How to replace Bluetooth mic in factory location (WRX 08+)
Results 1 to 15 of 15
This is a discussion on How to replace Bluetooth mic in factory location (WRX 08+) within the Cockpit and Cabin forums, part of the Tutorials & DIY category; I know, I know.. I spelled Bluetooth wrong in the title. How to replace Bluetooth mic in factory location (WRX ...
    May 2013
    This is a walkthrough on how to replace the factory Bluetooth with an aftermarket HU's Bluetooth mic.
    The factory Bluetooth is located in the middle of the overhead light cluster.
    The first step is to remove the covers of both lights. This can be done fairly easily with just your fingernail. You can see the 2 little clips holding it in. Just stick your fingernail in there and push forward to release the clips.
    Next remove the 2 screws located here:
    There are 3 clips holding the light cluster in. To remove the light cluster, use your nails and pull towards yourself to give the clips enough clearance to slip out.
    Once out, this is what you should see (may look different depending on options installed). The little black box is the factory Bluetooth mic. Remove the 2 screws holding it in and move it aside.
    Take your new Bluetooth mic and run the end of the cable through the head liner like so: (I used a flat head to guide the cable out)
    Now run your cable along the liner and down to under your steering wheel and connect it to your HU. Use a credit card to guide the cable into the cracks.
    By moving the factory mic over a bit, you can give yourself enough room to squeeze in your new mic. This is where it should sit:
    Using some nice indoor double sided foam, stick a few pieces on your mic and put it in the empty space you created.
    Put everything back together and you are done.
    I did a quick test call and was told it sounds identical to the factory mic ("Like you are on speaker phone.")
    Let me know if you have any questions.
    Nov 2012
    CT
    is there a reason why you just moved the oem mic and not remove it all together?
    May 2013
    Quote Originally Posted by jling0311
    Well mainly because i didn't want to snip any wires. I didn't see any sort of clip or quick release to just pull it out. The other reason was because if for some reason I decided to sell the car I would most likely reinstall the OEM head unit and bluetooth mic and keep my new head unit.
    Jan 2009
    Md
    I think the OEM mic sucks... people can never hear me on it.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    "bluetoot", huh? That's weird, my toots are clear...
    2007 Outback 3.0R wagon
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    I can't stop chuckling at the title... "bluetoot"
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Palmyra, NJ
    The fact that he said Bluetoot numerous times is even funnier
    May 2013
    ... Dammit
    Dec 2013
    Montgomery, Texas, United States
    Unhappy
    Quote Originally Posted by Methodical4u View Post
    I suspect that sucky mic sound has more to do with the loud car with lack of baffling and stiff suspension (vibrating the mic, maybe). The degree to which I must repeat myself or shout with either factory or Pioneer mic is proportionate to my speed.
    Dec 2013
    Oh, and thank you for this guide, TAG. It looks good and I will be relying on it heavily--going through a DIY phase.
    May 2013
    Quote Originally Posted by DaWRXplz View Post
    Good luck, not that you're going to need it! It's a pretty simple job. It's been about 7 months now and I haven't had any problems with it. Like you said though, the only time anyone ever says they are having a hard time hearing me I'm usually on the freeway or have the windows open. Other than that I've been told it just sounds like I'm using speakerphone.
    Registered User bgsubbie's Avatar
    Mar 2014
    Laval, QC
    I just did it now. The mic was installed on the steering wheel column. Now it looks better.
    BTW thanks a ton for this post
    Sep 2014
    I installed the way you have it. Everyone tells me I sound like I'm underwater or they cant hear me at all as if all the windows were open but they aren't when they tell me this. I'm using pioneer mic.
    Mar 2014
    Laval, QC
    I've got the same exact problem with my Pioneer mic as well but I don't use that mic very often. I guess it has something to do with vibrations transmitting from the car to the mic via all the plastics around the mic plus the fact that its so close and not isolated from the bare bone metal roof. im gonna be playing around with it and see what comes of it. May be some sound isolation and some more of the thick double sided tape would help reduce noise and vibrations.
    May 2016
    Great write up..I have a 2016 Forester and wanted to run a new mic from my factory HU to my steering column and d/c the old mic ... I can't find a place on the back of my HU to plug in a new mic ...am I missing something? If no plug, any reason I can't splice into t he factory mic and run a new mic off of the splice (d/c the factory mic)? thanks!
