Failed emissions on carfax?
Results 1 to 15 of 28
This is a discussion on Failed emissions on carfax? within the Car Purchasing Forum forums, part of the ClubWRX.net Marketplace category; Hey guys. Looking at a slightly used 2013 WRX Limited (17,000 miles). Saw on the carfax where it said it ...
    Aug 2013
    Hey guys. Looking at a slightly used 2013 WRX Limited (17,000 miles). Saw on the carfax where it said it failed emissions inspection but then passed it on that same day only 2 miles on the car later.
    Any ideas what this is? other than that the car looks super clean.
    Thanks.
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    Might have popped a CEL or failed a visual inspection. Are u sure its stock?
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    Probably failed, guy went home put it back to stock, then it passed. Happens all the time. Be wary of buying any used car that's known to be driven by 20 something year olds and are generally heavily modded and beaten. Just cause its stock now doesn't mean it always was.
    Case in point, my 2013 was stage 2. Now it's stock. You'd never know if I didn't tell you because I'm anal and put every stock bolt and shield back in place just like factory. I even bought a new dash cover so when I removed my boost gauge there were no holes drilled in it.
    Not saying that's the case with the one your looking at but just something to keep in mind when buying a car like this.
    [Edit]:Just so you know, a factory 100% stock 2013 car WILL NOT FAIL emissions. If it failed. Then it was modded
    And what state do you live in that they test brand new cars? Even in nazi California I think it's a few years before. New car needs to be resmogged.....
    2013 wrx sedan(saving up for a 2015 STI)
    Previous faist cars: '05 Mustang GT '02 RSX-S, '91 SR20 240sx, '85 300zx turbo
  5. #4
    Registered User wrxnguyen's Avatar
    Jul 2013
    714 Orange County
    Quote Originally Posted by EndlessSea View Post
    In CA new cars don't get smog check until 5 years later. After that it's every 2 years.
  6. #5
    May 2007
    orlando flawduh
    We don't have emissions testing in FL so correct me if I'm wrong, but a CEL can cause you to fail right?
    Lets say a day before he fills up his gas tank... Doesn't tighten the cap... Now he has a CEL. Is the car modded? No. Is it going to pass? No.
    desiree
  7. #6
    Quote Originally Posted by wrxnguyen View Post
    In CA new cars are smogged at any time during title transfers not between first degree relatives and not between the descendants of natives in some counties; during such transfers and/or every two years after the first five in others. Check your local county.
    - Al Stewart
  8. #7
    Aug 2013
    Could it be a city thing to require emissions inspections? I live in Texas but not in the city where the car is located (also in Texas). I know they do car inspections in Texas but not sure if emissions is part of it (I recently moved here). It looks as if it was inspected after it was traded in to the dealer. Do dealers do an emissions test normally? Maybe I should ask them about it.
    Here are the links to the carfax and car. Basically is there no way of knowing if it was modded?
    Used 2013 Subaru Impreza WRX For Sale | Denton TX
    CARFAX Vehicle History Report for this 2013 SUBARU IMPREZA WRX
  9. #8
    Jan 2012
    Philly Area
    Needs moar photos. If it failed due to modding, that is likely from an aftermarket downpipe. If you can get a pic of the engine bay taken from the passenger side and looking at the back of the engine, we may be able to determine if it had been modded. That might be difficult, understandably, so what we would be looking for is whether the stock heatshield exists, looks like stock, and with closer inspection to see if the bolts for the downpipe look to have been recently messed with.
    - Will
  10. #9
    Aug 2012
    Tucson, AZ
    the 13's are also getting CEL for something that dealers cant figure out. anywhere from loose throttle body hose to a bad splice in a wire harness and theyre getting evap codes
  11. #10
    Yes that's such an odd story. Early bugeye cars would get phantom codes but they released a reflash and it seemed to fix the issues. Now different weird issues.
    - Al Stewart
  12. #11
    Dec 2012
    Philadelphia, PA
    Rather delete my post.
  13. #12
    Aug 2013
    Can I get a little more help guys? I am trying to decide if this car is worth driving 5 hours tomorrow for. He has made me a good offer on the price with my trade in.
    I talked to him about the failed emissions and he said it was because the battery had been disconnected and they needed to drive it a bit before the monitor reset? This sound legitimate?
    Also here are some engine pics:
    http://www.pix8.net/pro/pic.php?u=5308OsKWQ&i=11585872
    http://www.pix8.net/pro/pic.php?u=5308OsKWQ&i=11585873
    http://www.pix8.net/pro/pic.php?u=5308OsKWQ&i=11585874
    http://www.pix8.net/pro/pic.php?u=5308OsKWQ&i=11585875
    http://www.pix8.net/pro/pic.php?u=5308OsKWQ&i=11585876
    http://www.pix8.net/pro/pic.php?u=5308OsKWQ&i=11585877
  14. #13
    Quote Originally Posted by Coletrain12 View Post
    A disconnected battery would cause sensors to not show "ready" state, therefore failing emissions.
    - Al Stewart
  15. #14
    Jul 2013
    714 Orange County
    I got a lame excuse for taking in an old truck once.... guy said gas cap was not closing properly... charged me $30 for a new gas cap! It was either that or fail.... they gotta make money somehow I guess.
  16. #15
    Aug 2013
    He said it wasn't modded and I don't really think it was.
    I wasn't sure about the battery thing because I have never really dealt with it. Thanks for clarifying. I think I may go take a look at it tomorrow and see how it drives.
