2015 WRX at the track
Results 1 to 15 of 29
This is a discussion on 2015 WRX at the track within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I bought my 2015 WRX on April 1st and was immediately impressed with its handling. I couldn't believe how aggressive ...
    Registered User 15WRX's Avatar
    Apr 2014
    Long Island
    I bought my 2015 WRX on April 1st and was immediately impressed with its handling. I couldn't believe how aggressive the turn in was and how the awd pulled it through the corners under power.
    In order to get a better sense of how it handled at the limit I decided to take it to Lime Rock to see what the REX was made of.
    For Background:
    I've been tracking BMWs at race tracks around the North East since 1993 (wow has it been over 20 years) when my 1993 E36 BMW 325is had 1,200 miles on it. My favorite tracks (in descending order) are Bridgehampton, Watkins Glen, Summit Point, Lime Rock, Pocono (various configurations). In 2001 I upgraded to a 1998 E36 M3 which has turned into a finely tuned track machine with Ground Control coil overs, camber plates, sway barbarians and some minor engine mods (nothing internal) that would not compromise longevity. On R Compounds this car can keep up with most of the modern high HP cars that other driving instructors bring to the track these days.
    Preparing for the Track:
    It was apparent that the brakes on the WRX would not cut it for track duty. I was initially going to take her to Watkins Glen which is killer on brakes and was apprehensive about pads, fluid and cooling. As it turned out I wasn't able to make the Watkins Glen dates and settled on running the car at Lime Rock for its first track date. Lime Rock is MUCH easier on brakes and there is only one very heavy braking zone going into Big Bend from the main straight. Still - brake upgrades were essential for the track.
    It was very difficult to find any resources on what pad shape the 2015 WRX uses since the car is so new. Enter Justin at JSC Speed. They purchased a 2015 WRX as a development/project car for their business (they maintain the WRX safety cars used at NJ Motorsport Park's Lightning and Thunderbolt race tracks). To figure out what pads were needed, they took apart the brakes on their project car and test fitted a bunch of different shapes. It turns out the 2015 WRX uses D1078 pads up front and D1114 in the rear.
    I upgraded the pads to Hawk HP+ all around. These pads have the most aggressive bite and best heat tolerance of any track/street hybrid pad and have acceptable squeal levels when driven on the street (unlike true race pads). I also upgraded the fluid to DOT4 ATE Super Blue race fluid which has a much higher boiling point than stock DOT3. I also upgraded the brake lines to braided stainless just for the hell of it since everything was apart and I was flushing the system anyway.
    That's pretty much it.
    At the Track:
    Let me preface by stating that I have not driven a bone stock car on a race track in 15 years so I knew going in that a comparison to my M3 would be entirely unfair.
    I pumped up the standard 235/45-17 Dunlop Sport Maxx RT tires to 40 lbs all around and got in line for my first session. I turned off all the traction control nannies by pressing and holding the traction button until both lights lit up on the dash. My car is a CVT (can you believe it) and I set the transmission in S# and put it in manual mode.
    I took it slow, building up speed progressively over the first 4-5 laps. The car felt fantastic on the warmup lap and I pressed it a bit harder on each successive lap.
    Suspension:
    The stock suspension is very nicely sorted and the car does not lean much in the corners - even at the limit. The car and use a lot more camber in the front to get the front end to bite harder under extreme load but otherwise it was very impressive. The car also handled the transition from the left hander into the right hander pretty well and was very responsive to a small mid corner lift to get the front end to tuck in.
    Brakes:
    The upgraded brakes were excellent. The pedal feel was a huge improvement over the sponginess of the stock fluid and pads. There was still about 1/4" of travel but then they had great bite and a solidly firm feel after that. The brakes remained strong and never faded over the course of the day. They also felt balanced and had good modulation. I only got into the ABS twice all day when I really started to push the braking point closer in Big Bend and trail braked it thru the first apex.
    Steering:
    I have to say that I was disappointed with the steering feel. The steering was accurate and responsive to inputs but I got no feedback through the wheel about what was going on at the front tires. My M3 is always talking to me, telling me how much grip is available before the front end starts to slide. The WRX felt more like I was driving a video game - accurate but numb. That was a letdown since I didn't feel that the wheel was numb during hard street driving.
    Tires:
    The 235/45-17 Dunlop Sport Maxx RT stock tires are great - up to a point. I played with the pressure a bit dropping 2 lbs all around after the 1st and 2nd session to try to prevent them from overheating. I tried this because the tires never rolled over on the sidewall and it was very apparent when they got too hot because they would get really greasy. Toward the middle to end of the later sessions I had to continually adjust my turn in to account for the degrading grip and responsiveness of the tire. Still for the speeds that the car was running the tires held up very well. No chunking of the tread blocks or unusual handling characteristics.
    Engine/Transmission:
    The engine was strong initially and did a great job of powering through corners with the awd.
    I believe I ran into some overheating issues on either the engine or transmission oil. I saw 243 to 250 max engine oil temps on the triple gauge readout in each session. I don't know about the transmission temps as there is no gauge for that. Either way the car felt down on power as the day progressed. Ambient temps were high 70s low 80s and partly sunny.
    I think the computer must have been backing down on boost or timing as temperatures rose but this is just anecdotal.
    The CVT transmission did all right for itself. It took me some time to get used to not heel/toeing on downshifts and using the paddles but the 8 speeds were pretty useful keeping the car in the power band (4800 - 5900 mostly). I used mainly 4, 5 and 6.
    Seats:
    They did an excellent job keeping me in place with the stock belts. I used an old trick i learned before I installed a roll bar and harnesses in the M3. I move my seat all the way back. Twisted the belt buckle a full 360 turn. Then clicked in. I then slide my seat up to tighten down the lap belt. The twist holds it from expanding. The shoulder belt tightens at the first hard braking zone and then I was good to go for the duration.
    Data:
    The group I ran with does not allow in car cameras that are not mounted directly to a roll bar (no suction cup mounts) so I couldn't use my GoPro. I did get some decent data from my iphone data aquisition software but I didn't plug into the ODB port to get all the engine data. Lime Rock is 1.53 miles with 7 turns and a lot of elevation changes. A typical 1998 M3 would run in the 1:04s. The WRX ran pretty consistent 1:07s. Not bad at all for a first time out.
    Tom
    2015 WRX
    1998 E36 M3 Track Prepared / Street Legal
    Instructor - BMW CCA
    Apr 2014
    Long Island
    Tom
    2015 WRX
    Jun 2014
    sounds fun.
    i'm disappointed/surprised to hear about the lack of steering feedback.
    however, i'm still excited to receive delivery of mine.
    Aug 2013
    15wrx, thanks for the lengthy and detailed review. It's great to get an experienced track driver's opinion of the car's capabilities and the fact that it was mostly stock makes it even more relevant to those of us considering the purchase. It sounds to me that it's a pretty capable car for the price. I'm pretty tall at 6'4" so although there's excellent headroom I'm not sure a helmet will fit for me, so I'm not sure I will do much track time but it would be nice to have the option and your post gives me confidence that my skill would probably be the limiting factor not the car. The last track I was on was Lime Rock in my brother's 911 back in probably '94. I now live closer to Watkins Glen and might get out there with my on order '15 WRX.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    This is a great review!!! Unfortunately electric steering is the way of the future, and although EPAS is numb compared to hydraulic assist, I felt the WRX had a pretty decent EPAS system. There is only so much that can be done however...
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User Initial D's Avatar
    Apr 2014
    Quote Originally Posted by 15WRX View Post
    Finally your build is up 8D! So you decide to get a CVT huh? Are you going to mod it? Can you even mod a CVT lol? Is there any gas lag when you press the pedal of your car? I bought a new altima last year and CVT to save gas, but WOW that sort 3 second "lag" before my car start moving right was annoying...If I remember in a video, there a sport option? How that go? Also, any problem you have relating to CVT?
    Apr 2014
    Long Island
    Quote Originally Posted by WRXSTIG View Post
    I'm curious how the stock tires hold up to the track? Do they seem to wear pretty quick or will they last through multiple track days plus daily driving.
    Hey - haven't checked back in a while. So to update on a couple of questions:
    The tires held up surprisingly well at the track. No chuncking at all. They did however get pretty greasy feeling when they got hot. That got the car into some controlled drifting but I had to ease back on the base to get the car back on line.
    As for the throttle response on the CVT - the only time I feel a lag is on step off. Maybe a half or quarter second - not bad and that is in I mode. In S# mode I don't feel it.
    On the track there was no lag at all other than if I was off boost after heavy braking into big bend - but I figured that is normal turbo spool up and I am only modulating the throttle in the corner so the turbo is more or less spooled up by the time it is time to punch it at the second apex.
    I did see oil temps going up to nearly 250 and at that point it think the computer started limiting boost to prevent damage. Not limp home but I definitely noticed less punch and the lap times were slower.
    Tom
    2015 WRX
    Registered User anxiouz's Avatar
    Aug 2010
    So Cal
    Very nice read. Thanks for sharing the feedback.
    Steve // 2010 Cadillac CTS-V // 2011 WRX hatchback (SOLD)
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    nice write up!!! did the CVT have a kind of burning rubber band smell after some hot laps at all?
    2013 wrx sedan(saving up for a 2015 STI)
    Previous faist cars: '05 Mustang GT '02 RSX-S, '91 SR20 240sx, '85 300zx turbo
    Apr 2014
    Long Island
    Actually the CVT did pretty well at the track. No smell or warning lights (don't know how hot it actually got).
    Manual mode is very responsive and I found I liked Sport mode better than Sport#. The 8 gears were too confusing to me, I couldn't really tell how many gears to go up or down or which gear I should be in. The 6 speeds of Sport mode mapped better to my memories of driving an E36 M3 at Lime Rock for so many years.
    Speaking of the E36 - the biggest adjustment of driving the CVT at the track (and I would imagine this is the case for any other paddle shifted tranny) is the strange sensation that I had nothing to do with my left foot. I am so used to heel toeing that I got tripped up many times under heavy braking into Big Bend and stabbed for the clutch that didn't exist.
    It seems that to be fast in a non-clutched (auto/DSG) transmission car it makes sense to learn left foot braking. The WRX needs heavy trail braking to rotate the car into corners (same as the M3). If I can learn to left foot braking then it might make sense to start squeezing on the gas towards the end of the braking zone so the turbo is spooled as soon as its time to really add power.
    Any thoughts on that technique?
    Tom
    2015 WRX
    zax
    zax is offline
    Nov 2008
    Preface: I am not a professional driver, nor have I ever participated in a true track day. I have taken HPDC and auto-x'd several times, but mostly I just enjoy practicing race techniques in empty parking lots and back roads
    On my bugeye, I used to practice trail-braking often. Particularly with the WRX (50:50 torque split), the car behaves a bit like a FWD car in the corners with the power going to the front of a front-heavy vehicle. I found that trail braking was particularly effective in preloading that front axle for grip before applying throttle. I seem to recall that ABS was a bit intrusive when applying this technique, so I often pulled the ABS fuse.
    Facebook me here
    Registered User thesolodriver84's Avatar
    Mar 2014
    Fort Belvoir VA
    Just curious when you say acceptable squeal levels. Like will my wife complain that it sounds like nails on a chalk board and kill me if I buy these? Also if I put a baby in the back seat will this bring the little minion into a crying furry?
    Oct 2014
    Miami, FL
    Did any of you guys bleed the clutch when you did the brake fluid? I would think that mixing fluids, whIle not necessarily harmful, would be less than ideal.
    something else forever Germz to Japz's Avatar
    Jul 2014
    Herndon Virginia
    dang nice review and nice times!
    didn't know the CVT could be fun on a track though...
    Apr 2014
    Long Island
    I've taken the WRX to the track a couple more times since my initial review - still bone stock. The CVT definitely is not the ideal choice for track days. It works well and does what you tell it to do (in manual mode) when you tell it to without any delay. However it is less engaging and not as satisfying as nailing a well executed heel toe downshift. But the biggest problem with the 'transmission' is that the car is so quite I have no aural feedback about when I should be shifting. Many times I would feel the car upshift (sometimes in a corner which does not upset the car at all) on its own. I glance at the gauges and realize that the car was redlined and upshifted automatically. Sometimes I didn't even feel the upshift and I would upshift again manually and bog the motor. Part of this was because I was learning a new track (Lightning in NJ) and as I progressively got faster my shift points kept moving backwards. The car really needs an exhaust that can be heard. That will happen this summer with a Cobb Access Port and pro tune.
    That said, the car drives really well, especially in the wet when I was suddenly one of the quickest cars in the instructor group and having a blast drifting out of corners getting used to how hooked up an awd car can be on a wet track!
    I am planning on some suspension and tire upgrades that should help dial out some of the understeer in preparation for this years track days. Next month RCE Yellow springs are going in with offset strut mounts, adjustable front camber bolts and adjustable rear control arms. That should firm up the already taut suspension and get me 2.5 to 3.0 degrees negative front camber and allow me to get rid of the unwanted rear camber from the .8" drop from the springs.
    Mach V Awesome 17" wheels are my first choice for weight savings and brake clearance (they clear STI Brembos (which I understand are a direct bolt on) and even some aftermarket BBKs). Plus there are a lot of Extreme Performance (Tire Rack lingo) 17" tires in 255/40 17 that are cost effective (sub $200) and close to R compounds but still good for 15K+ miles on the street (two summers for me as I put snows on from November to April).
