V7 STi cluster Kp/h to MPH conversion
Results 1 to 12 of 12
This is a discussion on V7 STi cluster Kp/h to MPH conversion within the Cockpit and Cabin forums, part of the Tutorials & DIY category; Been meaning to do this for awhile but was racking up the Kilometers to coinside with the correct mileage on ...
    Registered User Cuda's Avatar
    Jan 2002
    Pekin, Illinois
    Been meaning to do this for awhile but was racking up the Kilometers to coinside with the correct mileage on my car. First you need the Elite International E0021 Converter chip. It has four wires coming from it.
    Red- power source
    Black- ground
    Yellow- signal in
    Grey- signal out
    I decided to solder the power source and ground to the back of the cluster so that I wouldn't have to cut factory wires. All connections are made on connector i10 which is above the speed. It is also the only connector with only a single row of pins. Pin 7 on the connecter is power(red), pin 6 is ground(black).
    02 WRX SRP
    85 Mustang GT Convertable
    Mods: http://www.clubwrx.net/forums/showpost.php?p=1030367&postcount=236
    Jan 2002
    Pekin, Illinois
    Here is a cleaner picture, nevermind the grey and yellow wires.
    02 WRX SRP
    Jan 2002
    Pekin, Illinois
    oops
    02 WRX SRP
    Jan 2002
    Pekin, Illinois
    Pin 2 is the speedo sensor wire (green with yellow stripe). I cut this wire a few inches before the connector. Connect the yellow wire to wire coming in from harness then grey wire going into cluster.
    02 WRX SRP
    Jan 2002
    Pekin, Illinois
    I had a friend, who is a cop, meet me out on a country road and had him clock me. It is right on up to 100 MPH, didn't go any faster than that. Guess there will be no more maxing out the speedo, 180MPH
    02 WRX SRP
    Aug 2002
    Virginia Beach, VA
    wow...that's pretty cool, does your odometer read in miles now too or just your speedo? Also....when are you going to post a tutorial on how to make your car actually go 180mph
    Jan 2002
    Pekin, Illinois
    Yes, the odometer will read in miles also. Hmm, how to actually hit 180MPH, well have to swap out with a V12 and get the correct body kit. In the end it will look like this.
    02 WRX SRP
    Aug 2002
    Virginia Beach, VA
    Wow, is that the new Do-Luck kit?
    Aug 2003
    Montgomery, AL
    what are you a noob or something? Its the new 22B Impreza Coupe! duh! and yes it does come with the 2 turbo boxer-6 motors for both the front and rear wheels!
    Hey, btw, where did you get this chip?
    Better known as Thai Mike...
    Jan 2002
    Pekin, Illinois
    You can get the chip here
    http://www.kilburne.com/2410/frames.php
    02 WRX SRP
    Feb 2016
    I really hate to bump an old thread but I am slightly confused as to which wires the yellow and Gray wires connect to. Do they go to the plug for the cluster? I am about to install mine today and want to install it on the cluster like yours
    Edit I see they go to 2 green wires could you or somebody clarify which ones? I can't really tell from the
    2nd picture.
    Also can I hook up the power and ground to wires as well instead of soldering on the pcb?
    Feb 2016
    Ok after looking at the 2nd pic more I see that it looks like the grey wire goes to the green striped wire on the plug and the yellow wire goes to the same wire clipped just on the non plug end....since its been clipped from the plug
