Dimming Gauges Wireing
Results 1 to 3 of 3
This is a discussion on Dimming Gauges Wireing within the Cockpit and Cabin forums, part of the Tutorials & DIY category; I searched around for info about this and didn't find any definitive answers but i gathered some info and tried ...
    Registered User c00lbeans's Avatar
    May 2005
    Portland, OR
    I searched around for info about this and didn't find any definitive answers but i gathered some info and tried this and it works with mechanical gauges.
    if your putting gauges on the A pillar a good place to power them is the fog light or cruise control switches.
    Both switches have a purple and orange wire, Purple is positive and orange is the ground.
    Apparently there is a current in the orange ground wire that makes the lights dim.
    So crimp the gauges ground wire to the Orange and your gauges will dim with the rest of the console lights.
    Registered User doridorirx7's Avatar
    Sep 2006
    Ontario
    .. as an addendum, if you are running an EL guage, or any guage with a common ground to power and the light, then just use the Purple wire.
    Registered User TheFugitiveMind's Avatar
    Jul 2005
    Ventura County,CA
    to dim my gauges, ive used the stock harness for the OEM boost Gauge, its located in in the harness for the CD player, just use some spade connetors to tap into it
    it seems that subaru uses the negative to dim.
    2006 Aspen White STi
    Stage 2 Open Source Road Tune
    A bunch of bushings from TiC
