Page 1 of 4 1234 LastLast
Results 1 to 15 of 55
This is a discussion on WRX awd versus Audi quattro awd within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Compare and contrast the two systems please....
    Nat
    Nat is offline
    Registered User Nat's Avatar
    Jun 2007
    Bend, OR
    Registered User cavallino333's Avatar
    Feb 2005
    Campbell CA
    Ok well one is made by Subaru in Japan the other is made by Audi in Germany.
    FORZA FERRARI
    BLOBEYE SYNDICATE (retired) #13
    Quote Originally Posted by Integra96 View Post
    One day I hope to buy a car that is lubricated exclusively by pure manatee oil.
    Registered User 06PearlWRX's Avatar
    Dec 2006
    SoCal
    Thats what i was thinking. Is there any real difference between real AWD systems? i mean besides the DCCD and any nifty gadgets like that. I guess they could use different front/rear split %'s.
    "90 miles an hour through trees sideways is pretty damn scary" ~Ken Block
    Feb 2005
    Campbell CA
    Quote Originally Posted by 06PearlWRX View Post
    I'm sure theres some major difference I figure I'd just get the ball rolling by starting with the simple differences.
    FORZA FERRARI
    Registered User fasteddie888's Avatar
    Sep 2007
    Buffalo, NY
    I'm wondering if it's like the 4-motion. Also, if anyone would like to chime in, I was thinking it might be a FWD adapted to AWD depending on engine orientation but I don't know.
    Registered User yo vanilla's Avatar
    Nov 2004
    appleton, wi
    audi uses a torsen center differential while subaru uses a viscous type.
    p.s. audi TT uses an electronic haldex awd system, not their own quattro design
    07 WRX TR | 03 mazda6
    man a whole mess of nachos sounds good right now
    ***Hawk-Eye Alliance #95*** Kachow!!
    Registered User farBeyondDriven's Avatar
    Sep 2006
    West Deptford, NJ
    It's really all dependent upon the model...
    Quote Originally Posted by fasteddie888 View Post
    I'm wondering if it's like the 4-motion. Also, if anyone would like to chime in, I was thinking it might be a FWD adapted to AWD but I don't know.
    4Motion and quattro are essentially the same exact system. However, VW's R32, Toureg, Audi's TT and Q7 don't use these.
    Quote Originally Posted by yo vanilla View Post
    I'm not sure if all quattro systems use the Torsen center diff.
    The R32 and TT use the Haldex system, the Toureg and Q7 use a BorgWarner system.
    (IIRC)
    2006 Panty Dropper
    "I want to die peacefully in my sleep, like my grandfather. Not screaming in terror like his passengers."
    Registered User JSarv's Avatar
    May 2007
    Illinois
    Well my Audi 98 A4 Quatro (2.8L) from what I understand uses a torsion front/center/rear differential, it also has permanent stability control thingy (don't know the true name of it) but if you get sideways in the snow or what not, it uses the braking system to brake on certain wheels to straighten the car out, however, if the throttle input increases while sideways this system retreats until throttle input is reduced. This is from experience.
    And it spins all four ALL the time, have yet to do a 1/2/3 wheel peel....
    Bugeye Mafia #157
    18g + 205 + E = 12.07@116
    Registered User GateWRXING's Avatar
    NJ/NY
    Has anyone driven a newer Audi Quattro...and if possible all biases aside...can say which system performs better in the snow....say a 2.0t a4 with snow tires and a WRX with snow tires...I always think my Subie is a beast in the snow but then it sometimes gets fishy around corners....
    gJb Hawk-Eye Alliance #002
    Mets
    Giants
    Rangers
    Nat
    Nat is offline
    Jun 2007
    Bend, OR
    Quote Originally Posted by GateWRXING View Post
    How new is "newer?" I just bought a 2002 A4 and will take delivery today or tomorrow and will find out soon how they compare in situ. The A4 uses 235/40R17 tires v. the 225/40R17 on my Subie though. I would need to buy the same snow tires (Yokohama W.Drive) to make it somewhat consistent I suppose.
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Gonna be a hard comparison as the Audi is also equipped with traction control on its AWD standard (modulates through the brakes to help gain traction when it is overcome on the AWD system) and the WRX was just made available with traction control in 08.
    Worth noting, found this here:
    http://answers.yahoo.com/question/in...AATzhYs&show=7
    Well everyone is close, but no one is right on.
    It is a 50/50 torque split, but using the ESP/ABS 80% of power can be transfered to a single wheel, not axle. Also the torque split only pertains to normal driving conditions. Audi uses a purely mechanical AWD system except for the TT and A3. By using wheel speed sensors the ABS control module automatically reads each individual wheels speed, and then applies the brakes to any wheels traveling faster than another wheel. This effectively changes the power distribution and helps put power to the wheels that are gripping and allows the wheels that are slipping to get traction. Also when cornering the power to each wheel changes because each wheel is traveling on a different arc and therefore at a different speed through the corner. If they didn't change speeds there would be a lot of wheel hop and poor traction.
    The TT and A3 have the Haldex clutch that MAIKOO was referring to. It is electronic and not really a true Quattro system. All of the other Quattro models use what is called a Torsen center differential. (Torsen stands for Torque Sensing). This technology was adopted from AWD racing. It is basically a mechanical planetary gear set that is the link between the front and rear axles. All new Audi models (starting with the new body styles) will be getting the 40/60 (40% front/60% rear) torque split introduced in the RS4. The 50/50 split tends to cause understeer during hard cornering, while the 40/60 encourages oversteer (easier to manage). The only difference is in the gearing of the Torsen differential. You could actually make your car have a 40/60 split by swapping Torsens. There are a couple companies that you can buy them from online, but you have to send them the old one because the rebuild them.
    I hope I cleared things up and didn't cause too much confusion.
    • 3 weeks ago
    Source(s):
    I am an Audi Technician.
    I have been to way too many Audi classes to count.
    edit:
    Your torque split is 50/50. My friend just sold a stage 2 A4 1.8t. Don't bother modding it, you'll unleash the engine compartment gremlins and have perma-CEL's. It is also gonna be an under steering beast because of its Torsen bias even with coilovers and sways. There are a sea of boost tubes/ancillary boost lines on the 1.8t and the IC is way too small from factory.
    Registered User mike05STi's Avatar
    Jan 2006
    Nashville, TN
    Do you mean torsion? Because Torsen is the name of a company who makes differentials.
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    -Albert Einstein
    Some people go through their whole lives wondering if they ever made a difference in the world. Marines don't have that problem.
    -Ronald Reagan
    Jun 2006
    Nor Cal
    Quote Originally Posted by mike05STi View Post
    No he means Torsen.
    NJ/NY
    So in Layman's words....?
    Does anybody else no the feeling that I am describing when you go around a turn in the snow with your subie. The steering gets lose and it seems as if the car is sliding a bit....its an odd feeling, its happened on both of my wrx's with the same snow tires (wintersportm3s)
    that makes me question the awd of the subie sometimes and wonder if this is the way an audi drives in snow....
    Mets
    Giants
    Rangers
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    In Layman's terms, you're going to fast, and you're sliding.
