How to take radio out!!!!
Results 1 to 11 of 11
This is a discussion on How to take radio out!!!! within the Cockpit and Cabin forums, part of the Tutorials & DIY category; I am trying to take the radio out and put in my XM radio. How do I do that? I ...
    Registered User Scout01's Avatar
    Jul 2008
    A, A
    I am trying to take the radio out and put in my XM radio. How do I do that? I do not want to break the trim.
    Registered User 06PearlWRX's Avatar
    Dec 2006
    SoCal
    this is for an 06/07 non TR. not sure about other years
    1. pull up at the back of the trim around the shifter. the whole piece pops up then pull towards the back of the car and leave it around the shifter and wires connected.
    2. the main piece around the AC and radio has two screws at the bottom on the sides now visible. undo those, then you can pop the trim out by working your way up from the bottom with your fingers simply pulling out. you will have to undo he two harnesses and air sensor tube from the AC to get it to completely remove.
    3. you'll have 6 screws holding on the radio bracket and then just have to undo the wiring harnesses, antenna jack, and ground in the back of the radio. its held to the mounting bracket by four screws on each side.
    side note: that plastic interior trim scratches incredibly easy. be very careful where you place them and that your not letting those two trim pieces scratch eachother while movin stuff.
    "90 miles an hour through trees sideways is pretty damn scary" ~Ken Block
    May 2007
    behind the wheel
    the 02/03 is much easier...
    pop the radio/ac surround trim out (4 or 6 clips around the perimeter).
    pop the top cupholder out; there are two phillips screws hiding behind it (dont remember if this is actually needed to do or not.. now i think about it, I don't believe it is.)
    Once the big trim piece is off, there are 6 phillips screw (3 on left, 3 on right) that hold the radio in. Remove those, slide the radio out. Ta-Da!
    Rogan o_0
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties - 750 lb/ft
    Registered User p0rnstar19's Avatar
    Gaithersburg, MD
    correct! you don't really need to take out the cup holder...
    make sure you have a long magnetized screw driver for the bottom 2 screws on the tape deck though. lost one putting in the sound system.
    Quote Originally Posted by LPPTundWRX View Post
    ^^^Your sig is bull****....
    Quote Originally Posted by Integra96 View Post
    Is that a euphemism for a meat helmet?
    Registered User 4cyturbowrx's Avatar
    Nov 2003
    philly
    Question is there plugs in the back of the head unit for an ipod. Since i dont have aux jack. on the front. its an 03 wrx
    Jul 2008
    A, A
    Quote Originally Posted by 06PearlWRX View Post
    Thanks
    Jul 2008
    A, A
    Quote Originally Posted by 4cyturbowrx View Post
    It is a 2002 and i am unsure.
    Registered User 02_Rex's Avatar
    Feb 2007
    I dont think the AUX option was there until 06'
    Huh... Didn't know you couldn't do that...
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    Jazzy Engineering has the solution, if you have the 6cd changer!
    Nasioc members have used it and it works, i expect mine to arrive today.
    2005 WRB WRX "was" STAGE 2
    Jul 2008
    A, A
    It is done...Thank you
    I put the Xm in last night and it took 35 minutes. Thanks to all that helped.
    Dec 2006
    SoCal
    07 was the first year with a stock aux input by the cig. lighter, really one of the only visible changes from 06 to 07.
