Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
This is a discussion on Silly goats. within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I'll be running 850s with my Green. Four cylinder engines are harder to fuel when compared to sixes. My Stealth ...
    Registered User John M's Avatar
    Dec 2002
    Milledgeville, GA
    I'll be running 850s with my Green. Four cylinder engines are harder to fuel when compared to sixes. My Stealth had "only" 550s, barely 100cc over stock, yet it was almost as much capacity as four 850s because there were six of 'em.
    John M
    2000 Lincoln Continental - slow DD with the DOHC 4.6 and a Superchips tune
    1992 Lexus SC400 - slow resto project
    2005 Legacy GT Limited - SOLD Feb 2011 - Forged internals, FP HTA Green @ 22 psi.
  2. #17
    Registered User 2004NeonSRT4's Avatar
    Jan 2004
    Oxford,PA
    Quote Originally Posted by BillFromTR View Post
    Deadbolt SZ49. I guess its a 50 trim?
    that late of a spool on a 50trim? what lb per hr wheel? .63 a/r? my t61 in a .63 spools 4k with .1 less liter displacement. (assume in the sig pic is your sti) i have 1000cc's in mine though. whats the static fuel pressure in the sti's?
    RayfieldsWRX - "You like the feel of torque steer? Interesting"
    jd92677 - "I like the idea of mashing the gas and not knowing which way the car will go."
    04 SRT-4 626whp SOLD.
    04 STi 13.3@102 stock. SOLD
    04 SRT4 400whp DD build in progress
  3. #18
    Registered User BillFromTR's Avatar
    Mar 2005
    toms river, NJ
    Quote Originally Posted by MengHang View Post
    How high of injectors are needed to run that baby? 650? 750???
    Im running 740's
    I might as well post up the whole mod list.....
    Exterior
    Seibon carbon fiber hood and wingless trunk
    Tinted windows
    Front badge removed
    De-ambered headlights
    WRX side skirts
    Interior
    Prosport gauges
    Sparco Speed Racing seats
    Suspension
    JDM Pink springs
    Whiteline 24mm front and rear adjustable swaybars
    RCE lowering camber plates
    Engine
    Deadbolt Superzilla 49lb turbocharger
    TurboXS full 3" catless exhaust
    Perrin Big MAF intake
    Gimmick turbo inlet
    SS Autochrome Front mounted intercooler
    Tumbler Generator Valves deleted
    KS Tech phenolic spacers
    Fuel
    Walbro 255 LPH fuel pump
    Deutchwerks 740cc/min injectors
    SMC meth kit with M15 nozzle
    Transmission
    ACT Full face clutch
    ECU
    Cobb AccessPort protuned by Chris at XX tuning
    Waiting to be ordered
    P&L EWG kit
    Gruppe-S unequal length headers
    pump gas 404hp/390tq @ 22psi
    mix of pump and 103 octane 430hp/435tq @24psi
    Quote Originally Posted by 2004NeonSRT4 View Post
    Not sure of the a/r, but its a 49lb/hr.
    ripped from a vendor....
    Deadbolt's SZ49 is a hybrid turbo, using a clipped TD06H turbine wheel mated to a 49lb/hr compressor wheel. Deadbolt's SuperZilla SZ49 includes Deadbolt's Monster Port (TM), Black Xtreme (TM) coating on the turbine housing, and Grey ceramic on the compressor housing. The SZ49 turbo is oil and water cooled and uses normal Subaru position inlets to the coolant supply lines. Deadbolt approximates that with the appropriate modifications and tuning this turbo can sustain 30 Psi and well over 450whp! This turbo has a 2.4" inlet, which will work with a stock-sized inlet hose and is internally wastegated. This turbo qualifies for Deadbolt's Free Rebuilds for Life program
    05 STi for sale, 400hp, 50k miles, only 17k
  4. #19
    Jan 2004
    Oxford,PA
    looks like full spool in the 3500 range which is more common in 50trim(ish) turbo. nice ride.
  5. #20
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    I'm no expert, but I've been told that it's better to run larger inj at less rate, than smaller ones at near max capacity. So 800cfm @ 60% is better than 650cfm @ 95%.
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
  6. #21
    Jan 2004
    Oxford,PA
    Quote Originally Posted by Pavia View Post
    you would be correct. but some piggyback ECU's (the safc) have a hard time pulling more then 10-15% fuel so making your choices wisely here really pays off.
