Cheap way to hardwire your Escort 8500 X50
Results 1 to 8 of 8
This is a discussion on Cheap way to hardwire your Escort 8500 X50 within the Cockpit and Cabin forums, part of the Tutorials & DIY category; *this is my first write up so please tell me how to improve it Thanks to SVT Amateur for the ...
    Registered User eld4au6's Avatar
    Dec 2005
    Anniston AL
    Smile Cheap way to hardwire your Escort 8500 X50
    Thanks to SVT Amateur for the method
    This mod is virtually free, aside from the phone cord, and the connectors
    Comparison Regular telephone cord: left, smart cord: right
    *Note you will lose the smart cord mute function*
    First get a regular telephone cord
    Then remove the map lights, use a flat head screw driver to get the clear plastic piece on your map-lights, then unscrew the two philips head screws, and un-plug it.
    Cut off one end, and cut some of the insulation off of the cord
    run it through you headliner to the area near the rear-view mirror
    Un-plug the the auto dimming mirror(if equipped) and locate the Yellow and Black wires. Yellow being power, and Black being ground, please note that other years may be different(the actual plug is not pictured) The image is of the plug that goes to the mirror. I used this plug to vampire clip the wires. The power on the phone cord is the RED and the ground is the GREEN. I had a very hard time getting the vampire clip to work on that small of a wire, so I used some other wire and crimped them together then using the larger wire, vampire clipped the power and ground on the harness
    This is after wiring up the phone cord, and pluging the harness back in
    -05 CGM STiBlobeye Syndicate #4
    -97 Acura SLX totaled 231k
    -95 Toyota Land Cruiser
    Dec 2005
    Anniston AL
    This is the finnished product:banana:
    Registered User anthonywrx's Avatar
    Feb 2004
    Elk Grove, IL
    very well done!!
    Quote Originally Posted by psb02wrx
    while you carpe diem, tell her to carpe deez nuts.
    Fun In the Snow
    STi in the making...
    Registered User farBeyondDriven's Avatar
    Sep 2006
    West Deptford, NJ
    how exactly do you vampire clip wires?
    2006 Panty Dropper
    "I want to die peacefully in my sleep, like my grandfather. Not screaming in terror like his passengers."
    Dec 2005
    Anniston AL
    1st get the tap thing(or vampire clip,dunno what its really called)
    2nd put 1 wire into the clip
    3rd put the 2nd wire in the clip
    4th crimp the pin in to the wires(not pictured)
    5th put the retainer clip on.
    Registered User efmd3's Avatar
    Jun 2006
    the ham
    nice write up, i'll go this route when i hardwire mine, methinks...
    Registered User cam.rex.03's Avatar
    May 2008
    Western Washington
    I'm trying to do this, but I don't have the auto dimming mirror what do I do? I've got the plastic off right not and the only wires I see are those going to the dome lights (and I'm assuming the domelights are not switched, and that they only have power when the button is pressed?). Anyone have any suggestions?
    Registered User kalidas's Avatar
    Jan 2009
    Tucson, AZ
    You might actually have the wire up there. In this writeup (granted it's for an 08 STI), he says that it is way up underneath by the visor.
    2008 Subaru WRX STi - V1 Hard Wired Installation
