Build your own gauge pod! CUSTOM!!!11OMFG!!! - Page 2
Results 16 to 30 of 41
This is a discussion on Build your own gauge pod! CUSTOM!!!11OMFG!!! within the Cockpit and Cabin forums, part of the Tutorials & DIY category; Originally Posted by Wrinkleboi looks like a lot of work for the money saved, but i know exactly where you ...
    Registered User dielectric's Avatar
    Mar 2003
    Palatine, IL
    Quote Originally Posted by Wrinkleboi
    looks like a lot of work for the money saved, but i know exactly where you are at. sometimes projects like that are fun, and you'll appreciate it. i'm in teh middle of seeing if i can replicate the rally armor mudflaps for under $50 total... probably not worth the time, but its a fun challenge.
    bryan
    I made rally armor-style mudflaps for my VW Rabbit for free. I found an old truck mudflap at the side of the road, and cut it with a sabre saw. I don't suggest the salvage route, but I do suggest buying a huge truck mudflap and cutting out four dinky ones for your car. Also, use galvanzed or plastic hardware, I didn't and the sheet metal screws got rusty and looked awful.
    Also, awesome initiative on the part of the original poster. I hope you're wearing gloves and a mask, though!
    ribonucleic acid freakout
    Feb 2005
    pixpixpixpixpix
    she was like "ahhhh you're nailing me!..cool."
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    Quote Originally Posted by fokai
    pixpixpixpixpix
    +1
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
  6. #19
    Registered User E-Wrex's Avatar
    May 2005
    Portland
    Pcs on their way, uploading as we speak.
    My poor tranny!... someone sell me an aspen white 06 sti.
    Mods
  7. #20
    May 2005
    Portland
    Pics!
    After bondoing, and way too much sanding, I'm getting closer to the end product. I haven't worked on it for a while, and picked it up today, so I can finally get my gauges installed for in anticipation of getting my EM set up and tuned. Pics:
    It'd tough to get a smooth finish, everytime you sand it relatively smooth, you find pockets that you have to fill with bondo again, and resand. I'm getting better at it, but it's still a learning experience.
    Bondo is fun stuff! Althought after like 4 hours of sanding, loses it's novelty. I'm going to try and get the bondoin finished and sanded by tonight, and maybe go pick up some paint and primer. I'm trying to decide whether to go black, and paint the rest of my interior black (like the s202-203), or try and match the interior gray color. I think black would be a bit more exciting. In time I also plan to put a row of switches on the upper section of it, one for the guage back-lighting, one for IC sprayer, etc...
    Mods
  8. #21
    May 2005
    Portland
    Wow, after looking over this thread I realize how much of a slacker I am! Quick question, and Im going to take this thread for a quick hijack: Anybody know where to get an Oil pressure sender that will fir the oil galley plug that comes from www.subaruwrxparts.com? I got the plug, and my sender doesn't fit, now I need to figure something out for that. Oh, and are all senders basically the same thing? Hoorah for a triple post!
    Mods
  9. #22
    Feb 2005
    damn, once you get that all sanded down its gonna be lookin hawt
  10. #23
    May 2005
    Portland
    After sanding for about three hours and adding more bondo, it's looking way good. there's still a few tiny holes and stuff from bubbles, and little crevices here and there, but 20 coats of primer aughta fix that . Got the last bit of bondo on the top part, and need to sand that down, hopefully I should be able to start painting tomorrow, and get to installing and wiring my gauges this weekend.
    I just came to the realization that this is the silliest write up evar! Atleast it's fun
    Mods
  11. #24
    May 2005
    Portland
    Change of plans number 246: I actually just cut out the part that holds the gauges and glued it straight onto my a-pillar. I was getting ultra fed-up trying to put the whole thing in, and it turns out this angle worked way better. It fits nicely (obviously using the stock a-pillar), and after a bit of bondoing and molding it looks better than most if the a-pillar gauge pods Ive seen. I'm currently painting it with spray on epoxy that is normally used for appliances. I was planning on primering and painting over it, but the finish looks really cool, and I imagine is pretty durable. I'll get some pics up of the almost finished product this afternoon. If the finish on is as cool as I think it is, I may paint all the other pillars and other light-gray parts with this stuff. I'll be sure to post pics of everything after paint and installation.
    Mods
  12. #25
    May 2005
    Portland
    Gauges are in, but they won't light up.... time to re-wire.
    Mods
  13. #26
    Registered User labelskate's Avatar
    Oct 2005
    Ahwatukee, AZ
    PMI? You play paintball?
    Sweet gauge pod lol wish I could do that.
  14. #27
    May 2005
    Portland
    Yeah, I used to play pretty regularly. I gotta 04 shocker, and my cousins got an angel, we used to go to the local fields and own everybody. My cousin played as a rookie for a year and his team got first in the NW division, winning against landslide by a luck shot.
    Mods
  15. #28
    Moderator timber's Avatar
    St. George, Ut.
    Quote Originally Posted by E-Wrex
    Did you ever end up finding anything out about your oil sender? I think I have a bad one so I'm curious if thet are all the same also..
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
  16. #29
    Registered User Redline927's Avatar
    Jun 2004
    New Jersey
    standing by for final product pics...
  17. #30
    May 2005
    Portland
    It officially looks like sh!t. It works for now, but wasn't nearly worth the time. I need to get better gauges and a better gauge pod, but atleast I can monitor my boost.
    And I never found anything out about the sender, although they do sell them at G.I. Joes
    Mods
