Page 1 of 3 123 LastLast
Results 1 to 15 of 38
This is a discussion on jetta 1.8t dyno for all those that actually care within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I had my car dynoed this weekend and put down 181.9 fwhp and 234.0 ft/lbs. It was like 90+ degrees ...
    Nov 2003
    WV
    I had my car dynoed this weekend and put down 181.9 fwhp and 234.0 ft/lbs. It was like 90+ degrees out however and with the cooler weather and a few more bolt-ons that I don't already have (3"dp and test pipe(no emissions in wv and don't hate on me for it, if you want to complain about emissions, go to a volcano foums/deisel truck forum/factory forum) and a fmic) I should be pushing about 200+whp and 250+ ft/lbs tq when I go back around January. And I'm going to make sure it's like -30 degrees out next time
    So, now all I have to do is find a stage 2 wrx to run and see what happens
    Registered User hellafastWRX's Avatar
    Sep 2003
    Huntington, Long Island..... NY
    Nice torque #!
    --Chris
    04 WRX wagon - 304whp Mods - SOLD
    2008 DGM Impreza 2.5i sedan - STi Grille, GTspec cf lip, CTspec cf trunk chrome cover, Perrin shorty antennae
    LISC #3
    www.longislandsubaruclub.com
    Buzzz Wannabe's Avatar
    Apr 2003
    Peoria, AZ
    Who's dyno were you on?
    My dyno and almost every one I know of, is set to adjust the numbers to what it would be at sea level. Was not this the case with your dyno pull?
    Registered User AwdTurboWrx's Avatar
    Mar 2004
    Sun Valley,CA
    stage 2 wrx will have about 30more whp, it will have about the same torque and it will have a longer powerband since 1.8t turbos die off quick. You decide what will happen. Btw can you upload the chart?? its just crazy how early 1.8t turbos spools, virtually no lag.
    The Ghosts of Zooph and Sarcasmo Will haunt CLUBWRX forever!!!
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    Quote Originally Posted by Wannabe
    Good question. Also, what was the vapor pressure when you dynoed?
    Jul 2005
    Ya the 1.8T's are very torquey engines, i have a 05 GLI 6spd, and im pretty sure if i had the mods you got, i could take out some WRX's maybe even the stage 2's.
    Mar 2004
    Sun Valley,CA
    i just read his post again and i couldnt help but laugh, nobody is gonna hate you on this site for being catless. This isnt vortex where you arent allowed to mention street racing, or mods that will not pass emissions
    btw no emissions?? thats awesome. i wanna move!
    Registered User bigwrxguy's Avatar
    Jul 2004
    Quote Originally Posted by YZFWV
    I ran one with your mods and pulled 3+ car lengths from a roll. I'm "stage 2"
    Registered User 04wrx4keeps's Avatar
    Apr 2003
    Central NY/ Western PA (for school)
    My friend had a 1.8T with a reflash (advertised as 190-200whp but he never dynoed it) and AEM intake, he was almost dead even with my 04 with just TBE (no EM) from a roll (I would usually inch away from him), from a stop it still wasnt pretty. He wouldnt ever race me once I got the Cobb Stage 2 from a stop or a roll, but you deffinatly need a little more whp to pull one.
    Cobb Stage 2.5 VF-34 + uppipe
    Best ET so far - 13.1@103 with a 1.81 60'
    Nov 2003
    WV
    Quote Originally Posted by bigwrxguy
    see, this is the only thing I can't understand. If I would have done a dyno run at night I would have had much better numbers because I wouldn't have had heat loss. If it would have been done in even 80 degree weather, I would have been able to pull off 190+/- and 245+/-. From what everyone says, stage2 wrx's put down about 220awhp. If the two cars were actually running, there wouldn't be 3+ car lengths. And the heat does make a big difference on the 1.8t's since the intercooler is so small and it was chipped. My second run netted 180.0 / 224.0. That's 10 ft/lbs of tq being lost in the matter of 1-2 minutes.
    I ran a slightly modded srt-4 and lost by 1 car length from 35ish to 100-120. and it had to have been putting down about 240-250fwhp, so unless the dynos you are going to are cheating you by 30 or so awhp , which would actually have to be 60+awhp to put 3+ car lengths on a car with the same power mine was putting down.
    But then again, the chip manufacture DOES matter. Some one was running apr 93 v-tune and put down 185 and 224, my chip is only the 91 octane program and the company puts out a 93 octane program that spikes at 25psi, which would give me 10+ hp to the wheels. There are some chips that only dyno at about 170/200 or so respective hp/tq numbers, so I can see you pulling on one of those, but 3+ car lengths still sounds like a lot.
    Especially when I pulled 1.5 cars on a wrx with -atleast- a catback and the not even needed to be mentioned BOV.
    so maybe he had a different chip and setup than I did. Also I have a 3" catback which "takes" some of the down low power and puts it higher in the rev range.
    Also, I'm sure the wrx is the same way with every company's "stage 2" putting down slightly different numbers than the next.
    As far as the dyno type, I'm not sure, but it had the SAE numbers and AF ratio is all it put out.
    edit: And to back up my questioning of 3+carlengths, there are people running 13's with the stock turbo and trapping over 100mph. What does a stage 2 wrx with a stock turbo run? 13's at 100 or so, and that's with the awd launch. So wouldn't the car trapping higher, and with a worse launch, be the car that pulls from a roll?
    Mar 2004
    Sun Valley,CA
    dude you ran a wrx with just a catback and bov and you pulled and with that much power it sounds like all he had was catback and bov. Catback doesnt get you much power unless you get rid of cats and open up the flow. Most stage 2wrx's are more like 230whp. I've told you before and a million times same thing over and over again. Im trying to get a hold of me racing a gti (which is even lighter than your car) with your mods vs me of a roll with my 03 wrx which at the time just had downpipe and mbc. You'll see the results of actual mods instead of ricers with bov and catback just to make noise without anything else.
    Apr 2004
    Charleston, WV
    I'm a stage 2+ WRX and I live in WV. I'm all for having fun and seeing what cars do what, win or lose. If you are around charleston, did you here about the STi vs SRT-4 group this weekend. It wasn't pretty for the STi (stock) guy, 3 seperate SRT's pulled on him. One I heard had 350+ at the wheels, and one at 404. Not exactly a fair fight, but it motivated Jody, er guy in the STi, to get on line and order some go fast parts. Hit me here and we can meet up this weekend.
    04 PSM WRX Stg 4-16G
    Blobeye Syndicate
    Mar 2004
    Sun Valley,CA
    what type of engine management are you running?
    Nov 2003
    WV
    EIP. They're not as widely used as GIAC, REVO, APR, Upsolute, or some of the larger brands. They only have one shop but it's 1 1/2 hours from my place and they manufacture most of their own stuff in house.
    They're the guys that had the 600+ hp r32.
    Jul 2004
    Most stage 2 put down 220-230whp and about the same in torque. And the heat soak with no heat sheild is very bad.
    But like you said every car is different and you forget the most important part driver skill. We went from a 30mph roll in 2nd to 90mph before I let off. He said he didn't miss any shifts.
    Dyno's don't tell all esspically if you have a turbo like the 1.8t that dies out way before redline.
