Results 1 to 5 of 5
This is a discussion on Need HELP for AMP Installation within the Cockpit and Cabin forums, part of the Tutorials & DIY category; Hi, Hoping someone can help me out in installing my pioneer amp. All I need to know is how to ...
    Mar 2006
    Hi,
    All I need to know is how to feed the power cable from the battery to the inside of the car.
    My ride is a MY05 Impreza WRX (Aus).
    I've search for a hole to feed it through without any luck!
    Need help urgently, my amp and sub are waiting to be pumped hard!
    Any diagrams or video's would be greatly appreciated!
    Cheers,
    Giovanni
    Registered User JOHN91709's Avatar
    Jun 2005
    So-Cal
    you just connect the power cable from the positive terminal w/ a fuse to the amp through the firewall and run a ground from your amp.
    t3h Z w00t!!!
    Blobeye Syndicate #12
    ooo you touched my tra la la
    Quote Originally Posted by ShardAerithes
    My buddy has an SRT-4, I watched him beat an F-16 from a roll.
    Mar 2006
    re:
    Thanks John,
    Could you explain the firewall part, or describe to me what i am suppose to be looking for? Is there a hole in the engine bay where I feed the power cable in?
    Cheers,
    Giovanni
    Jun 2005
    So-Cal
    you run the power cable through the grommet in the firewall on the drivers side, underneath the dash and depending where you want to mount your amp assuming you want it in the trunk just run it down the sides and throught to the trunk
    t3h Z w00t!!!
    Registered User ezzzey's Avatar
    Apr 2006
    Quote Originally Posted by souljah_sectn8 View Post
    Hi,
    Cheers,
    Giovanni
    I wish i took pictures, i did mine last night. But ill try and explain. First what i did was uncrew the glove compartment (about x8 screws) very easy.
    Then if you go ahead and open your hood, and the plastic cover that is underneath your wipers, i just went and poped the pins on that. Then lift the plastic piece up on the passenger side, and you'll see about 3-4 holes, they go directly twoards your interior. You'll see a White plastic, i just drilled a hole as big as the power wire, and fed it thru, then ran the rest of the wire down the side underneath the door kick panels. Whole process took me about 10-15mins.
    Ill try and post pic
