I need advice on buying a wrx
Results 1 to 7 of 7
This is a discussion on I need advice on buying a wrx within the Car Purchasing Forum forums, part of the ClubWRX.net Marketplace category; There is a guy selling a 2002 bugeye Wrx near me he said the long block needs replaced witch means ...
    Oct 2015
    There is a guy selling a 2002 bugeye Wrx near me he said the long block needs replaced witch means the whole engine right? But he said he blew on the heads and they are alright or something I don't know what the hell that means but if the heads are alright it's the short block right? And that a lot cheaper? I think. how much do you think it would cost to replace the whole engine if I had a macanic do it the guy says it needs a new engine or rebuilt would rebuilding it be cheaper? He wants 1500 is that a good deal? It has 216xxx miles
    lit fam XJman's Avatar
    Feb 2015
    At work
    Unless you are purposely buying it to sink money into it I would pass. Long block would include the heads. I've not hear the term he used so I can't speak to what he meant.
    Sent from my Nexus 6 using Tapatalk
    All? NO ALL!
    voidin warranty since 05 unseen's Avatar
    Jan 2015
    631 to 516
    Quote Originally Posted by Dreamz18 View Post
    umm pause...
    jk, does he mean he did a compression test and found that everything is holding? a cheap crate engine should run you around 5k installed. someone correct me on the figure.
    stinkeye member #976
    2014 wrx hatch build
    http://www.clubwrx.net/forums/builds...een-build.html
    Oct 2015
    umm pause...
    jk, does he mean he did a compression test and found that everything is holding? a cheap crate engine should run you around 5k installed. someone correct me on the figure.[/QUOTE]
    This is what the text said that he sent me
    rob blew on the bottom of the block. i think the head is still ok.
    Feb 2015
    At work
    How do you know the piston didn't impact the head? Thinking it didn't doest mean it didnt
    All? NO ALL!
    Walk away.
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    So think about it. You'd end up paying $5 - 7 grand for a 14 yr old car with 216,000 on the chassis & tranny. I'd pass also.
