WRX vs. Mach 1 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
This is a discussion on WRX vs. Mach 1 within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Originally posted by MR REX Yep, the 3 horn beep is usually always done from a roll, but since he ...
    Indy
    Yep, the 3 horn beep is usually always done from a roll, but since he didn't mention the speed at which they started at I wasn't sure. And turns out that it was indeed from a stop.
    good kill either way....
    Haha, then it turns out that I have owned myself..doh!
    2005 NBP Accord EX-V6 6MT
    AEM CAI, HFP aerokit, Comptech SS
    17" Enkei RS7s on YokoES100 tires
    Dec 2001
    McLean, VA
    Fast car crappy driver = Owned. The 2004 Model will have 320 HP and 335 tourque. Compared to 305 and 320 tourque. Still a win is a win. I saw the mach1 guy I raced later that evening come from behind and beat a stock STI. STI ran a 13.38 don't remember mph and the Mach 1 ran a 13.29. STI ran a 1.8 60 ft and he ran a 2.0.
    Nov 2003
    no, the mach isnt the same as a 98 cobra...it makes the same peak hp but thats it. it doesnt have a dohc motor or 7k rpm redline like the cobra and it makes more low end torque too. its basically a nice little hopped up gt.
  6. #19
    Apr 2003
    Brownsville, TX
    you are mistaken for sure. the mach is exactly like a cobra, DOHC and even more like a 98 cobra than a newer cobra due to it's Solid Rear End. It has the exact same DOHC engine, it has been rated at 305 HP at the factory vs the 98 cobra's 305 as well. the 99-2001 cobras had 320 HP and IRS
    2003 Platinum Silver WRX
    Stock Gutted Uppipe
  7. #20
    Moderator
    Jul 2003
    Maryland
    It's a rebadged, solid axle, shaker hood COBRA. Spend some more time on stangnet or at corral buddy.
  8. #21
    Jan 2004
    what he said.
    2001 Mustang Cobra
    Vortech @9psi
    13* Timing and 11.5AFR
    Tuned by ME
  9. #22
    Registered User MidnightFLAT4's Avatar
    Sep 2003
    Dayton Ohio, Chicago IL
    The car traps 105 whether its a 96-98 cobra or the new mach1. Obviously traction was bad issue in this case. 12.9 for just sticky tires seems unrealistic because the car isnt making enough rear wheel horse. (its not an LS1), but the 4.6 motor is very strong DOHC and revvs to 8 grand. Its one of the best sounding 8cylinders out there.... I love that motor. grrr your buddy from work has a wonderful car.
    03 MBP WRX Sedan
    STi RA gearset October 4th,STi Trans Mount
    Cobb AccessECU STG II 16.4psi. Bosal DP, Catless OEM UP, 205/55 ZR16 Futura Ultra Z's.
  10. #23
    Jan 2004
    I have timeslips in front of me where i trap 104 but my et was only 13.6. The mach with it's solid rear allows for the use of ET slicks to net around a 1.7- 1.8 60' which gets it the 12.9. The 2001 cobra's IRS has weak halfshafts which wont allow for use of tires stickier than the DR's. The horsepower is there I beleive it gets around 287rwhp for the 01 cobra and the mach was getting 29x rwhp. with some gears alone either car will destroy the LS-1 vette or camaro (stock ones)
    2001 Mustang Cobra
    Vortech @9psi
    Tuned by ME
  11. #24
    Jan 2004
    just for kicks here is the mach1 in my area and his/her time
    Melissa driving BigBadMach (2003 4V 4.6L Mach1)
    12.95 @ 105.08 mph 1.66 60ft. 12/05/03
    this run was with the et slicks in the rear with draglites.
    edit: the more i think about it, she MIGHT have an exhuast. not too sure on that though
    2001 Mustang Cobra
    Vortech @9psi
    Tuned by ME
  12. #25
    Dec 2001
    McLean, VA
    The car is some what diffrent than the pre 03 cobras.
    10.1 compression
    3.55 Gears
    Pre 03
    9.5 compression
    3.27 gears
    The Mach 1 hp is underrated. I have seen 290 rwhp on the dyno. Tha = 330 HP. They underated it do to previous issues and to increase the hp gap between it and the claimed 390 for the SC 03. We all know by now, that the crank hp on the 03 cobra is more like 425.
