..
    Upgrades??? stock...
  16. #44
    Mar 2003
    Hey sgoswx, I'm from FLA too.....You wanna play?????What part of Fl are you from? Ever go to the street races at the Tower shops? or Fudruckers?.... If you wanna play with LS1's .......theres alot of action here!
    2001 Formula
    11.40@119 (N/A)
    $1,700 in mods (head&cam)
    10.90@129 MPH (NOS)
    Stock 12.94@107MPH
  17. #45
    Nov 2001
    Florida
    I live south of Fort Myers. I race at Imokkelee drag strip 1/8 mile. Thats my usual spot on Friday nights.
    I'm also not familar with the Tower shops (Bell Tower?), etc. I don't get involved with organized street racing. I've been there and done that years ago. I used to drive a stage 2 head/cam LS1 with all the goodies.
    I've had way too many tickets and I'm way too paranoid to do orgainized street racing.
    But if I happen to run into someone on the street and the street is clear. I'll go for it. But I have to be very careful.
    Besides, your way out of my league. In your sig you mentioned 1700$ in mods = heads and cam. You only had $1700 in mods running a head/cam setup.
    I had about 8k in mods for my Head/cam setup- thats with all the other goodies. (engine mangament, exhaust, intake, etc, and installation.
    MTi chargers $8500 for their stage 2 head/cam setup.
    I must have been ripped off. I paid 1800$ just for my Stage 2 heads. Then another 350$ for my cam.. I got them from Corvette Connection. They got them from Breathless Performance on the East Coast. Are you familiar with Keith at Corvette Connection in Fort Myers? He's builds some fast LS1's.
    He did all the work on my LS1. Those guys are pretty hard core. I believe they also do some street racing.
