yes 04/05 came standard with a LSD. holds up very well to anything you can through at it.
This is a discussion on car is finally ready within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; So, I am not familiar with fwd. I would have to assume that you are using some sort of limited ...
So, I am not familiar with fwd. I would have to assume that you are using some sort of limited slip drive train? Forgive my n00bness, the only fwd drive cars I've ever driven were a Geo and a Dynasty...![]()
"Never Launched"![]()
Dougie - Founder, 250,000 mile club
-5,000 posts
RayfieldsWRX - "You like the feel of torque steer? Interesting"
jd92677 - "I like the idea of mashing the gas and not knowing which way the car will go."
04 SRT-4 626whp SOLD.
04 STi 13.3@102 stock. SOLD
04 SRT4 400whp DD build in progress
I don't like this idea. With that power (projected 600whp) and slicks, this is a very bad idea, IMO.. when that axle breaks, what happens? The revs instantly shoot to the limiter, there becomes mad rotational speed in the gearbox as well, and is not a good "safety net", in my opinion.
But im no neon guy, so this may be 'the norm' for the fwd big power streetcars.
I'm not knocking it at all, just don't know the "in-thing" as to what the srt4 guys are doing. Albeit, I'm definitely no stranger to either big power, or drag racing, just I'm used to doing things differently..![]()
Rogan o_0
'01 Dodge 2500 CTD 6-holed hand-shaker - 3850# dual disk
'97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties
if an axle breaks the lsd takes off the power away from it and places it on the other but by then u already know somethings wrongs and your out of it. works very well for a lot of guys. most of the time its never needed as the axles are very strong as well. once you get the suspension dialed in as well as air pressure its very reliable.
Rogan o_0
good lord!!Did you install a parachute while you where at it
2008 Metallic Gray WRX
get some video when you get that thing up and movin![]()
i have video of it moving around but nothing at any speed. no shute needed. it won't be that fast. 9.49s or 150+mph is the cut off and then you need a parachute
The braging right below to you for sure.
I was reading modified mag in issue FEB 08, where a MR2 was making some good number. On his travel, the rear trailing arm broke while he was driving and the car was totalled. I'd hate for something to happen to you, because with that much power....it's pretty scarry. Remember, your car is very small and very light.
Protect yourself...and get that roll cage in ASAP bro.
Peace.![]()
Meng Hang
Ogura Corporation (US Headquarters) Chesterfield Township, MI
Network System Administrator, IT Supervisor
Black WRX 2002, ...with 18G with Stock IC.
Well the graph in the first page is from my car. The race gas numbers are low because I had a crack in the intercooler. Well after I make 3 post I will post some pics and my vid. Or go to youtube and search for srt-4 dyno pumpgas. Ghost3928 is my username on there.
nice of you to find your way over here ghost, hows Hawaii?
/gloat
Rogan o_0
