Results 1 to 4 of 4
This is a discussion on Ammeter Install Tutorial & Info within the Cockpit and Cabin forums, part of the Tutorials & DIY category; Here's a tutorial I wrote up about ammeters. Hope it helps: http://www-ec.njit.edu/~trb2/WRX/AmmeterTutorial.php...
    Dec 2005
    NJ
    - Gone
    Dec 2005
    Quote Originally Posted by Sausage
    Might I suggest, instead of just electrical tape, using a small plastic Project Box from radio shack? drill a couple holes in it for the wires. Foe even extra security, fill the box with epoxy or silicone, or even hot glue!
    00 Subaru Legacy GT Limited Black/Black; Mods: Hella SuperTones, TrunkMonkey
    Support the Monkey
    Dec 2005
    NJ
    That's a really good idea...never thought of it.
    - Gone
    Registered User mike3026's Avatar
    Feb 2008
    Fort Bragg
    Does it matter if your stereo amp positive wire is attached to the B+ wire or to the positive terminal???? I did exactly what you said in the directions. I get a negative 30 amps when I turn my key to radio only. However, when I start the engine it stays at zero amps. I turn on the lights, hi beams, AC, and radio full blast and the gauge will go negative for a split second and then jump back up to zero amps. My battery has never died before and isn't dead now. What do you think?
    I tried my stereo amp wire on the positive terminal and the B+ terminal, and the gauge is the same regardless.
