Trancehead's build/mod thread - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 63
This is a discussion on Trancehead's build/mod thread within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by vweater1369 So kind of a silly question here as I've never really worked on a New (or ...
  1. #46
    Registered User trancehead's Avatar
    Jan 2014
    Montgomery Village, MD
    Quote Originally Posted by vweater1369 View Post
    So kind of a silly question here as I've never really worked on a New (or new-ish) car, just my old DSM. How long did it take you to swap all the bushings? I know the car being newer makes a world of difference for these jobs.
    Honestly that's kind of a hard question to answer since I was doing a lot of other things all at once. But if you know what you're doing I'd say a couple hours max.
    2014 SWP WRX Hatch
    Build Thread
  3. #47
    Feb 2014
    Does the stereo sound better with the new head unit?
  4. #48
    Jan 2014
    Quote Originally Posted by paxtu22 View Post
    Actually, it pumps up the RMS to 14 watts from stock, I would say it is MUCH better. I'm an audiophile by nature so it's really not up to par for me, but yes, it is much better than stock
    2014 SWP WRX Hatch
    Build Thread
  6. #49
    Jan 2014
    02/23/2014 Perrin Engine Mounts have been installed. These things are solid. No movement whatsoever. In terms of NVH, I don't so much notice vibes as I do sound, which I don't mind because it just sounds so drop dead sexy :P. It is very different from my Mazda in the fact that when I fully mounted that car the vibes were more pronounced than sound (as in I couldn't tell the difference between a cop and a roof rack lol). In terms of this install, yes it is a bit of a pain, but if you look at the instructions compared to where everything is bolted up in the car I'd say it would take two hours max from popping the hood to all buttoned back up.
    As usual with my installs, they experience SOME kind of fail.....well as I was completing my MWR training so I can use the Automotive Skills Shop on any base I entrusted the install to a friend of mine. Welp, the Perrin instructions say that if the supplied bolt does fit through the frame, to cut out a small portion. The following picture is what he thought that meant.....words can't express how mad I was. The supplied washer did not fit any more so we had to take his speed6 out to Ace to pick up some bigger washers. It turned a simple two hour job into a 6 hour job :|
    2014 SWP WRX Hatch
    Build Thread
  7. #50
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Coming along nicely.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  8. #51
    Jan 2014
    Thank you sir! I believe I saw you a few days back at the intersection of 355 and Montgomery Village. Black wagon correct?
    2014 SWP WRX Hatch
    Build Thread
  9. #52
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by trancehead View Post
    Yep!
    Facebook me here
  10. #53
    Jan 2014
    Good lookin' ride you got there man
    2014 SWP WRX Hatch
    Build Thread
  11. #54
    Jan 2014
    So, I just got my new lightweight crank pulley in the mail yesterdya and am planning my install for tomorrow. I'm asking all y'alls professional opinions because I've seen both. My vendor (edgeautosport) and several how-to's have stated that the belts do not need to be replaced. However, Perrin, and several other how-to's state that the belts should be replaced.
    The belts have 1200 miles on them brand new.....thoughts?
    2014 SWP WRX Hatch
    Build Thread
  12. #55
    Palmyra, NJ
    Honestly I wouldn't replace the belts...I'm sure they are fine. But I also wouldn't add a lightweight crank pulley either.
  13. #56
    Jan 2014
    Any particular reason?
    2014 SWP WRX Hatch
    Build Thread
  14. #57
    Palmyra, NJ
    There seem to be two trains of thought...those that dislike them and think they are pointless...and those that think they are beneficial and actually do help improve throttle response and rev quickness. I'm of the first train of thought because I've read many threads where people didn't see any improvement and thought it was a waste of time and money to install on up to threads where the lightweight pulley actually caused misfires as the crank wasn't as balanced. How true that proves though is beyond my scope since I just don't care to spend the money on it to find out first hand.
    You on the other hand...if you already have it, go for it! I'd like to see a review when you're done. Maybe you can dispel some of the "pointless" myth.
  15. #58
    Jan 2014
    Ah, yeah, that argument. I helped a buddy install one in his BRZ and after driving it around the AutoX course before and after I could definitely tell a difference. Now the question will be, do I notice the same thing with the WRX.
    2014 SWP WRX Hatch
    Build Thread
  16. #59
    Palmyra, NJ
    That's a good question...but they are also very different engines
  17. #60
    Sep 2013
    Elk Grove, CA
    Nice Rex! Going for the same look as you. subb'd
