Originally Posted by pingflood
yeah you can, for the most part. A honda cbr 1000rr is putting out more power and about even, maybe a little more, torque than an rc51.
This is a discussion on Me Vs. Suzuki GSXR 600 within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Originally Posted by cnk You're kidding right? If that were the case, then why even bother sticking a V12 in ...
It is somewhat easier to get higher volumetric efficiency from a smaller cylinder and to get it to rev higher, but there is also total weight of the engine and the biggie, the internal friction caused by having more cylinders. The early 500 fours made 36whp, about the same as a decent (and much lighter) 400 single, and you can guess as to which is faster.Originally Posted by cnk
The main contributors to tourque curves are not the number of cylinders a machine has. A single can be quite peaky if the cam timing and lift are tuned for it. A 50hp 500cc single will have a substancially similar powerband to a 50hp 500cc twin provided similar head and cam designs, with the single having an edge in traction because of the widely spaced power pulses. The single will also be lighter, have less gyroscopic resistance to leaning and less wind resistance. The thing is, you can get a 500 twin to make 80hp, while the single will be limited to about 60hp or less. Something to do with more valve area and higher redline.
In cars adding cylinders is done mainly add displacement while keeping combustion chamber size small enough to avoid detonation rather than to increase redline, with the nearly agricultural redlines of auto engines.
The main drawback of the EX500 is its dated head and fuel system design. When it was first put into production in 1986, the overall power to weight ratio of the bike was slightly higher than the 600 fours of the day, with the exception being the 600 Ninja. All these years later it still makes 51 wheel hp while the 600's have gone from 70ish to 100ish and have gotten lighter than the 500 twin. Aprillia has just started producing a modern 450 twin which produced over 80hp in race trim, and will likely lose just a little of that edge for street use; think 70hp.
The EX500 was called a "finger in the light socket sportbike" with "astonishing" power when it was new, but I read a recent article where it was called so boring that no one should even buy it. Imagine when an STI, which has similar 1/4 mile times and similar handling (on pavement) will be called so dull that it wouldn't even merit a test drive, except as a first car for teenagers. This is in effect what has happened to the EX500. A real beginner bike is a light dirtbike that allows you to exceed the limits and still get up and ride. Try that on any streetbike and you will get punted to the moon. That leaves most street riders as a bunch of chicken sh** pussies who disgrace their mounts in front of porky cars. (Like in front of my 2.5 on the twisties)
I have to agree with your first post about speed. Even a 600 traps in the 120's.Originally Posted by RHONE
But the point of my post is where do I find out more about the shifter karts?
same can be said about cars. How many gets getting rwd cars drive them right off the road because they think they're the number one drifter? Take it to the track.
And the street is the perfect place for a bike if you're not going to ride it like an ass. Any bike that gets 50mpg > any car but a deisel or a hybrid gas electric. + it will out perform a lot of cars out there and still get 50mpg.
Plus it's just plain better not being stuck in a cage.
i guess i dont understand how bikes lose to 300whp wrx's even with mods. Couldn't he be in first at 45mph?? i know with my friends r6 he could be, my friends cbr f4i also.
The Ghosts of Zooph and Sarcasmo Will haunt CLUBWRX forever!!!
don't know what year it was. Believe it or not, gsxr's only had 80-90whp at one point...Originally Posted by AwdTurboWrx
but even if they weigh 500 pounds which they are less plus driver so at 700. you divide that by 90 you get 7.7pound per whp while with 300whp wrx with driver lets say 3200/300whp you get 10.6 pound per whp, huge difference. Plus bike has way better gearing. I dont get it...
Something is going on. We need to know the year of the gix. Must have been an older one or something.
Here are two "timeslips" from a WRX and a 600:
The WRX time was pulled from this site, the 600 is an R6 Yamaha which was a little slower than a Gix, ridden by Gadson in CW. I chose them because they had similar 60'foot times.
R6:
60' 1.74 secs
330' 4.62
1/8th: 6.68
1/4: 10.51
trap: 130.74 mph
WRX:
60': 1.76
330': 4.85
1/8th: 7.39
1/4: 11.397
trap: 123.47 mph
Gadson is running about .5 seconds faster than the average mag times. His 60's are better than a normal human's. So I figure most of a bike's time is in the roll from about 45-130 mph. That is the strongest part of a bike's acceleration, not the weakest part: before drag takes over and after the front ends settles down.
Do any of you venture a guess as to this car's hp? (Belongs to Dug-e-Fresh). I think more than 300. Other people who claim 300-330 hp are into the mid to high 12's, not low 11's and definately not into the mid to upper 10's like the R6. The R6 is into the 9's when gearing and chassis are lowered (about $200).
The R6 dynoed at 108 and weighed 397 with an empty tank
original poster said he ended up at his back wheels every time. Depending on the year and weight and hp and condition of the bike, this could be possible. Agreed, however, that if this was a brand new 05 gsxr 600 with 130some crank hp and 110ish whp, there would be no way. But if a new r6 did 10.51 by a REALLY skilled rider (because the mag guys do this ALL the time mind you), maye his friend was on an older bike and not cranking down on it all the way or starting at 8k rpm at 45mph on a bike that doesn't start to really move until 10K or so.
There's a lot of variables here. But, if it's a bike that say, runs 11 flat with an average rider and his friend with a wrx could run and 11.5 or 11.75, what's the length between the two vehiles going over the at 1/2 a second difference and 3/4 of a second?
All I was trying illustrate was that a WRX can come out of the hole as well as a bike, and that a bike doesn't get its good et from the first 60 feet, but from the next 1260. The car whose timeslip I transcribed was a real monster, probably making considerably more than 300 whp. It was not from the thread starter. If it was, I would not debate the results. Any little slip and that car would take a 600 or visa versa.
A 1.74 is a real feat on an R6, even a mag guy usually can't do it, it was done by a professional dragracer hired for the purpose of setting strip times on the 600's. (Rickey Gadson.)
Hrmm I would barely be able to hang with a newer 600 and that is up here at 3500ft. I put out 450whp btw. I tried running with one on pump fuel where I only make a measly 350whp and he beat me by quite a bit. The older 600s would be no problem for me though. Even some of the older 1000 cc bikes I could hang with.
11.1 @ 131
