dyno chart @ 19psi =)
Results 1 to 15 of 21
This is a discussion on dyno chart @ 19psi =) within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Tuned by Robbie @ Epic Motorsport (epicparts.net) Turned out about where I suspected.. going for 22 lbs of boost when ...
    Registered User wrxloaf08's Avatar
    Oct 2008
    Fayetteville NC
    Turned out about where I suspected.. going for 22 lbs of boost when I get an accessport. To follow drag slips.. lol.
    08 WRX Sedan
    the WRX is back! 340whp 366 tq @22psi
    Registered User jpjester's Avatar
    Apr 2007
    Doylestown PA
    Quote Originally Posted by wrxloaf08 View Post
    What modifications are you running?
    Oct 2008
    Fayetteville NC
    in my profile.. I think i'm set with this for my engine for awhile
    08 WRX Sedan
  5. #4
    327whp with an SZ49? What type of dyno? How maxed are your injectors?
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  6. #5
    Oct 2008
    Fayetteville NC
    I'm guessing they still got room.. I should hit 350-360 21 psi on cobb software. Rob was hesitant to go farther with open source since ecu is kind of unpredictable. Also pushing limits of WRX engine/trans here so I don't want to run it much harder.
    Edit: it was a on a mustang dyno
    08 WRX Sedan
  7. #6
    How is the ECU any less predictable with the open-source reflash rather than Cobb? Sounds to me like he just doesn't know Romraider very well. A reflash is a reflash - there should be no difference in "predictability"
  8. #7
    Oct 2008
    Fayetteville NC
    my understanding of the software was that it didn't do a complete reflash, there was room for it to adapt still. EX: different powerbands on same tuning ?
    08 WRX Sedan
  9. #8
    Registered User Cicatrize's Avatar
    Apr 2009
    Michigan
    HOLY HELL! I was waiting for this, as I really wanted to see your numbers. That is disgustingly awesome, dude. Makes me want to mod the crap out of my 09 now.
    2009 DGM WRX 5-door w/ STI short shifter. Stock...for now.
  10. #9
    Oct 2008
    Fayetteville NC
    Quote Originally Posted by Cicatrize View Post
    Oh yeah, with the ewg it sounds like a total monster when I flat foot. Since your starting with a bigger turbo you may have a less expensive route to some good results.
    08 WRX Sedan
  11. #10
    Apr 2009
    Michigan
    Definitely. My ultimate goal with mine will be stage 2 + fuel pump, injectors, CP forged pistons, and a crap-ton of boost (20+ lbs). Taking the turbo out of the equation definitely helps the wallet.
    The only problem with the VF52 is that it will require a little modification to the wastegate with that kind of power since it's retardified when it's stock.
  12. #11
    Oct 2008
    Fayetteville NC
    put an ewg on it. the GS/Tial kit is only like $600, regardless of hp external is just a better way to go for engine life and for power. Not sure why your going with pistons, also be aware boost does a number on stock parts. I had an issue of the intercooler pipes blowing off the gaskets @ 19.. lol. Had to T bolt clamp them.
    08 WRX Sedan
  13. #12
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    Quote Originally Posted by idipskoalmint View Post
    That's what I'm wondering. I haven't kept up with OSS on 08 or 09's, but this just doesn't sound right.
  14. #13
    Apr 2009
    Michigan
    I'm going to get pistons because the stock pistons on the EJ25 have serious ring land issues, and I'd rather prepare myself for the boost than be sorry down the road and have to replace the block or sleeve it. Man, I didn't even think about the IC pipes...yeah those will probably have to be replaced, and probably the IC too. That is $$$.
  15. #14
    Quote Originally Posted by BrianH
    I believe the only difference is the new tactrix cable needed to do the tuning - I don't think there's an interface difference between GD/GR
    Can you post a datalog?
  16. #15
    Oct 2008
    Fayetteville NC
    Prob not, he tuned it last week. All I have it the graph and numbers.
    08 WRX Sedan
