Quote Originally Posted by Slider View Post
I would go stage 2 but im broke.
Hey YBNormal, does the cobb keep the stock turbo heatshield? If not what did you do cut it?
As posted above, you have to get rid of it or cut it. I always cut mine. If you trim in small increments, you can end up with a decent size shield anchored with two screws. I also use heat wrap all the way up the DP.
