Building a short block; 2010 STi
Results 1 to 5 of 5
This is a discussion on Building a short block; 2010 STi within the Builds forums, part of the Tech & Modifying & General Repairs category; Hey everyone, recently my 2010 STi took a poop on me. Had some misfiring, put in new spark plugs, continued ...
    Oct 2013
    Warminster, PA
    Hey everyone, recently my 2010 STi took a poop on me. Had some misfiring, put in new spark plugs, continued misfiring. Did a leakdown test and got 80% leak on cyl. 2 and 40$ on cyl. 1. I was convinced it was ringlands, so I pulled out the engine in my driveway and brought it over to my friend's shop. We fully disassembled the engine, and behold, piston #2.
    Piston #1 had one chunk of ringland easily come out as well, and #3 had a few hairline cracks and a chunk missing, and #4 had just a small piece broken.
    I am now on the quest to rebuild the shortblock. I'm aiming for durability. I know everything will break at some point, especially with modified engines, but at this point I'd rather have more durability than power. I only had an intake, downpipe and exhaust and a dyno tune, with 330whp on the shop's Mustang dyno. I don't plan on making over 400whp anytime soon, but will eventually. I want my block to be as reliable as possible, while still making decent power.
    I've done a lot of research, and it seems rather expensive to buy a Cosworth short block, which was what I was considering. Does anyone know if you can send them your shortblock to avoid a core charge? My block is still in great shape (only 24k miles) and I don't need a brand new one. I've also read that it would seem to behoove me to have my block built by the same person that will be tuning it, that also provides a warranty, so their won't be any blame being passed around if and when it does break. So that brings me to another question, are there any reputable tuners/engine builders near the Philadelphia/Tri-State area? I'd rather not have my car need to go 5+ hours away to be tuned, unless this tuner/engine builder is godlike with Subaru motors.
    If I supply the parts and have someone build it or doing myself, I was thinking Cosworth pistons, and definitely Manley Turbotuff Rods. Probably Manley bearings as well. That's what I'm doing at the minimum, unless there are some other parts I can swap into the shortblock to increase durability. Also keep in mind this will be my dailydriver, however I don't mind if it's "not comfortable to DD" (I'm most likely doing a stage 4 six puck clutch).
    I'm not really looking for a specific power number; I was comfortable with the power it was making when it broke. I just want it to be more durable, and be able to handle the power when I do some more things to it down the road. Thoughts?
    zax
    zax is offline
    \_(ツ)_/ zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Cosworth certainly produces quality product, but I'm not sure it's worth the price point. I'd suggest finding a reputable local builder to build your current block. For durability, use a 4032 alloy and not a 2618 which will make ends meat out of cylinder liners in about 50k miles. If there's nothing wrong with your bearings, this could be as easy as dropping in a set of 4032 pistons and calling it a day.
    Zax's utterly unimaginably stock 2015 STi build thread
    Zax's Shaggin' Wagon Build Thread Now tuned for 99% pure Unicorn Jizz!
    Rollin' with the Bugeye Mafia #302 | N.E.R.D. Subject Zero
    Facebook me here
    Oct 2013
    Warminster, PA
    The rod bearings have some scoring so I'm going to replace those as well.
  5. #4
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by AnthonyP View Post
    Good idea... Subaru isn't known for choosing the best bearing materials.
    Facebook me here
  6. #5
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Since the engine is out, I'd recommend installing a KillerB oil pickup and windage tray as extra precaution. Wouldn't want to spend all that money and time to have a oiling problem cause more damage.
