2017 WRX Limited Build
Results 1 to 15 of 16
This is a discussion on 2017 WRX Limited Build within the Builds forums, part of the Tech & Modifying & General Repairs category; So I have decided that it would be appropriate to chronicle my experience with my 2017 WRX Limited including mods, ...
    Sep 2016
    So I have decided that it would be appropriate to chronicle my experience with my 2017 WRX Limited including mods, problems, thoughts, etc. So without further ado a short revuew after 7k miles.
    So 7k miles in and what do I think of the car? It's a fantastic car that's loads of fun, but not without its fair share of problems. I'll split this into Exterior, Interior, and Driving.
    Exterior:
    The exterior is in good condition and I haven't noticed any paint chips or scratches to speak of (besides a door ding ).
    Interior:
    I clean the interior every Sunday so I would be very upset if it had any issues. The interior is still in very good condition and the leather shows no signs of wear and tear. I'm glad to see that the interior seems to hold up well if taken care of. What I'm not happy with is that the dash collects dust very easily and the plastic in the back tends to rattle when the exhaust gets drony.
    Driving:
    7k miles in and it is still very fun to drive, but there are issues I need to fix that I'll start with. The biggest one is the non-linear throttle which makes it seem like 30% is more like 85% throttle. Then is how sloppy the shifter is in 1,2,5, and 6. Their is way too much movement in the shifter side to side in those gears. The exhaust is too quiet as well unless it's at ~1500rpm and it's very bassy. Finally, the boost drops down to about 10-11psi very shortly after reaching peak at 15.9psi before redline. Those are the cons. Besides that I love the suspension stiffness, the clutch, the throws, the steering, etc.
    Now that I have that out of the way I just got my first set of mods for my WRX. Now I just got a Boomba STS, Perrin Brass Bushing, and Perrin Shifter Stop. I said that I love the throws in it right now, but that doesn't mean I would like them shorter. I will update when I get it installed with ease of installation and thoughts of the products. If anyone has any suggestions before I install it that would help, it would be appreciated.
    Registered User 4EverMetal's Avatar
    Aug 2016
    Lost Wages, NV
    I have the same car with the Perrin shift stop and bushing along with their shift knob. Together they clean up and make shifting smooth and clean.
    2017 WRX Limited - Cobb Turbo back with MAP CAI and Tune
    2015 Yamaha FZ09
    Aug 2016
    Lost Wages, NV
    Also I recommend the Cobb Access port, their stage 1 map will smooth things out and get rid of the crappy throttle response.
    2015 Yamaha FZ09
    Registered User zimm17's Avatar
    Dec 2016
    Annandale, VA
    Yup, do the Cobb stage 1 map. The dealer loaded mine up with 300 miles on the ODO. Even though I'm staying under the 4000rpm limit (still breaking in) the throttle response is perfectly linear, and doesn't surge forward like you stomped the gas. From forum research, it looks like the OEM tune commands nearly 100% throttle with the pedal only 1/3 the way down.
    2017 WRX
    Mar 2016
    Does stage one add any noticeable power?
    Dec 2016
    Annandale, VA
    Quote Originally Posted by mjmwrx View Post
    I don't know yet, I haven't been past 4,000rpm as I'm still under break-in. Their map notes say how much power increase there is: COBB Tuning - Maps
    2017 WRX
    Aug 2016
    Lost Wages, NV
    2015 Yamaha FZ09
    Sep 2016
    March or February I will be getting the Cobb AP, Invidia N1 dual, Invidia Catless DP, MAP CAI, and MAP TMIC and CP. I've heard great things about the Cobb AP, but I would rather do the tune and everything else all at the same time. Just my thoughts on it. Also will be uploading a stock dyno graph from VD after this snow clears up.
    Jun 2015
    Just a bit of free chicken MAPerformance sells the COBB AP with a custom map they tuned their WRX to that is better than the COBB OTS maps. Also you get all the standard COBB maps...including the stage 1 you reference.
    Sep 2016
    That's actually the reason I am going to be buying the AP and other stuff from them. They have that free custom tune and they show actual data for all their mods.
    Aug 2016
    Lost Wages, NV
    Yes they do, it sucks you have to use their CAI for their map/tune.
    2015 Yamaha FZ09
    Mar 2016
    Quote Originally Posted by 4EverMetal View Post
    How bout the butt dyno?
    Aug 2016
    Lost Wages, NV
    ^^^ For sure there is a major difference.
    2015 Yamaha FZ09
    Sep 2016
    So what is everyone's thoughts on Virtual Dyno? Is it worth it and how bad are the results if you are not on a 100% flat road?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Cschubert117 View Post
    A dyno is only a relative tuning tool. The numbers themselves are meaningless. That applies to any form of dynamometer.
    Dyno FAQ
    Sent from my SHIELD Tablet K1 using Tapatalk
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
