Results 1 to 15 of 25
This is a discussion on Possibly buying a bugeye within the Car Purchasing Forum forums, part of the ClubWRX.net Marketplace category; So I've been looking for a car the past month and I found a good looking bugeye with 75k. The ...
    Nov 2012
    So I've been looking for a car the past month and I found a good looking bugeye with 75k. The guy claims to have dyno sheets of the car pushing 290hp (stage 2) the only red flag I see with this car is the CEL codes.
    P0328- knock sensor
    P1090 tgv sensor
    P1091 tgv stuck open
    P1088 tgv stuck close
    What do you think?
    Nov 2012
    He claims that most if not all all from the BOV, which I plan on taking off.
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    Honestly I would stay away from anything with modifications.
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Nov 2012
    How about if I told you I can get it for $6500?
    Texas, United States
    I don't see what a BOV would have to do with any of those codes.. so right there he's lying to you. You might be able to buy it for $6500, but you're likely going to have to spend a lot more money (and time) getting it running reliably.
    Who did the tune? What do they have to say about the codes? What exactly has been done to the car (specifics)?
    Nov 2012
    This is the ad
    2002 Subaru WRX
    His explanation is "the sensors are because it has a BOV and the mass air flow sensor is expecting the bypass valve to be running while there's actually a BOV. So no air is cycling past the sensor causing a CEL"
    Any advice is appreciated. Im 19 and of course Im going to get gassed up when a car like this comes up in my price range. But I cant afford a lemon, at least in the next couple months. Thanks guys.
    Nov 2012
    I asked about the tune, and he has no clue, he bought it like that. The dyno makes me think it was done right.
    May 2007
    orlando flawduh
    after reading the FS ad, i stand by my original post even more.
    if you're young and cant afford a headache, you need to find a bone stock wrx with maintenance records.
    edit: also, the 295HP thing is a concern as well. most dyno graphs are in WHP. for a bugeye to get to 295WHP, it has to have an upgraded turbo. even if the car was dyno'd on a high reading dyno [dynojet], there has to be more than just an exhaust/FMIC/BOV.
    desiree
    06 impreza wrx tr
    facebook
    Sounds like a mess, and he's blatantly lying about the CEL. Personally, I would avoid that car unless you're looking for a project and have the money set aside to replace the engine when it needs it.
    Nov 2012
    You think I can find a reliable wrx below the $7500 range?
    May 2007
    orlando flawduh
    not completely impossible but you'll need patience and may need to travel a bit.
    most bugeyes with higher mileage are in that price range. the key is just finding one thats not molested
    desiree
    06 impreza wrx tr
    facebook
    Aug 2012
    to replace the tgv valve is pretty simple, there common for being stuck open or closed.
    Quote Originally Posted by Subaru1229 View Post
    My issue isn't with the TGV, it's the fact that the seller is lying about the car from the start. And if you still have the brackets of death on there then R&Ring the intake manifold isn't exactly a simple task.. not to mention the valve would be pretty hard to fix if it isn't there.
    Honestly, I would be more concerned about the knock sensor.
    Nov 2012
    yeah I read about the tgv deletes, what about the knock sensor.....would you trust this subie?
    Just to get an idea where I'm coming from.. I bought my second bugeye in 2008 for $11k. It was modded by the previous owner and ran great. 300awhp when I picked it up. It continued running good for ONE DAY after I bought it. I figured I would just fix it and have a good car. Now it's 2012, I've spent over $15,000 rebuilding the engine FOUR times and it has only been drivable for about six months out of the last three years. Not to mention two divorces in part due to the fact that I refuse to sell the car because I could never get back the money I have invested in it at this point.
    So it's your call. If you've got plenty of cash and another car to drive while this one gets fixed then I guess you don't have too much to worry about.
    And in case you're wondering, my car is still not running right and it's going in next month to have the engine rebuilt a fifth time.
