Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Me vs. 05wrx4U2nv within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I assume your using the off the shelf map from cobb for the vf-34? How much boost are you seeing. ...
    Registered User enash99's Avatar
    Sep 2004
    Palm Harbor, FL
    I assume your using the off the shelf map from cobb for the vf-34? How much boost are you seeing. Depending on the DP you have the vf-34 can tend to be a creepy turbo if it doesnt have a PnP wastegate. I get a tiny bit of creep with the cooler weather. My tuner also gave me a map that will lower my WG cycles to limit the boost I run above 6k.
    2003 Platinum Silver Metalic Sedan
    VF-34 Powered
    My Mods
    Quote Originally Posted by Yossarian
    Even if your car was stock, your chances of warranty coverage are about as good as a retarded chimp trying to do a calculus problem while high on pcp.
  2. #17
    Registered User TheReaper's Avatar
    Jun 2004
    Vista, CA
    Quote Originally Posted by enash99 View Post
    yeah I was just gonna ask if he was running a wg. I know I need one with my stock sti turbo, I get creep more in cooler weather than warmer weather as well which is odd and I have a utec tuned.
    You might be a king or a little street sweeper but sooner or later you'll dance with the reaper.
  3. #18
    Sep 2004
    Palm Harbor, FL
    This time of year alot of the setups I have seen that were built/tuned in the spring/summer will begin to show some creep in the winter.
    VF-34 Powered
    My Mods
