bought used wrx
Results 1 to 15 of 17
This is a discussion on bought used wrx within the Car Purchasing Forum forums, part of the ClubWRX.net Marketplace category; 04 wrx with this heavy exedy clutch, an aftermarket exhaust etc. ( i will post pics later ) has 94k ...
    Aug 2014
    bought used wrx
    04 wrx with this heavy exedy clutch, an aftermarket exhaust etc. ( i will post pics later ) has 94k miles. tranny seems to be in good condition, engine runs strong, turbo seems to spool correctly.. what do you guys think? what other info can i give ?
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    What kind of information are you looking for?
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Aug 2014
    basically; was it a good buy? there is a receipt for an oil change from texas, roil purple 10w-30 synthetic i believe. but it was done at 80k. if i do all fluids, filters, belts etc. how long do you think it would last until major work needs to be done?
    Nov 2011
    North GA
    To be honest there is no way to possibly know that. That car could go forever or it could die tomorrow.
    Things I'd be concerned about:
    You're asking these questions after buying it.
    Our cars use 5w-30 so that oil needs to be changed asap. What kind of maintenance life did the car lead? If that's how the oil was changed all the time it could be an issue.
    When were the brakes done?
    Have you done a compression/leakdown test or had a mechanic look over the car?
    If the exhaust is turbo back you'd need to know how the car was tuned.
    Why did they put in a HD clutch?
    Is there rust?
    How are the tires?
    Personally, without any additional knowledge other than what you've given I wouldn't have bought that car.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Aug 2014
    Quote Originally Posted by michaelwfox View Post
    I want this forums opinion..
    I thought 10w-30 was usable depending on the climate?
    the brakes will be done by me
    no, is there a economical way to test it myself? and yes I have
    in the process of finding that out. . would buying a cobb accessport solve this issue?
    no clue but its annoying as hell in rush hour
    Is there rust?
    no
    How are the tires?
    about 80 percent
    Aug 2014
    So what oil should i be putting into it? what transmission fluid? what differential fluid? ive seen different answers in the stickies and other peoples posts.
    Nov 2011
    North GA
    10w-30 isn't a recommend oil type regardless of climate.
    Quote from another thread:
    "5W30 is the recommended oil for best fuel economy and is what Subaru puts in the car from the factory. As you can see from the factory manual page above,5w30 basically works for most of us due to climate temps. Obviously some might run a different oil in the winter and summer seasons depending on where you live or by preferred choice."
    Yes you can do the test yourself.
    Basics: Compression/Leak Tests
    Getting an accessport would allow you to tune it yes but, running a TBE without a tune could have damaged the motor. I'd ask the previous owner about how they tuned it (if it's turbo back) and go from there.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Nov 2011
    North GA
    Quote Originally Posted by randomusername View Post
    Rotella T6 5w30 is a pretty widely used oil.
    Trans and dif should get Subaru Extra-S only.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Aug 2014
    thanks I will test compression and find out about tune asap. I see that desert climate(which is what im in) says 10w-50 synthetic, that might be what the jiffy lube receipt said "royal purple 10w-50" cause the car came from texas which is also desert climate.
    Aug 2014
    ok I will look into rotella but that disheartens me because ive read people saying motul, amsoil, mobil1 etc. are the best... and youre the first one to say rotella
    Nov 2011
    North GA
    Welcome!
    10w50 should be okay but, I'd still change it just to be sure.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Nov 2011
    North GA
    Everyone else is wrong lol.
    But really, T6 has consistently returned great UOAs for our cars. Google Rotella T6 WRX and you'll see plenty of support for it.
    Sent from my Galaxy S4 (typo, schmypo)
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    T6 is 5w40 and non energy conserving.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    T6 only comes in 5w40.
    Also, in my personal experience, Extra-S sucks. Out of the four gear oils I have tried (including the non-synthetic that came in my bugeye from the factory), Extra-S was by far the worst. It's the only gear oil I really had trouble with grinding gears. It was like the coefficient of friction wasn't high enough to engage the syncros. The best two gear oils I have used were Red Line, and Amsoil. Never had a singe issue with either of those.
    In the gearbox you want an oil with friction modifiers for syncromesh transmissions, in the rear diff (front diff shares oil with the gear box) I would use whatever you pick for the gear box, but a version without the friction modifiers. No such thing as too slick for the rear diff.
    Regardless of weight, Royal Purple is pretty ****ty oil, especially in turbo cars. It has a tendency to froth, and many of the UOAs I've seen were on the verge of scary in terms of wear. I wouldn't run 10w50 either, and I'm in TX. 50 weight is pretty heavy unless you have a built engine with looser clearances and need to do something to keep your pressure in spec. Anything from 0w30 to 10w40 should be fine.. maybe on the heavier side of that if it's regularly above 100°F where you live.
    If you really want to know what weight works best for your specific car and climate, you will need to monitor oil pressure and send samples in for frequent UOAs.
    Then you evidently haven't read much on Subaru forums.. at all. I would say Rotella T6 is probably the preferred oil for 70% of the community.. at least in the United States. I wouldn't go as far as to say it's the best, but it's inexpensive and readily available. That, coupled with it's impressive UOA results, and group think make it to go to oil for most turbo Subaru applications. There are some GL5 ester based oils that I would say are better.. Motul v300, and Amsoil Dominator are probably about the best you can get (and their price tag reflects that). Redline and Valvoline VR1 are also excellent choices, as is German Castrol 0w-30 (although that seems to be getting harder to find, and might not be the best for hot climates).
    Engine oils I would avoid.. anything made by Penzoil, Mobil 1 5w30 (shears horribly in turbo applications.. which is funny, because Mobil 1 10w30 seems to perform pretty well), Royal Purple, any non-synthetics..
    I would be most concerned about your tune situation. If your tune isn't right for the modifications you have on the car, one trip to the grocery store could ruin your engine.. even if it "feels" like it's running good.
    Aug 2014
    Thank you everybody for the great replies with detailed info!
    you're right I haven't read deep into the forums, I've just read through threads that have popped up on google.
    I contacted previous owner of vehicle and he said its tuned for the mods which should be: "aps tbe, aps cai and aps hard y pipe kit for the tmic"
    Now i bought from a mechanic shop and am wondering if they kept the mods on or replaced some or all with factory stuff. how can I check this?
    I picked up fuel,oil,air filter oem replacements and a 4qt. bottle of t6 rotella 5w-40 and I have two more questions: it labelled as diesel oil, did I get the right one? its all they had on the shelf.
    and will I need to go back and get another bottle? isnt the capacity 4.7 qts? I couldn't remember at the store.
