Scroth Rallye3 harness install for 08/09 Impreza
Results 1 to 15 of 15
This is a discussion on Scroth Rallye3 harness install for 08/09 Impreza within the Cockpit and Cabin forums, part of the Tutorials & DIY category; Be sure to follow all of Schroth's instructions/warnings. The Rallye3 comes in two pieces- a rear "tail" and the front ...
    Jul 2001
    Plains of Eastern Montana
    The Rallye3 comes in two pieces- a rear "tail" and the front harness portion
    we'll start w/ the tail piece first
    the trim piece that surrounds the rear pillar where the upper seat belt receptacle needs to be removed
    first remove the two phillip's screws that are visible
    there is one remaining phillips screw it resides under a little tab in the front of the trim piece- this tab is in there tight- use a very fine tipped screw driver to pop it out- be careful as it would be easy to scratch the trim piece if not careful
    the last screw revealed
    there are two plastic fasteners at the top of the window- remove these (that fine head screw driver might come in handy again)
    then carefully pop of the trim piece there are a few plastic pop fasteners holding it on
    here is where the "tail" piece gets mounted- you can't get a socket on it (at least I couldn't)- it's 16mm- underneath a bolt head needs to be held (it's 14mm)- quarters are a little tight, but w/ a little work the nut/lock washer will come off.
    there is a little trim piece surrounding the seat belt- it pops off easily to make room for the tail piece- mount the tail piece on top and snug the nut firmly
    make sure the tail piece is orientated correctly (right side up) before bolting it up and putting the trim piece back on
    insure the oe belt pulls out and retracts smoothly
    for the front piece we'll be working at the rear of the seat, go ahead and push the seat forward
    here's where we mount the right hand portion of the harness (the plastic cover snaps right off)- the bolt is 14mm- remove it
    install the mount (again be sure the harness is orientated correctly and not twisted)
    now to the left side- here's where we going w/ it
    it's also 14mm- remove that bolt
    this bolt has two spacer w/ a captive washer, it might not be necessary but I removed the washer and trimmed one of the spacers by 2mm (the width of the Schroth mount)- this was kind of a pita and may not be necessary but I wanted to insure there was enough thread engagement
    all buttoned up- again insure everything is orientated correctly first- I had the oe belt twisted the first time, then discovered (after re-installing of course) that the left side harness was twisted as well!!!
    congratulations it's not mounted you'll need to adjust the tail piece to your liking
    front shot
    the harness can be easily slid over the top of the seat and stored underneath the seat out of the way- not as handy as their Quick Fit- but they don't make a Quick Fit for 06+ Imprezas and have no plans to
    Registered User kalidas's Avatar
    Jan 2009
    Tucson, AZ
    Could you post a pic of the completed attachment in the rear. Like in the first pic but a little wider view, maybe including the back of the front seat?
    Jul 2001
    I'll try and snap a pic soon
    Jul 2001
    is this what you had in mind?
    Jan 2009
    Tucson, AZ
    Perfect, that's what I was looking for. Thanks
    Registered User falkonsti's Avatar
    Jul 2007
    great step by step +1
    2007 WRB WRX Limited SOLD
    2008 QSM Legacy Spec.B
    Nov 2008
    Vincennes, Indiana
    Hey Big Sky. What's your opinion on the Rallye4's? Would they be as easy as an install for my 08 like your Rallye3's? Other than the other mounting point of course. Would these be a direct bolt on? Or would I have to buy extra parts? Thanks in advance for your input! :-)
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    er...so the "tail" part is always suspended in the air through the back seat area like that? Can't be too nice for someone who has to sit back there?
    Jul 2001
    the rallye3 is the only approved harness for the 08/09 from Schroth- the extra mounting point in the rear really nets nothing and would make that portion of the belt harder to get out of the way when not in use
    the tail flops over the rear of the rear seat ( I even have a little velcro holder for it ) not in the way at all- just got back from a 2000 mile trip w/ four adults- the Schroth belt(s) weren't even noticed
    DUB
    DUB is offline
    Jul 2007
    SLT, CA
    Oh, I see. It disconnects from the "Y" section (second to last picture) and stores out of the way behind the rear seat. Cool.
    Jul 2001
    exactly- the front portion goes over the top of the seat and stores under the rear of the driver's seat, the "tail" flips over the back of the rear seat
    Nov 2008
    Vincennes, Indiana
    Hey Big Sky. How would the Rallye 4's even mount in an 08? I know the lap belt portion would be the same as the Rallye 3's. But would the rear section just extend to the back seat and one side of the harness tail attach to the lower mounting point for the rear passenger shoulder belt near the seat cushion and the other side to the mounting point of the matching rear shoulder belt receptical in the rear seat? Just curious cause I want blue and Rallye 3's only come in black. Which just WON'T do! Haha.
    Jul 2001
    not exactly how they would do it- they don't recommend the rallye4 for the new WRX for some reason
    it seems to me someone on iwsti may have put in a rallye 4, might want to do a little searching over there
    they do have some generic instructions on line for both the 3 and 4 which might shed some light???
    Nov 2008
    Vincennes, Indiana
    If I bought a harness bar would the rallye 4's be ok? Cause that's what I'm planning.
    Jul 2001
    with a harness bar you should be golden- make sure you have the correct hardware for attaching it to the harness bar- also make sure you attach as they state (there is a very important protocol to follow on the weaving of the harness)
    send them an email just to be sure- I've found them very responsive
