First time: 13.961 @101.05 - Page 2
Results 16 to 30 of 32
This is a discussion on First time: 13.961 @101.05 within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I can tell a huge difference in the amount of power I have on tap depending on the temp of ...
    Registered User brembo's Avatar
    Oct 2002
    North Carolina
    I can tell a huge difference in the amount of power I have on tap depending on the temp of the intercooler. I can see how a nice IC sprayer/nitrous sprayer would be a great help at the 1/4 mile.
    I know that the new(2004?) F150 Lightenings are using an a/c based system to cool the IC down, and on that engine its good for a 50 hp boost, "transient" as the ford engineers put it.
    Heat and humidity really do screw with FI engines alot. Tho, I don't quite grasp why humidity would play such a factor. Seems like air with a higher percentage of moisture would HELP remove heat from a IC or radiator ya know? Is the moisture displacing combustible components in the combustion chamber or something?
    2003 WRB Wagon. Vishnu Stage 2(VF30). DBA 5010's/steel lines/Carbotech Bobcat pads, MRT topmount. Tein coilovers, 22/24 mm sways, ALK....I'M DONE!!!!!!
    Registered User drizze99's Avatar
    Apr 2003
    Bear, DE
    Ya know, I'm going to see if I can get an answer to this one!!
    The Evo 8 comes standard with a water sprayer on the IC and I was talking to an Evo owner at the track and he fills it with ice cubes. He also tapped into the stock set-up with nitrous, but his bottle was empty friday night. He was trying so hard to get into the high 12's but could only come up with a 13 flat. And that was with only an intake and a 3" turbo back, no cat. Had a muffler tho.
    2006 Subaru Impreza 2.5i [Bone Stock]
    2003 Dodge SRT-4 [303 hp/323 tq] - SOLD
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Screw the Evo, I'll race him for slips. What a loser. He put his hazards on at the track? That's just terarded. Find out who he is and ask him if he'll race a near stock WRX.
    Anyway, drizze, I told you if you trapped better than me, I'd concede that your car is faster. Too bad...
    You'll do better in the fall when the weather cools down. When you trap over 102, I'll come down to your track and beat you again at the strip for good measure.
    When you're ready for me to make your car faster, call me and schedule an appointment. I'll snag you a lot more ponies for a few hundred bucks. Enough to beat me from a roll atleast.
    What tire pressures did you run F/R, drizze?
    -Jim
  6. #19
    Apr 2003
    Bear, DE
    -Jim
    The reccomended tire pressure for the car is 32psi F/R. Like I said earlier the best I could do was a 2.2 60'. On my last run, a fellow SRT-4 owner told me to drop it to 26psi, and that's when I got the 2.1' 60'.
    I really think a bottle neck I have is with the stock exhaust. There is a 3" turbo back out for it now with race pipe, it puts down an added 17whp and 33wt!!
  7. #20
    Moderator fengshui's Avatar
    New Jersey
    Give a man a VF30 and a MBC and he'll think he is invincible
    BTW, Nice runs drizze.
    Moderator: Retired
    2002 Subaru Impreza WRX Sedan 5MT - Road Rally - Best 1/4mi: 13.954 @ 97.36mph (3448 lbs)
    2001 Mazda Miata 5MT - AutoX #99 (NNJ Region SCCA 2005 CStock Champion)
    1988 BMW 325 (2.7L "i" conversion) Sedan 5MT - Daily Driver (AutoX soon!)
    "If you can't drive this car fast you can't drive fast." --British Magazine, CAR, on the WRX
  8. #21
    Apr 2003
    Bear, DE
    Thanks Chris!
  9. #22
    Registered User Simp's Avatar
    Apr 2003
    Orlando/Atlanta
    Two points for you.
    2000 LS1 Camaro M6
  10. #23
    Apr 2003
    Eastern Sierras
    Damn Drizze, nice runs... I know its got more in it than that though
    STIwish
    03 Subaru WRX Sedan WR Blue -
    RIP
  11. #24
    Apr 2003
    Bear, DE
    Thanks STIwish! Yeah, I need to untap a little more powa!!
    Hey, I just noticed you have a Joe P MBC. Do you know what a Joe P E-MBC is? Is it just a 2 stage boost controller controlled by an electronic switch? One of the guys on the SRT board asked this and I don't think anyone answered him!
  12. #25
    Registered User droogie's Avatar
    Nov 2002
    Rochester, NY
    Wouldn't a rex with the same hp's tend to get a better 1/4 time? Is that basically because of the launch?
    One other thing, I was reading the newest sport compact car mag where they put the evo up against threee euro cars. They recorded s 14 sec 1/4 mile with the evo. They attributed it to the high heat and humidity. The non turbo cars were less effected by the temp.
    So given some better weather, you should gain maybe .3 to .5 secs.
    '04 WRB premium package.
    Gutted Stock up, Godspeed dp, Cobb AccessPort (Stage 2), Omori Turbo Guage, Omori EGT Guage, Falken 512's
  13. #26
    Apr 2003
    Bear, DE
    Droogie, I think so. Even with the crappy stock tires on a WRX, you can still get a 1.8 60' right? My best was a 2.1, so right there is .3 of a sec.
    My first run that night, which was at approx 6:30pm, it was very muggy, humid and hot. I ran a 14.4 @97.2 with a 2.2 60'. My last run, which was about 10:15pm. I ran a 13.9 @101 with a 2.1 60'. The air was a little cooler and a little less humid, but I also had a bag of ice on my intake manifold. Colder temps = more power, easily.
  14. #27
    Jul 2001
    PA
    Higher moisture content in air makes it harder to compress.
    Yeah, Chris, because that's all I have done to my car.
    -Jim
  15. #28
    Aug 2003
    Puyallup, WA
    nice run
    Nice run drizz! I can't believe how much hp you have w/ just a mbc and filter...amazing! Just think if we had lsd on the 03's!
    14.045 @101 stock
    stg. one/Perrin fmic, ed piping/Mopar catback/perrin sri/mopar bov...stg. 2 coming soon
  16. #29
    Registered User ebbtide's Avatar
    Oct 2002
    Detroit
    My best run with stock tires and stage 1 was 13.759 @ 101.68 (milan MI). With same setup and 15" bfg DR's, I ran 13.585 @ 102.88 (norwalk OH, 90+ heat). Your mods should give you a better time in colder weather, or you should stick to mopar parts
    If you plan on dragging the SRT, jump the fan relay to cool your car in the pits. The colder the better, and the fan cools the intake and the IC.
    Nice runs!
    2003 Dodge SRT-4 Black
    221 whp/ 241 wtrq *Stock*
    13.585 @ 102.88 *Stage 1*
    "Nothing gives you such a sense of the infinite as stupidity"
  17. #30
    Apr 2003
    Bear, DE
    Originally posted by ebbtide
    .....or you should stick to mopar parts
    Hey eb, on this 13.9@101 run, I went up against a Stage 1 SRT-4 and beat him!! He ran a 14.0@100 oke: I was actually the fastest privately owned SRT-4 there that night. Psi-Fi Motorsports ran a 12.8 @110 in their SRT-4!!
    How do you trip the fan's?? I can't wait for fall weather!!
