Expensive Service Intervals?
Results 1 to 15 of 17
This is a discussion on Expensive Service Intervals? within the Car Purchasing Forum forums, part of the ClubWRX.net Marketplace category; I'm looking at buying a 2014 WRX hatchback. I was wondering if there are any expensive service intervals on the ...
    Aug 2014
    I'm looking at buying a 2014 WRX hatchback. I was wondering if there are any expensive service intervals on the WRX that I should be aware of? I know with some cars, notably sports cars, there are expensive service intervals in the first few thousand miles. Just want to make sure i know what I am getting myself into.
    Thanks!
    Matt
    Palmyra, NJ
    Oil changes are Synthetic...so if you pay a dealer or shop to do it, they will charge you $60ish or so. Its obviously much cheaper if you do it yourself. But you don't have to change oil until ever 7500 miles.
    Otherwise...just Google what they do at the 30k, 60k, 90k, etc. services.. A lot of the "Service" can be done at home yourself. If you take it to the dealer, they "inspect" a lot of crap and charge you the labor/time it takes to do that, such as $50 or $60 for a cabin filter change. You can order a cabin filter for $15 off Amazon and install it yourself behind the dash in 20 minutes.
    Spark plugs (60k) can be considered expensive, mostly because of labor. The time it takes to remove the battery and other stuff to get to them drives up the time it takes. But, its another thing you can do yourself because it's decently easy so long as you have tools.
    Timing Belt service at 105k can be costly of course...they have to take apart much of the front end of the car...that can run you anywhere from $900-$1500 depending on what else you get done at the same time (radiator? Coolant, thermostat, water pump, etc.).
    Bottom line though, these cars aren't much more expensive than any other basic car (with the exception of a BMW or Mercedes).
    Oct 2011
    Santa Ana, CA
    What ^^ said.
    Don't forget tires. You MUST change all 4 at a time.
    Being AWD, you probably love grip, so forget about buying cheap tires anymore, not that you ever should have...
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by UEDan View Post
    What ^^ said.
    I didn't think maintaining a WRX was too bad.. until I had to unexpectedly drop $1150 on tires simply because I ran over a screw and got a puncture.
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    It will also depend on your warranty situation. The tune up services can be pricey and also brake jobs. You can do all of those things yourself.
    But you still want to be careful to follow dealer service intervals, because they can be picky about where it gets serviced. I didn't buy extended warranty mainly because as parts wear and need replacing I'll upgrade them.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    Registered User grendels_wrx's Avatar
    Aug 2013
    Northen, VA
    Was this because it was too close to the sidewall?
    I have a nail in my right rear now not close to the sidewall and not leaking. Not driving the car after discovery which was close to when it got in there I think. I'm gonna pull it out one night and see if it leaks. If it does take the tire down to the dealer for a free patch since I have the Gold Plus extended warranty that covers it. Also covers the original tires which according to the previous owner of the car have like 100 miles on em since he swapped out for new wheels/tires almost right away.
    I was told by the dealer that compared to say my Nissan (the dealer park sells Subaru, Ford and Nissan) that the Subaru is 25% more to maintain. Not German car level I guess but not cheap.
    Timing belt - I'll be selling my car before I have to replace
    Spark plugs - I figure this is the one main maintenance cost which most people will have to get done. I don't understand why it's this low for a modern car.
    Tires, brakes, etc to me are normal considering it's a sporty performance car. So I expect higher tire and brake costs.
    2013 Black STi Limited sedan
    Oct 2011
    Santa Ana, CA
    I had a nail in the shoulder of the tire and that was unrepairable.
    I would just have the dealer take it off and fix it right then and there. No risk of deforming the tire if there is a leak.
    Luckily I had only put on a few hundred miles. New tire.
    Aug 2013
    Northen, VA
    So you recommend I don't bother pulling the nail out myself, its not going into the tire so much as across the tire through the tread. I was gonna pull it out in my garage with a jack ready in case it deflates. Alternative is to drive it 3 miles down the road to the dealer and risk nail getting worse. I hate these decisions. Also be nice if dealer wouldn't have to jack it up. Just look and go, it can be plugged, come out with plug kit ready to go, pull out nail and insert plug if it leaks.
    Aug 2012
    Tucson, AZ
    If you know how to plug do it...but from the sounds of it being across the tread rather than a puncture then there's no problem. The only time you really can't plug a tire is if it's too close to the sidewall where the tread ends
    Stinkeye member 520
    Aug 2013
    Northen, VA
    Quote Originally Posted by nsibanez View Post
    Well I called dealer last week and I can basically pull the wheel off and take it to them and I get free repair. I just have to give them mileage of car. But ideally if I pull out the nail it won't leak. But if it does I have to get my first experience with jacking the car up.
    Maybe I'm being a bit silly not just driving the car down the road 3 miles to have em fix. But I am barely driving car as this nail in the rear tire delayed me getting the clear bra and opticoat on it.
    Oct 2013
    Boston
    Spray some water where nail came out of and see if its bubbling air.
    STINK EYE MOB #500
    1996 Honda Civic Lx
    Palmyra, NJ
    So what if you have to jack the car up...it'd be the same as if you had to change a tire. Jack it up, get the wheel off, take it to get repaired, put wheel back on, **** bitches. Profit.
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by TownLine500 View Post
    I'm not sure I follow. None of the maintenance I've done had anything to do with a warranty. I do most of the work myself, so things like oil changes, brakes, spark plugs, etc don't really cost any more than any other car. But having to replace four tires instead of just one quadruples the cost.
    Quote Originally Posted by grendels_wrx View Post
    Pretty much. I had the screw pulled, and the hole patched.. but then a week later the car started riding very rough. The inner sidewall of the tire buckled and bubbled out. Since the tires were about 1/3rd worn down the tread depth was too far off to install a new tire without replacing the other three, and when your tires cost $290 a piece it adds up quick.
    Aug 2013
    Northen, VA
    Yep that's the plan. However I just got the car so I'm a bit nervous about screwing up my pride and joy jacking the car up with the factory stand.
    Aug 2012
    Tucson, AZ
    You're not going to screw it up. It's pretty straight forward
    How is the nail preventing you from getting clear bra?
    Stinkeye member 520
