Goo Gone will probably work just fine. Only use as little at a time.
This is a discussion on Need help cleaning STI seats - Removing Duct tape Glue within the Cockpit and Cabin forums, part of the Tutorials & DIY category; I accidentally put something on my seats on my 06 STI (blue Alacantara) that had some sticky stuff on it ...
I accidentally put something on my seats on my 06 STI (blue Alacantara) that had some sticky stuff on it from gray duct tape. The sticky gray material from the duct tape is now stuck on the blue part of my seats!I tried using a little rubbing alcohol with no luck. I need something like "Goo Gone" that won't hurt my seats. A friend of mine said sesame oil might help break down the glue, but I'm afraid of trying it. Any help is greatly appreciated.
Jamie
2009 WRX Prem Hatch:
Cobb stage II, Kartboy SS, SPT Catback, Cobb DP, WL Sways, Perrin/AVO Endlinks, Conti DWS
Previous rides:
99 Civic Si (RIP), 2004 WRX, 2006 STI
Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
New Member Hangout / Off Topic / Tri-State
Mods & Pics
Jamie
Previous rides:
I would test Goo Gone on an inconspicuous area of the seat fabric myself.
WD40 can loosen adhesive. Test it on duct tape adhesive first.
Mods & Pics
don't use goo gone, or wd40 or any of that ****.. when off from school i work for my dad's carpet cleaning/upholstery business.. get a rag and use soapy water.. if that doesn't work i can send you a little bit of the cleaning solution
