Vishnu Tuning Dynoed Evos - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 61
This is a discussion on Vishnu Tuning Dynoed Evos within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Originally posted by jt2 I'd say that Brett's statement is probably right, that DYNAMICALLY they're in a different league. That ...
    That is to say that the driving experience is likely quite different, given the better suspension, brakes, etc.
    Almost excatly like the difference between the vanilla WRX and the STi is likely to be - which is the proper car to compare the EVO to.
    agreed. it'll be a nice battle which i believe the STI will come out barely on top, on paper that is for now anyways.
    Kory "I love Rexes and STis"
    - 2006 Toyota Rav4 Limited V6
    - 2001 Acura CL Type S
    - 1998 Prelude S
    - 1997 Eclipse GSX
    - 1996 Eclipse GS
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    An ECUtek is $750 just for the service and I am sure the EVO "service" will cost the same. Hardly a free mod for either car.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
    Registered User JRod's Avatar
    Apr 2002
    Harrisonburg, VA
    Originally posted by dukmahsik
    shrug ask them not me, i didnt state it. to them i guess stock is not adding any perf parts and only using what came stock. aren't their "free mods" for wrxes?
    I hear you, sorry I came across so harsh (too much caffeine with lunch I think) There are some free mods for the WRX but nothing yielding 30whp. I was assuming they tweaked some engine managment parameters somehow. If they can get 30whp with free mods then
    2002 WRX Sedan-Silver
    Turbo XS UTEC Stage IV (VF34)+TMIC, STI RA gears, Exedy clutch/flywheel
  6. #19
    no problem man, no harm taken.
    and if anyone doubts it, i like wrxes.
    - 1998 Prelude S
    - 1997 Eclipse GSX
    - 1996 Eclipse GS
  7. #20
    Aug 2002
    Don't you guys think that the EVO 8 is a little diluted compared to the (soon to be) US Spec STI? I almost think that the EVO is more comparable to the regular WRX right down to the Viscous center differential and the open front. The EVO may have better brakes, suspension, and a little more power than a standard WRX, but will be no match for the 2.5T, DCCD STI.
    Just my .02
    2002 WRBP WRX
    Old setup = BPM GT turboback, PDE up-pipe, Unichip w/custom map, cooler plugs (NGK range 7), Walbro 255LPH FP, MBC (15 PSI), and custom built turbo utilizing the 13G housing (Internals: Hitachi compressor wheel, Mitsu 15G turbine lightly clipped).
    1/4, 12.88 105.10 - 1/8, 8.09 85.96
    New set up = Now w/UTEC and STI Injectors
    1/4, ? - 1/8, ?
  8. #21
    Registered User 2003WRX's Avatar
    Aug 2002
    Utah
    Hmm, disappointing... It makes that $50K EVO look even more ridiculous. lol
    2003 WRX Sedan
    2004 Nissan Xterra SE 4x4
  9. #22
    Registered User JimDab's Avatar
    Anaheim, CA
    and you'd think for the extra $27K you'd at least not have to worry about door dings as much as the WRX
    I wonder what type of SUV parked next to the guy in the picture in the first post
    jk
    2003 WRBlue Pearl Subaru Impreza WRX Sedan
    For Go: APEX'i AVC-R, Godspeed Uppipe, Samco IC Hoses
    For Show: JUN Eyelids, Clear Side-Markers, Momo RaceAir Shift Knob
    For Handling: Eibach Pro-Kit Springs, Cusco Rear Sway Bar
  10. #23
    Just my .02
    typical words from a typical wrx owner
    if u think the evo is comparable to the wrx then u need to open ur eyes. besides the sti isn't released yet so why make judgement? we'll see soon enough.
    - 1998 Prelude S
    - 1997 Eclipse GSX
    - 1996 Eclipse GS
  11. #24
    Moderator WilliamG's Avatar
    Nov 2002
    Seattle, WA
    Actually, the WRX IS comparable to the EVO. Think about the difference between the two - pricewise. With a few mods, the WRX is as good as - if not better than - the EVO, without costing as much as an EVO.
    2010 SSM STI
  12. #25
    Apr 2002
    One Square Mile, NJ
    It might be true that for the $5000 price difference you can beef up your brakes and suspension and add a upipe and MBC and have a car that handles better, stops better, and goes quicker than the EVO, but comparisons like this are ridiculous. All comparisons should be made stock vs. stock. In that light, they are not the same car.
    However, I am confident that my car will be as good as or better than a stock EVO for well less than the at least $31K is will take to put one in my driveway, $31K being exactly $5500 more than it took to put my WRX in my driveway.
    -joe
    '02 WRB Sedan
  13. #26
    Anaheim, CA
    but you know an evo will have more potential if it takes a modded wrx to compete with a stock evo. mod the evo and it'll reach a higher point than the wrx could
    (at least with stock turbos i mean )
  14. #27
    Apr 2002
    One Square Mile, NJ
    Of course. Hell, I could buy a $10K Hyundai Accent and put $22K into it and have a car just as good as an EVO. The arguement and possibilities never end. My point was, dollar for dollar, the WRX and the EVO are pretty close cars. The STI has some seriosly expensive stuff on it, so I am not sure if the EVO and the STI are going to be dollar for dollar very similar. DCCD and STI 6 speed gear box are not cheap!
    -joe
    '02 WRB Sedan
  15. #28
    Aug 2002
    Why? As far as straight-line accelleration they've both got 2.0L motors and 4 valves per cyl. One is inline vs the other an H4. The EVO's motor may be a little stronger with a forged internal part or two but there are also WRX's right now putting down 400"W"HP on stock internals.
    Where suspension and brakes are concerned, the EVO does come with a stiffer stock set up than the WRX. However, I've only put on lowering springs - 1.5" (front) 1.3" (rear) and set my camber to -1.75 (front) and -1.00 (rear) with 225 45 17's and my car handles surprisingly well. The stock brakes on the WRX aren't all that bad either if anybody cares to dig up some data.
    Now the let's talk about AWD on the EVO vs WRX. They are set up the same way. Both have an open front/Viscous center/ and LSD rear.
    Is there any thing that I'm missing and the WRX costs less.
    2002 WRBP WRX
    1/4, ? - 1/8, ?
  16. #29
    Anaheim, CA
    just the stock turbo of the wrx can't compare to the evo's. the evo has closer to a vf23-ish turbo.
    and the internals can hold up to more, like you said
    the latest news is that the evo can put down 250hp on a FWD dyno. im too lazy to find the link, it's around here somewhere but the actual post is at evolutionm.net
  17. #30
    Registered User Weapon wrX's Avatar
    Oct 2002
    I am happy with my rex...I like the evo too and ofcourse the STI...STock vs STock tho it is better than wrx...but its going to be fun modding to keep up and smoke em..
