My Engine Build Plan
Results 1 to 10 of 10
This is a discussion on My Engine Build Plan within the Builds forums, part of the Tech & Modifying & General Repairs category; Hey everyone, some of you might recall that recently my motor failed on me. 2010 STi SE with 24k miles. ...
    Oct 2013
    Warminster, PA
    Hey everyone, some of you might recall that recently my motor failed on me. 2010 STi SE with 24k miles. Here is the original thread. TL;DR - My ringlands failed. Bad. Cylinder #2's piston is missing the entire side of the ringland (top & bottom). They easily came off after I pulled them out of the motor. Luckily they didn't break apart while in the car. There really wasn't any metal in the oil pan or filter.
    Anyway, I've decided my build plan, builder, and tuner. I've been doing a lot of research to plan this out, and I think I have everything. If there's something not listed that I need or should add, please let me know. This is my first build so I may have missed something. I would like to try and keep this under $5k, but hey, you have to pay to play.
    I took a 2 1/2 hour drive and dropped my block, heads and crank off at IAG Performance in Maryland on Saturday. After doing a lot of research, they seem to be very reputable, have good turnaround time, and can meet all my needs and exceed them.
    My goal is a reliable, durable daily driver, but also makes good power. I'm not aiming to hit 400whp anytime soon, but I will eventually (I read the PSA and links). My car ran 330awhp on R/T Tuning's Mustang Dyno before, with intake, full catless turboback and Cobb Dynotune. I'm not really expecting this build to make over 350awhp, and that's fine...for now
    Moving along, here is my proposed build as of now. I plan on reusing my shortblock and crank, but we will know for sure after IAG diagnoses everything.
    • Manley Pistons (99.75mm)
    • Manley H-Beam Rods (might do TurboTuff instead)
    • ACL Rod & Main Bearings
    • ARP Head Studs
    • Perrin Air-Oil Separator
    • Air Pump Delete
    • Competition Stage 4 Six-Puck Clutch
    • Gates Timing Belt Kit & Water Pump
    • Oil Pump (What is recommended?)
    • OEM Gasket Set
    This comes out to a subtotal of around $3000 for the parts alone. Then there's also the other small miscallaneuos parts and fluids, which will probably add up to around $300-500. I expect labor to be aroud 15-20 hours (motor is already pulled and full disassembled), adding roughly $1500 in labor, making the grand total right around $5000. Then there is also about $500 to tune the car after it is done. So yeah, as you can see I'm already going over my budget. There's so many other little costs that I'm sure will add up as well, like towing the car to the shop.
    I really want to do cams while I have everything pulled, but it looks like it's going to be around another $1500 to do that, and I'm having trouble deciding if that's worth it right now, seeing as I'm not really looking for significant power gains at the moment, I just like the way lopey cams sound.
    Other possible mods I want to do in the future are:
    • Headers
    • UpPipe
    • External WasteGate
    • Walbro 255lph Fuel Pump
    • Injectors (probably 1000cc)
    • Boost Controller
    • Perrin Front Mount Intercooler
    • Radiator
    • Of course a bigger turbo at some point
    Some of those are pretty cheap and I might consider doing now, such as the boost controller. Since the boost controller and the fuel pump are pretty cheap, are they worth upgrading now for my setup, or can they wait? Since I'm not too knowledgable, I'm not sure if I should upragde my fueling system, or if stock will be fine for my build. I am also considering going Speed Density, but I might wait till I do the headers/UpPipe/EWG.
    I know this is a lot, but I have so much going on in my life right now and its difficult for me to spend hours and hours trying to find every answer. I just started 2 new jobs, trying to get my PA ACT 235 Cert, and just got engaged and a place with my Fiancee right after returning home from my deployment. Thank you all so much in advance. You guys are seriously a huge help.
    zax
    zax is offline
    Perverted Physicist zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Looks good.
    You can stick with the stock oil pump which should flow more than enough oil for the typical tolerances a builder works with.
    Zax's utterly unimaginably stock 2015 STi build thread
    Zax's Shaggin' Wagon Build Thread Now tuned for 99% pure Unicorn Jizz!
    Zach | Moderator | Builds, Electronics/Car Audio, Engine Modifications, Mid-Atlantic States, Suspension & Wheels, Tech & Modifying & General Repairs |
    Facebook me here
    Oct 2013
    Warminster, PA
    Looks good.
    Thanks. I was reading on NASIOC that it's good to replace the oil pump with a new one when doing a rebuild.
  5. #4
    Oct 2005
    Late Devonian
    Sounds nice - I'll be interested to hear how it turns out.
    He meant a new stock one.
  6. #5
    The Guy On The Couch TownLine500's Avatar
    Oct 2013
    Boston
    It's going to be nice when finished!
    Keep us updated on your progress.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
  7. #6
    Oct 2013
    Warminster, PA
    Oh okay, I read it as keep the one I have, not replace with a new stock one.
    Quote Originally Posted by TownLine500 View Post
    Thanks! I definitely will. I'm really excited for this. There's so much I want to do since everything is out but I just can't drop that much money at once. Why didn't I stay single?
  8. #7
    Oct 2013
    Warminster, PA
    Adding more to my build
    Well, one of my friends is parting out his car, and it's too much a of a good deal to pass up, so I'm going to be snagging some parts. I will be getting:
    • Blouch Dominator 1.5XTR 10^2cm Hotside Turbo (will be mounted stock location)
    • Turbo XS Front Mount Intercooler
    • Agency Power UEL Headers (Once cracked, but reinforced and rewelded) - Good or bad idea on these?
    • Injector Dynamics 1000cc Top Feed Injectors
    I was wondering what else I need in correlation with the turbo. I'm already over my budget, so I'm trying to do just what I need. I can afford more, just trying to spend less. I'm thinking about doing:
    • Fuel Rails
    • Walboro 255 Fuel Pump or DW 65C Fuel Pump
    • Boost Controller (Grimspeed?)
    • 2.4" Turbo Inlet
    • Ceramic Coated 38mm External Gate Up-Pipe (Grimspeed?)
    Anything else I need to run this turbo? I'm not trying to cut corners, just only want to get what I need. I know its ironic as I post about upgrading a turbo, as I don't need it, but yeah. Thanks in advance.
  9. #8
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by AnthonyP View Post
    Ooph, yeah I meant stick with the OEM pump. Sorry for the confusion.
    Facebook me here
  10. #9
    zax
    zax is offline
    Nov 2008
    *]Agency Power UEL Headers (Once cracked, but reinforced and rewelded) - Good or bad idea on these?
    Bad idea. Don't waste your time with UEL headers nor the Agency Power brand.
    Facebook me here
  11. #10
    OMG WTF MainFrame's Avatar
    Texas, United States
    I just briefly skimmed through this.. but you're going to want to stick with the h-beam rods unless you plan on pushing it past ~450-475wtq. The Manley h-beams are MUCH lighter than their turbo tuff rods, and the more weight you can save in that area the better.
