This is a discussion on My modifications within the Builds forums, part of the Tech & Modifying & General Repairs category; Option 1 or 4....
Option 1 or 4.
I almost always saw some caster cross, usually was in the .2-.3 range, I don't think a 1/2 degree is something I'd worry too much about
I am surprised you didn't see a little more than you did, could be the caster sweep they did wasn't perfect????
I'd say install the Com C's and see what you get.
I'd have to say I'm leaning that it wasn't accurate 100% but the only thing that sets me off a touch is that it felt a bit easier to pull the right arm down for the install and the bushing seemed to fight differently than the left when going on. I'm not clear on how they take the measurements and how much room for error there is, but I suppose if it is something that you can't adjust anyway I could see trying to make as quick work of it as possible as long as it looked in "spec" on the readout.
I'm glad both experts agree on option 4 though as that is keeping with the previous plan and I already have the Com C's on the pile. But yeah, I'm just a touch bummed it isn't higher on both sides.
Most people look like they have issues:
All Right. I'm putting these springs and inserts on today. Wish me luck!
Only thing is I wish I had put more consideration into the bump stops. Apparently the ones RCE provided are for STi only. So I've been reading and reading. Assuming I have the long (118mm) rear ones, I plan to cut off one nub on both front and rear. This is given a predicted 25/~22mm drop. Is that reasonable? Which end to cut (I think bottom if that is the harder part on a WRX)?
I'm interested to see what the actual drop will be as I haven't found any wagons on the regular guy springs. If it is 15mm/10mm F/R on an STi, plus ~10mm for WRX, plus a little more in the rear for wagons I'm guessing these drop nearly the same as the wagon version they discontinued. We shall see. I hope it is less.
Good luck. What's the install beer you've got? What's your celebratory cigar?Originally Posted by mycologist
Fronts are off and apart. Now for the drilling etc.. I think I would rather go to the dentist honestly so I am mustering some courage right now.
I have some "raging *****" belgian style pale ale (holding off on that for now). I hadn't thought of a cigar - that's a fine idea. I'll have to mull over what I want.
Why hold off? I've rarely had an install go smoothly, but at least if I'm ****faced, I laugh at all the complications I run across. Maybe that's why my short shifter and bushing install took me 5½ hours to do...Originally Posted by mycologist
Every part install starts with beers and ends with a cigar. I have never been able to decide on what cigar I want until the install is done, however.Originally Posted by mycologist
So far it is at 14.25" in the front compared to this morning it was at 15" -hard to measure that accurately though. It took a while to clean the bodies up to where I was satisfied but pretty leisurely all and all. I was going to go for a gratuitous pic but they look exactly like clean stockers except for the Com C on the top.
Rears will be tomorrow.
I tried this stuff "fluid film" I heard about from gun people. Amazing. It foams up on the rust somehow neutralizing it, leaves an awesome protective coating, darkens it up from the nasty orange, smells good, non-toxic, and makes your hands soft. IIRC it is lanolin based. I'm going to end up spraying everything under the car after seeing the results.
for bump stops- cut one "nub" from each- the small one, that should be just about right for that amount of lowering
once you ride on Koni's you'll thank yourself for a job well done![]()
Awe man...I'm so jealous right now. I wanna work on my carLooks like you're having a fun time and your car sounds amazing
Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
