Are you talking about the wire kit or your car? The wire kit has a +12 and ground. Only two wires. The ground has a ring terminal, the +12 has a press-on type connector.
As far as where to hook it in, there are +12 sources all over. For a ground you can just look for a screw that goes into the metal frame.
LinkBack URL
About LinkBacks
