Results 1 to 7 of 7
This is a discussion on 2012 Center console USB and AUX mod to work with aftermarket HUs within the Cockpit and Cabin forums, part of the Tutorials & DIY category; Hey Im sure this has been done before but I figured I'd post a pic of what I did in ...
    May 2012
    Hey Im sure this has been done before but I figured I'd post a pic of what I did in case anyone is wondering how to keep their stock USB and AUX but be able to use them with an aftermarket HU. All I did was desolder the stock connectors from the circuit board and add a couple male connectors so that they'll plug into the HUs cable. I am using this with a Pioneer AVIC-X940bt and it works great. The best part for me is that if I want to return everything back to stock I can simply solder the stock connectors back in and be good to go. Let me know if you have any questions.
    Jun 2012
    Boca Raton, FL
    cool, I did something similar to my VW R32. It was tougher because the VW had an actual iPod dock to deal with, but yea, carefully solder each wire and it OWM dock in the arm rest worked with the Pioneer AVIC
    May 2012
    Quote Originally Posted by Mf645 View Post
    You must have had the 2008 R32. I didnt have much for luxuries in my 2005 R32
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    When you desolder all you do is heat up the solder points with the soldering iron right?
    How are you liking the 940BT?
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    Registered User squiRe2001's Avatar
    Jun 2012
    Northeast, PA
    Quote Originally Posted by maus View Post
    Im looking into the 940 BT too. Let us know how you like it.
    May 2012
    To desolder a single joint you would do like you said but the problem when delodering something like this is that there are too many connections that are holding the the thing to the board and you cant get them all hot at the same time. The way around this is to physically remove all the solder from the joint, so that way there is nothing left to hold it to the board and you can just pull it off. I use this: RadioShack® 45-Watt Desoldering Iron - RadioShack.com. It works really well and it is well worth the $12. Ive used it on all types of things. If you cant tell from the pic, all you do is suck away the solder once you heat it up. easy peasy
    As for the X940BT Ive only had it in the car for 3 days now so I cant give you a full report but I can tell you that I love it right now. This is my first double din touch screen unit so take that into account too. I love being able to choose from so many different inputs; XM, FM, AM, IPod, SD, USB, AUX, DVD, Pandora, Aha, and have built in Nav on top of all that... couldnt ask for more. Im using it with an Android phone so I dont have access to advanced app mode but that doesnt really matter to me at the moment. It reacts well to all touch inputs as far as speed and only a light touch is needed. The nav works great and looks cool in the process.
    Registered User bratte88's Avatar
    Apr 2012
    Requesting a detailed step by step if possible with links for products used
    -Brian
    2012 SWP WRX hatch
    PERRIN TMIC (black) / PERRIN CAI (red) / PERRIN Radiator Shroud (red)
    Cobb Accessport / Invidia Q300 Catback / Invidia DP / SPT Boost Gauge
    Pioneer 7" Nav w/ backup camera / SPT STS / Red Hella's / Kartboy Bushing
    6K lowbeams 6K fogs 6k DRL / Grimmspeed Plate Relocation / Cobb Heat Shield
    Cobb Red Shift Knob / Rally Armor Mud Flaps / 08 STi center console swap
