335i > VF43 WRX
This is a discussion on Thoughts: VF43 wrx vs chipped 335i coupe within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Who would win? I've always wanted to run a stock one. My coworker wants to race me in his chipped ...
My coworker wants to race me in his chipped 335i coupe. Engine's stock except for the piggyback ecu. Has exterior dress-up mods and that's about it. He doesn't know how much power he's making.
As for me, I have a 03 vf43 wrx (complete mods in profile). Don't ask me how much I'm putting to the wheels because I don't know, since I was only road tuned awhile back.
Race will most likely be a roll race (starting in the 50s maybe?) since I don't want to mess up my stock tranny with hard launches.
Well, my previous two cars were brand new BMW 335i's and I had both of them piggyback tuned.
I owned both the PROcede and then the JB3 (which was better and faster).
I know both Shiv at Vishnu and Terry at BMS personally and often dyno tested with them.
A tune only 335i on 91 Octane will put down 340+ rwhp. On 93 and a higher map it will put down 355 rwhp. On 100 Octane and higher map it will put down 365-370 rwhp.
Then you need intake and exhaust to go to any higher maps and take advantage of even more power.
A tune only 335i on street tires will run
12.5-12.7 @ 113+ mph on 91 Octane
12.4-12.6 @ 114+ mph on 93 Octane
12.3+ @ 115-116 mph on 100 Octane
knock off .2 tenths if DR's are used.
I'll put it to you this way too:
A tune only 335i will creep away from a stock e92 M3 6MT. I beat them by 1.5 CL's from 40-120 mph.
It will run very close to even with an e92 M3 with DCT
I ran an e92 M3 6MT that had intake, exhaust, pulley, tune and lowered from 40-125 and from 40-80 we were door to door, then from 80-125 he pulled 1.5 CL's on me. So it took 4 power mods on the M3 to beat my tune only 335i.
Not sure what kind of power you put down in your VF43 WRX, but chances are it's not enough to trap over 113 mph unless you have many other supporting mods. The N54 engine in the 335i/135i is a stout engine and responds to mods with EASE.
I'm sure Driver72 will chime in but the chipped 335i could make at least 350 crank hp (depends on the setting). I don't know much about VF43 but from a roll 335i is very strong with a chip anywhere from 2k+ to 5000rpm. I currently have the JB+ chip and I could tell you it's a totally different beast vs stock 335i.
I've run (before having the JB+ piggyback) an exhausted mod only STi (I can't tell if he has any other mod because the exhaust was so obvious) in my stock 335i on the highway. It wasn't pretty for the STi.
I've seen posts stage 2 STi could easily take the 335i on the highway but then not sure what kind of mod 335i has if any.
No worries. LOL
I got a new 09 WRX
I considered
2010 Audi S4
2009 AMG C63
2010 GT500
But I thought it was time to downgrade for a bit.
The WRX is pretty quick though, but not as fast as my 335i.
I'll be back to a higher powered car in the near future, the WRX is just a toy for a bit.
Sorry to go OT too.
Nobody ever thinks of the Legacy when cross shopping![]()
John M
2000 Lincoln Continental - slow DD with the DOHC 4.6 and a Superchips tune
1992 Lexus SC400 - slow resto project
2005 Legacy GT Limited - SOLD Feb 2011 - Forged internals, FP HTA Green @ 22 psi.
Actually, before I purchased my 08 Impreza WRX I looked @ the Legacy I believe it was the 2.5GT Spec B model - dealer said that was 35k @ the time in Nov 07' then I looked @ the 2.5GT he said that was only 2k less @ 33k which wasn't affordable to me - so I ended up with my Impreza WRX @ 28k out the door. I'm happy with it, I've got no complaints - thank goodness the VF52 is a direct bolt on for me
I guess they can demand markups like that in the northeast. I bought mine (Limited) brand new with 8 miles on the odometer for $28.5k + tax in September 2004. That was just months after the debut of the redesign. Sticker was like 31,900.
I'm up to 18k miles now and it looks like I've probably lost a ring land back when the first turbo blew. Time for a rebuild with all forged goodies -- and all the extra boost that'll go with it. Good thing the Green has some top end headroom left.
John M
thanks for the input guys.
As for the piggyback ecu, don't know what brand, but from what I asked him, it seems like he may be running off a base map. I don't think he's tuned.
Btw this is in CA so it's 91 octane.
there is really no "tuning" with the piggybacks.
The PROcede allows for "user adjustability" which allows you to up the boost a bit based on how much octane and mods you have, and the JB3 just has a dozen maps that allows you to just go to a higher map based on how much octane and mods you have.
If it's in CA and on 91 Octane he's probably running the recommended map which is #5.
But many run Map 6 or 7 (basically the same, map 7 just has faster throttle response for those that like that) even though Map 7 is recommended for 93 Octane. No real issues other than some power being pulled will occur on Map 7 with 91 Octane if it's warm (above 90 degrees out, or you are at elevation above 2000 feet).
But again, Map 5 on 91 Octane all else stock on an auto 335i will yield him trap speeds in the 112 mph range. If he runs Map 7 it would be closer to 113.
If he runs Map 7 with some 100 Octane mixed in to make 93 Octane he'll be closer to 114 mph.
Give it a go, but unless you have tons of top end in your WRX, you'll lose from a roll (and even from a dig you may jump him 1+ CL's but he'll quickly reel you in and pass). I blasted plenty WRX's and STI's with my tune only 335i. They are really strong in the 40-120 mph rolling run range.
I beat a 335xi with a similiar setup (VF43), but the BMW was stock. At least I assumed it was (still had a temp tag on it).
It wasn't to top end either, fwiw. Just from a dig up to 3rd gear and then I stopped when the issue was no longer in doubt.
06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
That wouldn't surprise me considering you have 315 whp and the BMW was stock and probably still had a pretty green engine. But even without a green engine, the stock 335xi will do a 13.3 @ 103+ 1/4 mile.
And without a hard drop clutch launch it would be worse. I'm pretty sure you can beat that with 315 whp when stock the 335xi puts down about 265-270 whp.
i beat a stock 335xi with my stage 2 06 wrx in the 1/4 mile consistently...i consistently hit 13.5's at 100 mph, and yes, the bmw traps around 104 but is running around 13.6-13.7
