Originally Posted by
Impreza2.0
I found a slew of threads on this topic, to the point that you could build the whole thing from the ground up with no previous experience. If you wanted to learn how to make tubing, etc...,that much info...
so Google Web Search the following:
'WRX Boost Gauge Install'
and start looking at the pics. Most pics have a pretty deep explanation as to what it is that you are looking at, those that don't seem self explanatory after a bit of exploration.
I found that AutoMeter provides everything needed to make their gauges FUNCTION (and properly, given all conditions are at optimum), however, doing it with style and class, using AN-4 steel braided hose and fittings and so forth, is beneficial in many ways:
Less loss of pressure (more accurate readings due to zero expansion of hose or couplings, and no loss in boost)
Longer lifespan (!)
Tighter fitting (more reliable connection with the option of adjustment of fittings, and no rattle noises from plastic bits)
Serviceability (no replacing the capillary when your BPV or BOV needs work)
Looks (there's no argument that stainless hose looks nicer than cheap white plastic capillary tubing)
Peace of mind (you know those parts are way tougher than they have to be, leaving no chance of ever having to worry about the system)
This doesn't mean buying stainless hose and just clamping it onto the bits involved. It means taking the time to measure optimum length for efficiency vs. durability, then fitting proper threaded ends. This creates a significantly more useful component, as it will last for many years, and remain serviceable during that time. Replacement of single pieces of the system becomes easier, since threading is much cleaner than clamping, and provides less opportunity for anything to fail. Just my honest opinion... but probably a fact.
Edit:
First, thanks to the guys here and at NASIOC for helping me get the right goods for a boost gauge...
So I find that I have a VF34 turbocharger, and the up and downpipes are Titanium... thought I had stainless... oh how I am sufferring...
Basically what this is boiling down to is that the mystery car that I bought has some really amazing tuning done to it, though it is hard to find. It has a Borla Hush stainless exhaust, and it is catless, turbo back, and stainless, but I couldn't tell what mods were done up front, so didn't know what the stuff was. I got under the car, and saw where the stuff has names stamped into it... and the rainbow "discoloration" that occurs in Titanium has occcurred at the lower fittings into the midpipe.
When I went to find the place where the t-fitting we are discussing, it had already been cut...
weird? yeah, but this is weirder. I got the car from some guys who have this little used car lot here in Maine, out in a rural part. They said it had a few upgrades, but I didn't know what they were. I test drove it for 3 hours, and asked how much to leave with it. I got it for 10K. No worries. On the way out of the lot, the CEL comes on... no blinking, just ON... argghhh!
I figure this is simple. It's a bad neg on the batt...?
Nope... me and Subie go to the mechanic that owns the dynomometer. It's an "evap code" according to some ancient code book for all Subaru engines. There's also this weird chatter... OK, so I go to install this boost gauge... the line to the BPV was cut by the previous owner (I see age on the cut ends, and nothing has touched either in years (it's an 02)). More "OK" here, the lines left were adequate for an AutoMeter Boost Gauge T-Fitting (official sounding enough?). I tried that. I had no idea what boost I was getting... It blew the little plastic "T" into schrapnel. So, with a whining BPV line, a flashing CEL (I unpinched the pinched return line from the BPV), I go to Home Depot, follow your (the great "you" made up of all NASIOC and CWRX members) instructions. I get in, fire it up, and 17PSI VAC... steady. I gun it... 24PSI boost.
Well, all I know is that the previous owner had $4K into exhaust components, at least $2K into a bored vf34 on a rotated mount, and the intercooler is somehow alot wider than the other WRX ICs I have looked at. It is powdercoated silver, so if you know what it is, or if it is stock, let me know.
I am about to go take some pics of this stuff... If I am mistaken about what I am seeing, tell me. I am still a newb. All I know is that the mods in this car outcost the sale price of the car itself, and how he got 24PSI boost is not something I want to pay to learn, but as I do, will inform you.
Windy as this post got, it leads me to this... next edit will be a "cut out the fat", and "here's the pics"
as keeping this thread alive serves no more purpose than to explain BPV/gauge installation information, so you will get just that... so copy/paste if you are as nerdy about this stuff as I am...
and: Thank you for helping make it possible.
