03 wrx sluggish not boost leak either (log file inside)
Results 1 to 11 of 11
This is a discussion on 03 wrx sluggish not boost leak either (log file inside) within the Clubwrx Website/Forum Support - Report Errors forums, part of the Community - Meet other Enthusiasts category; https://docs.google.com/spreadsheet/...Wc&usp=sharing Hey guys im having some issues for my car as it appears to be a never ending battle. Ive ...
    Registered User sti_killer03's Avatar
    Nov 2010
    pennsylvania
    Hey guys im having some issues for my car as it appears to be a never ending battle. Ive been experiencing problems spooling and hitting target boost,(20psi) on vf39 and also feels like my timing is being pulled. Seems like getting to 80 is a challenge now. So far what i have done is Boost leak test found only one and it was my piston on my turbosmart bov. Fixed it Second was check for exhaust leaks and fix them i now have no leaks. IAM has found its way down to 3 or 0 sometimes the car does have high miles about 176k did compression check and it was 160,160, 160,158. low one was cylinder 3 (passenger back) I also changed plugs after compression test ngk iridium ixs one step colder I have attached a file to my log so you can see for yourself and tell me what you think. any and all help would be greatly appreciated i also believe my mods list is in my profile
    Thanks in advance
    Brandon
    Nov 2010
    pennsylvania
    here is my list of mods in case you cant see it on my profile:
    Engine:
    VF39 Turbo
    Crucial P&P&C TGV deletes
    DW 565cc injectors
    Walbro Fuel pump
    NGK iridium 1 step colder plugs
    Cobb SF short ram intake
    Samco Intake elbow
    Cobb Down pipe w/ High flow cat
    Cobb 3in Cat back exhaust
    Crucial Up pipe
    Grimmspeed PP&C Crossover Pipe w/ Grimmspeed extra thick gaskets
    STI TMIC w/ Ebay Y pipe
    Turbosmart Dual Port Bov
    Perrin Turbo Inlet
    JLM Motorsports Billet Pitch Mount
    Perrin Lightened Crank Pulley
    Crucial CU seal gaskets
    Crucial 1.4 bar rad cap x2
    Samco Rad Hoses
    Crucial Thermostat
    ECUFlash tune by testes running 20 PSI
    Prodrive 3-Port BCS
    Silencer delete
    HKS Oil Catch Can (Ebay) - not installed
    Crucial Radiator Shroud
    Crucial P&P&C Manifolds
    Speed Monkey Heatsheild
    Cusco Engine Mounts
    Paranoid Fabrications Lucrid and OEM Grounding kit
    Paranoid Fabrications Big 3 wiring kit.
    Transmission/Drivetrain:
    04 rebuilt trans with sti gears and double scnyros on first and reverse
    ACT Street Clutch
    ACT Streetlite Flywheel
    Kart Boy Shifter bushings
    Kart Boy Rear Shifter Bushing
    Kart Boy Crossmember Bushings
    Perrin Rear End locker kit - not installed yet
    STI Group N Trans Mount
    SPT/KartBoy Short Throw Shifter
    TiC Pivot Bushings
    Goodridge Stainless Steel Clutch line
    Redline Light Shock Proof fluids
    Suspension:
    Progress Springs
    Tokico D specs struts /w rear adjustment extenders
    STi Replica Strut Bars
    Super Pro ALK
    Super Pro SRB
    Brakes:
    Centric Slotted rotors - all 4
    Hawk HPS pads - Front and Rear
    Exterior:
    S202 Wing
    STI Hood Scoop
    Painted Headlamp Inserts
    17" Rota G-force in steel gray
    C-west Carbon Fiber Front Lip - Not installed yet
    Interior:
    Apexi Turbo Timer
    STI Shift Knob
    Prosport Oil pressure gauge/Boost Gauge/EGT gauge in a autometer clock pod!
    sorry for the misc stuff just pasted the list from my laptop
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    Did you clean your MAF?
    Nov 2010
    pennsylvania
    yes i did even made sure the o ring wasnt broke
    Jul 2013
    North Carolina
    That's a raw deal man, there's so many things it could be. Did you flow test injectors or test fuel pressure?
    Jul 2013
    North Carolina
    May be as simply as a fuel filter or bad fuel
    Nov 2010
    pennsylvania
    heres an update so far i have replaced my fuel filter changed gas stations so testing for crap fuel still no change but i did do another boost leak test and once again my turbo smart dual port is leaking out the top trumpet around the piston starts around 3 psi on gauge.
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Are you doing the tuning yourself?
    ...also seems like an obvious thing, and I am sure the leak test would have caught it if so, but you have made sure the intercooler connections are all tight (including underneath)? I can't help but notice you have the "ebay Y pipe" and wonder if there could be an issue there.
    Nov 2010
    pennsylvania
    when i boost leak tested it it started bubbling out of the bov and got worse as boost increased but other than that i heard no other obvious leaks end the psi drop down was close to normal 1 sec per psi drop
    Nov 2010
    pennsylvania
ID:	115926Click image for larger version.
    Nov 2010
    pennsylvania
