Results 1 to 15 of 18
This is a discussion on Tune a WRX to meet/exceed STi? within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I should get this out of the way first, I don't own a WRX, but I want one as my ...
    Sep 2012
    I should get this out of the way first, I don't own a WRX, but I want one as my next car. (right now I drive a v6 altima :\ wooooo) I am not made of money, so I had a simple and I am sure noob/overly asked question. The WRX and the STi use the same displacement motor, STi stopped using forged pistons around 05ish? Is the WRX a tune away from STi numbers? Or does the STi have a bigger turbo? Basically if I could save $20K and grab a used WRX then tune it to high heaven would that be an optimal choice to getting an STi and having less to spend on parts? Thanks
    Jul 2010
    Cincinnati
    Power-wise only... The '09+ wrx can be at sti power with a tune. But there are major differences beyond power that make the sti a better car.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Sep 2012
    Quote Originally Posted by jd92677 View Post
    I assume suspension and weight reductions right? Are the gear ratios different?
    Jul 2010
    Cincinnati
    Quote Originally Posted by timma100 View Post
    Being a 6 speed vs. a 5 speed yes the gear ratios are different. Suspension, brakes, and transmission are all much better on the sti. The sti is actually slightly heavier I believe.
    Stink eye mob #727
    Sep 2012
    Oh I didn't know the WRX was a 5 speed, I wonder when 6th is (MPH wise) I know my car is nothing in comparison but for reason 5th gear is at 100mph in a grocery getter.. Do you know why STi stopped using forged pistons? I'll try to find a video but an engine rebuild shop was showing the 20+ STi motors (05 and up) with cracked pistons..
    Hypereteutic pistons were adopted for reduced environmental impact.
    Subaru can make cars that perform like the STi better and cheaper than end users. I'd buy the car I wanted initially rather than spending more time, effort, and money making one after the fact.
    Sep 2012
    That's very true, it makes me sad that the pistons are no longer forged.... But I guess if your tuning enough to break them you should swap anyway.. Do you know what year they changed it? (05 was a guess) Might shoot of a old model and get forged pistons and save money
    http://forums.nasioc.com/forums/showthread.php?t=465249
    Hepereutectic and forged are not mutually exclusive I don't think. In any case none of this is an issue at this point.
    Jan 2012
    Philly Area
    This is an age old, or decade old if you want to be a stickler, debate.
    Bottom line, you can get to STI power relatively easily, but when you consider all the other things that make a STI a STI...you should just buy a STI from the get go. The suspension and transmission are totally different.
    So the question becomes, what is it about the STI that you want?
    - William
    Registered User subaken's Avatar
    Mar 2012
    High Desert, CA
    If I could afford an STI I would of bought one. Don't get me wrong, I love my WRX. I bought the WRX because I couldn't afford an STI brand new. There's pros and cons to both routes. Both are great cars for their respective prices. So either way you'll make a good decision.
    Registered User danyo's Avatar
    Feb 2012
    Las Vegas, NV
    I've had an 04 wrx and an 07 wrx. Both put down more hp than a stock sti. Now I have a bone stock 2011 sti and neither of my wrx's compare to the sti. Everything feels right.
    Jun 2012
    Boca Raton, FL
    It's really hard to add a 6th gear and Brembo's with a tune.
    Sep 2012
    Go here to find the differences between the WRX and the STi according to Subaru:
    Subaru Impreza WRX | Impreza WRX Compare Tool
    Chris
    Registered User XRedJar's Avatar
    Oct 2012
    Laurel, Md
    See, for me the WRX is the perfect fit. Sure an STI puts down more power and gives the driver more control over the AWD system. If you are going to really use it, then thats a plus.
    I traded a lightly modded S2000 for my WRX. I wanted to stay near the same power, but really like the AWD. I'm still breaking it in, but the torque is one of my favorite things about the WRX. Even running it easy, i am very satisfied with it's performance.
    Insurance is also a factor. My insurance went up only $174 a year, the STI would have been 3x that.
    I could have had the STI, but I know that I will never use that much car to it's potential. I did get mine with the short shifter and boost gauge. Two must have options in my opinion.
    Just my random thoughts from a new owner, take care.
    Registered User Eric05mx's Avatar
    Oct 2010
    PA
    Quote Originally Posted by subaken View Post
    I was in the same boat. I probably could have bought a new STi but I wouldn't have been able to buy a single thing for it. The base wrx was cheap enough to allow me buy some parts, tune, window tint, short throw, mud flaps, wheels, etc..
    Yes, I would still like an STi but I do not regret my decision even after driving a stock 2011 STi.
    2012 WRX ice silver metallic
    Protuned by Agile Auto 315whp/342wtq @ 20.5psi
