What is considered TOO many miles?
Results 1 to 13 of 13
This is a discussion on What is considered TOO many miles? within the Car Purchasing Forum forums, part of the ClubWRX.net Marketplace category; Hello all, I'm still looking for a good WRX, and I had a question regarding miles. What's considered too many ...
    Mar 2013
    Hello all,
    What's considered too many miles? I know it really depends on how the car was maintained, but at what point am I just asking for trouble?
    http://chicago.craigslist.org/nwi/cto/3688526323.html
    Take the above link for example.
    The car looks and sounds well maintained, but is 142,xxx just too many miles regardless of how it was maintained?
    I'm not necessarily looking to purchase this vehicle, but it is definitely one of the cleaner/stock ones in my area.
    I'm looking to spend no more than 10K, and I don't plan on modifying the car too much. Stage 2 at most.
    With the above mentioned mileage, how long do you think the car would run for assuming all maintenance was done properly?
    Thanks for the help!
    Cheers,
    Henry
    May 2007
    orlando flawduh
    my PERSONAL opinion.. if i were buying used, i'd not buy anything with more than an average 10k miles per year
    however, most people average about 15k miles per year so 142k isnt that bad for an 03
    like you said that maintenance is key. a car could have 50k miles on it and completely beat to hell and back... never had an oil change.. used the wrong type of gas... or it could have 230k miles of perfect driving/maintenance/service history/etc.
    desiree
    Mar 2013
    Quote Originally Posted by wrxtreme06 View Post
    Thanks for your input.
    I know the WRX is a reliable car, but too many of the drivers are not reliable owners. The high mileage does scare me, but it's very difficult finding a low mileage, low beat on WRX these days.
    There are other WRXs that have slower miles(95-110k miles) but have not had all the maintenance down like the above example.
    Maybe i should go check it out.
    May 2007
    orlando flawduh
    yeah it wont hurt to go look at it
    take a look at this thread if you havent already ----> How to Buy a Used WRX or STI
    desiree
    Too many miles is 1 mile past failure.
    The head gaskets are not expendable items. Since the car had them replaced, one or both had failed at one point.
    - Al Stewart
    Mar 2013
    First thing I looked at when signing up for this forum.
    Sidenote, I pretty sure this is one of the ONLY forums that has such detailed write ups about how to buy a used xxxxxx.
    Great stuff you guys got going on here.
    Mar 2013
    Great info.
    Thanks!
    Registered User mfigge2's Avatar
    Jun 2012
    IA, US
    Depends if you have another car and are handy with a wrench. If you have another way to get to work, then you can deal with a higher mileage issues. I have some buddies with 150k +miles on their wrx's and they have had some issues but they are lucky enough to have other ways to get to work. If you will be stranded if anything breaks, then go for a lower mileage car or buy something else while you save more. Just my thoughts...happy searching!
    '13 WRX Limited PBP hatch
    2012 Suzuki V-Strom 650 Adventure
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Head gasket failure is exceptionally uncommon on turbo Subarus. Leaves me wondering....
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Do you suspect a hard life and/or previous mods then? I suppose it's not unreasonable. It could just be luck of the draw though too. In any case one or both head gaskets failed at one point; no one in their right mind removes the front cover, cams, both heads, and then replaces everything, potentially with the motor still in the car, for no good reason.
    - Al Stewart
    zax
    zax is offline
    Nov 2008
    I'm sure a certified mechanic would be able to diagnose the car far better than an amateur like me could diagnose something over the internet... but certainly a "hard life" is never off the table!
    OP, at the very least, I'd have a certified mechanic perform a compression/leakdown test before considering the purchase!
    Facebook me here
    Registered User Kwrxp's Avatar
    Aug 2012
    Spring Grove, PA
    Seeing all of those new this and that has me thinking they fixed enough to sell.
    '11 WRX DGM
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    It's all a matter of "do you understand/have the ability to work on" what you're buying. I know many people with little to no mechanical aptitude or interest, and I wouldn't recommend them buying anything over 100K...unless it was possibly a well-maintained Civic/Camry, or other car that's not likely to have been pressed far beyond its engineered limits.
    I probably fall into a middle category...I've purchased an MR2T, WRX and other cars with mileage slightly below 100K, and have fixed the little things that came up.
    Then there's people like Trainrex, who have the knowledge and resources (and patience) to fix anything.
    You simply have to decide what you're comfortable with.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
