2002 Cobb Stage I WRX vs 2002 SS Camaro
View Poll Results: Who will win.
Voters
60. You may not vote on this poll
  • 2002 Cobb Stage I 5 speed WRX
    11 18.33%
  • 2002 SLP SS 6 speed Camaro
    49 81.67%
Page 1 of 4 1234 LastLast
Results 1 to 15 of 50
This is a discussion on 2002 Cobb Stage I WRX vs 2002 SS Camaro within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; There is more to a race then just the car. So this sunday my two friends will be racing their ...
    Registered User elohdaeh78's Avatar
    Apr 2002
    Long Valley, NJ
    There is more to a race then just the car. So this sunday my two friends will be racing their cars
    Dave - 2002 Cobb Stage I 5 speed wrx (other mods, short throw shifter, silencer delete)
    Tracy - 2002 Camaro SS SLP 6 speed (other mods...bone stock)
    So here is some backround info. Both of them raced at the same dragstrip in the summer in 80 degree weather. The interiors were left alone and so were the tire pressure, both ran on normal fuel not race gas. The WRX was run 1 day after my friend bought his first awd car so his driving of the car was limited, Tracy has owned the SS for a couple of years now. The SS was driven with the traction control on and the WRX was driven when it was bone stock. There best times are as follows.
    WRX (stock) - 14.7@91.5mph
    SS Camaro (slipping clutch ran with traction control on) - 14.4@101mph
    Now they will be racing again sunday, temps will be in the mid 40s, wrx is now stage I, camaro has a new clutch and will be run without traction control. Tire pressures will be fiddled with, interiors may or may not be taken out. Both cars will most likely run normal gas and not race fuel but that is not confirmed yet.
    Some things to think about
    SS will be driving without traction control on in cold weather, obviously the driver isn't the best and may have traction issues on non slicks. SS now has a new clutch.
    WRX driver now has alot more practice with the car, it is now stage I, cold weather will help being 40 degrees cooler out.
    Now before you go bashing their times and stuff, this is all for fun, sure the SS is alot faster, but it all comes down to the owners, pick who you think will win and I will report back the outcome on sunday. Thanks and have fun.
    2005 WRX (Short throw shifter, lightweight pulley,STI Splitters,Tein H-Tech springs,Up/Down Pipe, ERZ Catback, Cobb Stage 2, ASA JH8 with Yokohama ES 100s) 13.680@100.46mph
    Registered User MJez's Avatar
    Nov 2006
    watervliet, MI
    The SS will own it, I use to have one with a K&N drop in and some BFG drag radials. My best time with it was a 12.97@106mph. I would do a full tune up on the wrx, plugs, COIL's, fuel filter, K&N drop in. I did all that and trapped 95.7mph in a 03 stock wagon in 80* heat. His trap seems really low for a stock wrx.
    If the SS driver cant drive the wrx might come out on top, but the camaro is still about 100hp ahead. They dyno at almost 300whp stock.
    Apr 2002
    Long Valley, NJ
    Quote Originally Posted by MJez View Post
    The SS will own it, I use to have one with a K&N drop in and some BFG drag radials. My best time with it was a 12.97@106mph. I would do a full tune up on the wrx, plugs, wires, fuel filter, K&N drop in. I did all that and trapped 95.7mph in a 03 stock wagon in 80* heat. His trap seems really low for a stock wrx.
    Well i posted their times from before and now they are running again. Two words. Driver Mod.
    Jul 2004
    elk grove ca
    good luck finding wires for wrx's
    14.160@96.011
    90 degree weather
    airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
    Registered User DTR rex's Avatar
    Jun 2003
    Chi-town, IL
    You would have to be retarded to vote for the wrx here.
    Stock SLP SS's have run high 12's completely stock numerous times, and even crappy drivers can get mid 13's with the car. I would hope this guy has learned to drive his car a bit better, and now that his clutch is working properly he should own the hell of this wrx.
    Stage1 wrx is lucky to break into high 13's even with a good driver. SS's are in STi territory.
    Just call me Clark Kent
    Offical Body Guard for the Bugeye Mafia.
    Nov 2006
    watervliet, MI
    Quote Originally Posted by blackrex02 View Post
    Haha yeah, i ment coil packs. Noob mistake
    Registered User cavallino333's Avatar
    Feb 2005
    Campbell CA
    basically to summarize you vs SS = rapage
    FORZA FERRARI
    BLOBEYE SYNDICATE (retired) #13
    Quote Originally Posted by Integra96 View Post
    One day I hope to buy a car that is lubricated exclusively by pure manatee oil.
    Registered User Aerophyre's Avatar
    Jul 2003
    Tempe, AZ
    A wrx challenging an SS Camaro to a drag is like a rabbit racing a shark in the Ocean. Nuff said.
    Administrator
    May 2003
    Quote Originally Posted by Aerophyre View Post
    If the shark can't swim, anything is possible.
    Years back I repeatedly beat my friends 5sp TPI IROC Camaro with my 1.7l 83 Jetta. He couldn't launch for isht, and kept losing traction. I couldn't lose traction if I tried.
    Registered User Sleepwagon1's Avatar
    Jun 2006
    Asheville, North Kakilaki
    Look at what u said though. Cluthc was slipping in the SS. WRX will get pwned...
    Apr 2002
    Long Valley, NJ
    Quote Originally Posted by Trainrex View Post
    Yeah i think the people here are forgetting the biggest thing, and thats the driver, a crappy driver won't run mid 13s, a good driver will run mid 13s, a great driver low 13s and a crappy driver 14s, I have seen plenty of LS1's run 14s and those are the crappy drivers, hell i ran a C5 at the track and he ran a 14.7 thats a crappy driver.
    Registered User John M's Avatar
    Dec 2002
    Milledgeville, GA
    2002's are the strongest year LS1's, usually trapping 2-3 mph more than the previous models. As long as the driver doesn't blow off the tires at the launch, the WRX is toast. The Camaro will walk right on by from second gear onward. It's that much faster than the WRX.
    John M
    2000 Lincoln Continental - slow DD with the DOHC 4.6 and a Superchips tune
    1992 Lexus SC400 - slow resto project
    2005 Legacy GT Limited - SOLD Feb 2011 - Forged internals, FP HTA Green @ 22 psi.
    Jun 2003
    Chi-town, IL
    Quote Originally Posted by elohdaeh78 View Post
    Yeah, but regardless of his driving capabilities, a big reason for that 14.4 he ran was due to a slipping clutch. A slipping clutch can make a big difference, especially in a car like that where you need to watch where you launch and how much you spin.
    I am going to assume that since then he has gotten the clutch fixed and learned how to drive his car at least a "little" better. And that equates to 13sec time slips and regardless of his launch, trap speeds over 105mph.
    WRX = toast.
    Apr 2002
    Long Valley, NJ
    Quote Originally Posted by DTR rex View Post
    WRX = toast.
    Its a "she" I don't think her driving skills are any better since she did have the car for a couple of years already, the clutch may or may not play a big part in this I don't know how badly it was slipping when she ran her car, but she did take it to the track 2 times and her best was a 14.4. She was racing with the TC on which makes the car a good bit slower, but also limits your error during launching. I think the big thing here is that she is now racing in 40 degree weather with the TC off, so not only will she have less traction with the TC off but the cold weather will also hurt her traction. There is no contest here in which car is the faster car, everyone knows the SS is the faster car, but like I said before I ran a C5 two weekends ago and he ran a 14.7, when my brother got his 2002 WRX back in 2001 he ran a C5 that ran a 14.1 consistantly. The same day I ran the C5 a different SS SLP bone stock ran a 13.6 and all his friends including the driver were very impressed/shocked at how good of a time he ran. I know a kid with a bone stock WS6 that can't break into the 14s and he has taken it to the track a good number of times, I also have a friend with a 2002 WS6 that ran a 13.3 bone stock and a 12.9 with headers and exhaust. I guess all we have to do is wait till sunday to see, this is a race about a slower car with a better driver against a faster car with a worse driver, its not a race with equal drivers thats for sure.
    Jun 2003
    Chi-town, IL
    Indeed.
