Did you check this thread: Speaker install w/directions
That may have the answer you need.
This is a discussion on door panel removal help needed within the Cockpit and Cabin forums, part of the Tutorials & DIY category; OK, I'm trying to remove the door panels on the front to install new speakers in the doors... I think ...
I think I got everything up to the point where I actually snap off the door panel...
How exactly do I pull the panel off? I'm doing the front doors first...I tried pulling on the bottom, but it didn't seem to want to budge. How hard do I have to pull to get the bottom to snap off?
Any help would be greatly appreciated.
Thanks in advance,
Boomboom15
-Jim
'02 Platinum Silver WRX sedan w/roof rack...bone stock.Ok, now that's a lie.
GO HOKIES!!!!!!!!!
Also a 'trim panle removal tool' or a 'trim fork' <--- from Snapon will help removal greatly. You do need to give it a good tung once all screws are taken off, good luck!
'12 WRB Sedan
Door panel removal
Door Panel removal with pictures
Hope this helps you and others.
I bought a 2008 Subaru Impreza and i am wondering is it the same installation process as the older models i know i have the 6 1/2s and the tweeters in the front. The stock speakers suck wow
