Engine Cuts off over 5000 RPM
Results 1 to 9 of 9
This is a discussion on Engine Cuts off over 5000 RPM within the Clubwrx Website/Forum Support - Report Errors forums, part of the Community - Meet other Enthusiasts category; Hi Guys, I have a 2008 wrx with no modifications other that a boost Tee controller. The issue that i ...
    Nov 2014
    Hi Guys,
    The issue that i am having is that when the engine reaches above 5000RM the engine cuts off and with that the cruise control starts flashing and the traction control light come on along with the Service engine light.
    After sometime these lights turn off.
    My question is why is this annoyoing problem happening, can someone please advise what it could be.
    Thank you
    Ziggy
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Have you tuned the car for the MBC?!
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Banned for Ageism 96accord's Avatar
    Mar 2007
    Baltimore, Maryland
    Ziggy,
    It sounds like you are over boosting. Do you have a boost gauge? Have you been tuned for the boost controller?
    PS: This thread should be in the engine sub-forum.
    Edit: Zax beat me to the post.
    Nov 2014
    Hi Zax
    no i havent.
    should i be taking the car to a mechanic to do a tune or can i do it manually by turning the knob on the Boot tee to find the desired level.
    Nov 2014
    Hi Zax and 96accord,
    Is the issue that i am having a boost spike, and if i take the ball and spring from the boost tee will that fix the issue?
    zax
    zax is offline
    Nov 2008
    Do not install parts until you understand the implication of the installation.
    You cannot simply install an MBC and crank up the boost. If you're lucky, the engine is not blown. If you're lucky.
    Facebook me here
    Mar 2007
    Baltimore, Maryland
    Get rid of that manual boost controller and go back to stock.
            MainFrame's Avatar
    Austin, TX
    Lets hope fuel cut has saved your engine from too much damage..
    Aug 2012
    Tucson, AZ
    I'd suggest doing some research on what's required other then slapping parts on
    These cars have to hit a certain psi as well to set the lights off and hit fuel cut. Sometimes you over boost without setting them off, so in this extreme case you've been doing it multiple times
    Put the stock back on. It's more then enough for stock levels and up to stage 2. And make sure you don't swap vacuum lines by mistake
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
