EVO 8 Dynos are in ... OH MY !!!
Results 1 to 4 of 4
This is a discussion on EVO 8 Dynos are in ... OH MY !!! within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; The three US EVO VIIIs we've tested (under nearly identical conditions) put down right around 180 wheel hp. That's only ...
    Mar 2003
    The three US EVO VIIIs we've tested (under nearly identical conditions) put down right around 180 wheel hp. That's only ~20 more wheel hp than a stock WRX. Hence my concern about the 271hp rating. Thes dyno figures would suggest closer to 255hp, IMHO.
    A few interesting findings:
    Peak hp occurs around 5500rpm, not the claimed 6500rpm. Peak torque is right around 4000rpm.
    One of the three cars we tested ran 2psi less boost (17 tapering to 15 vs. 19 tapering to 17) than the others. It had a one month earlier build date (1/03 vs. 2/03), FWIW. It ended up making the same power as the other two higher boosting EVOs but with slightly less torque in the low end and midrange.
    Our EVO VIII, for some reason, only has a 1bar MAP sensor. Strange seeing it in a turbo car that runs 19psi of boost. I would expect nothing less than a 3bar unit for the car. With the 1 bar MAP sensor, it maxs out (reads a full 5v) at 0psi of boost. Bizarre and pretty useless, as far as I can see. While I didn't check the other cars we tested, I suspect they are similarly equipped.
    The car is especially knock prone at certain engine speeds. At least it is on the lovely 91 octane gas we run in CA.
    The car runs a frequency-based MAF sensor. Not the usual 0-5v types seen on most other cars.
    The car is under-advanced above 5500rpm. Adding just 1-2 degrees of timing at high rpm bumped hp by over 10 wheel hp without any detectible knock.
    The EVO VIII's factory ECU is a bit more sophisticated that the older EVOs which had no type of active knock correction or smart ignition learning capabilities. Even the processor on the board is bigger These new ECU smarts will present more complications on the tuning end. But that's what we do so we consider it a challenge.
    The EVO, like the WRX, is suseptible to MAF misreadings through intake modifications. We measured some pretty wild MAF errors when trying out different intake configurations.
    There's a lot more info we've dug up during our tune-a-thon. Some of it we'd like to keep to ourselves for now and some we'll elaborate on on our website (http://www.vishnutuning.com/lancer.htm). There's nothing there right now but a pretty picture. Give us a couple of days and it'll start filling out. It's past midnight and we just came back from our first test drive of our mildly tuned EVO Lots more info to come....
    Cheers,
    Shiv
    SUMMARY:
    Evo 8 makes 180hp to the wheels while WRX makes 160.... hrm really worth 10,000 more???
    Link to the thread: http://forums.evolutionm.net/showthr...threadid=15958
    Registered User Silver00Stang's Avatar
    Nov 2002
    Houston Baby!
    hrm.... interesting...
    2001 White SVT Cobra
    Mods:
    BBK Long Tube Headers
    K&N
    Bad tires
    Registered User kaizenfighter's Avatar
    May 2002
    Pigeon Forge, TN
    that is huge news!
    2005 STI
    Obsidian black with gold wheels
    Moderator of SE forum
    Quote:
    What is the handicapped parking situation at the special olympics?
    Moderating YOU
    before you had your Subaru!
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    See here, guys...
    Vishnu Tuning Dynoed Evos
    Armin - ClubWRX Admin/Moderator since 2002
    Vice President and Editorial Manager, NWMotiv.com
    Photography Portfolios: ArminAusejo.com | ArminWeddings.com
    President, Project One Car Club
    02 WRX "EVA-00" | 15 Audi S3 "Ella" | 2010 A4 (traded in) | 02 M3 "M-Thrizzle" (traded in) | 08 STI "Blaze" (sold)
    djrez4 is a genius | ScoobyDMC #010
