I'm a Disgrace! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
This is a discussion on I'm a Disgrace! within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Originally Posted by crazycam31 first gear takes you up to like 35-40 or so... I don't see what the deal ...
    Registered User IHRTWRX's Avatar
    Mar 2005
    NOR CAL
    Quote Originally Posted by crazycam31
    first gear takes you up to like 35-40 or so... I don't see what the deal is here....
    What rpm are you at when you are goin 40? 5k? Higher? Thats not enough room to even bother to risk goin to 1st. Either go to second or start from dig and leave it in 1st till you reach those speeds.
    Registered User crazycam31's Avatar
    Jul 2003
    Colorado
    Well, if I was at exaclty 30 i probably wouldn't downshift, but anything less I would.... in second gear thats just starting to get to the sweet spot and it would take a second or two to hit boost... By that time you'd be just hitting to top of first, putting it into second and be in the "sweet spot."
    Granted, I did mention already that my numbers might be a bit high since I'm not running the stock turbo.... Unlike a stock turbo, i make my peak power at like 6500 rpms... Not 5250 or so... kthanks.
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    exactly what i was sayin....by the time you shift, hit redline in like .000000000000001 seconds, and shift back to second the guy will be so far gone and laughing his ass off.
    not to mention, at that point, i cant see the powerband being worthwhile, unless the powerband on the wrx peaks at redline.
  6. #19
    Jul 2003
    Colorado
    Quote Originally Posted by IHRTWRX
    40 is about redlining. think about it this way. what "puts you in your seat harder", the top or first gear or 3500-4000 in second?
  7. #20
    Jul 2003
    Colorado
    Quote Originally Posted by 05WRX0704
  8. #21
    Mar 2005
    NOR CAL
    Well... neither. About 3.5-4k in 1st. And I dont care if more power comes from the last 500 rpms in 1st, that power is going to be useless due to the fact that you will lose time between the extra shift.
  9. #22
    Registered User WRCfan's Avatar
    May 2005
    Buffalo, NY
    OK, since I'm still learning the quirks of my rex, what would the recommended protocol for this situation? I know I should've used 2nd instead of 3rd, but again, I literally just turned 1000 miles today. So do I put it in 2nd with revs real high going side by side with him then hit it? Or do I depress the clutch with it in 2nd, bring up the revs and then release the clutch when I'm ready to go? I want to have fun with this thing, but I don't want to do any damage. I just feel like I'm walking on eggshells with the tranny on this thing. I'm not used to that. I've mentioned in other threads that I've got 194,000 miles + on the original clutch on my Aspire, and those are hard miles (by necessity really).
  10. #23
    Jul 2003
    Colorado
    No, you would just downshift into the gear, release the clutch and then hit the gas when you want to go.
    As far as downshifting though, you should be familiar with rev-matching to get into the low gears at higher speeds (so you don't wear out your syncros) and you need to double clutch in order to downshift to first.
  11. #24
    May 2005
    Buffalo, NY
    ^ Yeah, that too. I've got the heel toe, double clutch thing, been doing that for a while, but it's tough going from a clutch with 194K on it as opposed to 1K.
