Oil pressure sender.. should work with most electronic gauges. G.I. Joes is a sports/auto store in Oregon, and they indeed have them on the shelves. By the way, I googled that sender in about two seconds for future reference![]()
This is a discussion on Build your own gauge pod! CUSTOM!!!11OMFG!!! within the Cockpit and Cabin forums, part of the Tutorials & DIY category; Originally Posted by E-Wrex ....... And I never found anything out about the sender, although they do sell them at ...
Linky poo please? ...
"Never Launched"![]()
Dougie - Founder, 250,000 mile club
-5,000 posts
Thanks for the link.Originally Posted by E-Wrex
*Jc Whitney*
You mentioned a specific store, I thought I might patronize them.
I googled for that specific outlet (gi joes) before I even asked you...![]()
-5,000 posts
well its waaay better than i could have ever come up with
I'm not an expert but just wanted to share this idea. Went to Home-Depot and purchased a "PVC" piping "end-cap"...about 2/12" inches in diameter that would, pretty much, match the diameter of my boost-gauge. First I cut out the depth of the cap to fit the gauge and drilled some holes (four in my case), three in the back of cap (two to secure the gauge with the bolts provided/attached to the gauge and one for an adjust feature on my gauge). I also drilled a hole at the bottom of cap for mounting and wiring purposes. Sanded the cap to erase all manufacturer brands and gave it a couple of paint coats. PVC is very tough and clean so there isn't much more you need to do to it. So, I've drilled a "small" hole on the dash-board (left of the clock) because that's where I routed my wires through. The gauge looks no different than many "after-market" ones and perhaps BETTER than some!
I like the original casting (mold/shape) that the PVC pipe already had.
Hope this inspires some DIY's. Oh, by the way...the project only cost me about $2.37 after hardware...maybe $5.00 if you don't already have aerosol (spray) paint.
Can you post some "pictures" of your "PVC" boost gauge enclosure made from an "end-cap"? I am very curious to see how it "turned out", especially since you made it for so little "money". Next time I am at Home Depot, I will have to look for one of those "thingies" if it will be better than an "after-market" one.Originally Posted by subeerex
[QUOTE=Gooner]Can you post some "pictures" of your "PVC" boost gauge enclosure -
Sorry man! I have a "flintstones"-age computer set up that is not equipped to send pictures. The project's simple though as I mentioned. The hardest part is probably adjustinf/cutting for the depth of the cap to fit the gauge depth. But, imagine cutting a typical water cup in half or so (yeah the plastic type you find in your kitchen cabinet). Now, you wanna cut it to fit a lemon with the head of the lemon sticking out just above the rim of the.. now, shorter cup...you want that lemon snug too. Well, it's the same idea with this project but the lemon is your gauge in this case. Depends on the gauge type (mine has two built-in bolts on back for mounting and an adjuster button) you drill the holes necessary to secure the gauge to the cap. Now lay the cap on it's side and deside/mark the bottom of the cap which will match the bottom of the gauge (once in mounted position). Drill a hole (in my case, about 3/8" of an inch) at this bottom of the cap to get the wires through and will also serve to mount the gauge. To this 3/8" hole I screwed-on a "hollow" threaded bolt, same 3/8" size (about 1" inch in length) and secured it with two washer-like nuts (as thin as an American dime-coin but with enough thread to call it a nut), one inside and out side of the cap. I drilled a 3/8" hole on the dash board, left of the clock to mount my gauge and also route my wires through. That "hollow" bolt goes through this hole on the dash board and, again, secure it with a nut on the inside/bottom of dash.
I sanded the cap to get rid of any markings, emblems or logos from the manufacturer and gave it a couple of paint coats (mine is red). Like I said, the project will only run you for under $5.00 bucks (can't beat it), PVC cap, nuts, bolts and spray-paint.
Hope I was as clear as possible...sorry about not being able to show pictures.
Good luck!
I bit the bullet and bought an autometer a-pillar pod, it looks way freakin' cleaner. Oh, and I got some decent gauges, pics in a little bit. The little project was fun, but getting bondo realllllly smooth is an art. The end producy had little random flat spots and bubble pits and such, but it really wasnt bad in the end. Plus it probably wasn't worth the overall effort considering autometer gauge pods are around 50 bucks and I probably spent about 40 just getting everything right. Plus you can get some knock off ones that dont fit quite as well for like 20 bucks off ebay. Pics in a minute!
I cheated! Looks freakin' sweet tho, if I do say so myself.
if you try another fiberglass project try using speaker grill cloth stretched and superglue with activator to hold it in place and then put fiberglass resin on the grill cloth to get a mold. will make life much easier for you. as far as the bubbles at my shop we have a sprayable high build primer (i want to say it's called slick sand) that we use that gets rid of the bubbles so it doesn't have to be perfect. the flat spots can be minimized using a foam backed sand paper so you don't have pressure points where your fingers are causing them. all in all with those materials you would be probably over $100 that you could pick up a pre made gauge piller though. you should be able to find all this stuff at a local auto body paint store. hope this will help.
How is that? What type of car is that is it a carbon fiber gauge pod? Just correct me if I am misunderstood.![]()
