Billy's 2011 WRX Build Thread (Optimus) - Page 5
Page 5 of 14 FirstFirst 1234567891011121314 LastLast
Results 61 to 75 of 206
This is a discussion on Billy's 2011 WRX Build Thread (Optimus) within the Builds forums, part of the Tech & Modifying & General Repairs category; Looks Awesome! They blend in perfect with dash. I got to get gauges and stop using AP. I really like ...
  1. #61
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    Looks Awesome!
    I really like the wideband 02 gauge.
    Good work.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
  3. #62
    Great write-up, Billy
    Resident Tuner @ WTF Tuning
  4. #63
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Well, I pulled the trigger on a new Head Unit. It's a Pioneer AVH-X5600BHS, here is a link to a site that has some specs on it AVH-X5600BHS. This bad boy should do all I need and will help with the poor FM quality and the terrible Bluetooth connectivity issues I've been having as of late. I'm excited, should be here by next week.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
  6. #64
    Sep 2013
    Buckeye State
    Package came in the mail for me today. Install will be on Sunday afternoon. I'll post pictures and a review about the install on Monday or Tuesday! I'm excited to get rid of that Bluetooth connectivity issue.
    Billy
    Stink-Eye Mob #696
    Facebook
  7. #65
    Oct 2013
    Boston
    Sweet!
    Can't wait to see the write up and end results.
    Now your making me want one!
    Great choice.
    STINK EYE MOB #500
    1996 Honda Civic Lx
  8. #66
    Sep 2013
    Buckeye State
    Update: 9/14/2014
    So this one will be short and sweet but with lots of pictures. Install was very straight forward. put together the harness bridge that links the stock harness to the aftermarket plug. Then I wired in the DVD bypass into the correct wires (there is only three), wired up the steering wheel control module (which was also laid out and easy), and hooked up the USB port adapter.
    The hardest part was hooking up the backup camera. This requires a power wire that runs to the head unit being attached to the hot wire of the reverse lights, and a video cable running from the camera in the rear all the way to the front. The camera itself also requires a constant power wire and a ground which was easy to find. Now the reason the head unit needs the reverse lights hot wire is pretty straight forward. This allows the camera to only turn on and take over the full display when you are in reverse. Now, typically you would wire the camera to the same source as the head unit (reverse lights). My reasoning for wiring it to a constant power source is that doing it this way allows me to use the camera whenever I please by very easily changing the setting on the head unit to take the power from the video line instead of the power source the head unit is wired to (reverse lights). After I wired everything up to make sure it works, I ran all the wiring down the passenger side kick panels, under the back seat, and into the trunk paneling following the light harness from there to the trunk trim above the license plate. I then had to remove the trunk paneling to wire the rest of the way and to remove the trunk trim. The trunk trim is held on by two small nuts and two more clips. Very easy to remove. Once I removed it and disconnected the stock wire harness, I drilled a hole dead center bid enough to fit the bolt on my camera. This hole is on the bottom of the trim right above the license plate. Once that was done I sealed the hole with the 3m tape provided, bolted the camera in place, wired everything back up, and put the trunk back together.
    Now that I'm done with that, it's picture time kids!!!!!
    Here are a couple of the camera mounted up to the trunk trim.
    Finally, here is a picture of the backup camera in action.
    Welp, there you have it. Thanks again for following along... Until next time
    Billy
    Stink-Eye Mob #696
    Facebook
  9. #67
    Oct 2013
    Boston
    Nice write up Billy!
    I have not yet seen the stock deck removed. How hard was it to remove?
    STINK EYE MOB #500
    1996 Honda Civic Lx
  10. #68
    Sep 2013
    Buckeye State
    Quote Originally Posted by TownLine500 View Post
    It's quite easy. You remove the radio and air duct bezel by prying it off with your fingernails, it comes right off. Then from there it's 4 phillips head screw drivers and pulling out the stock head unit harness. It takes less than 10 minutes.
    Billy
    Stink-Eye Mob #696
    Facebook
  11. #69
    Sep 2013
    Buckeye State
    Took it off the Dealership's routine doctors visits this weekend. Did an oil change myself now that I cancelled my extended warranty. 5 quarts of Redline 0w30 went in and a Purolator PureOne oil filter (PL14460). ODO is roughly 53,000 Miles.
    Unfortunately I have no mod updates as of now . Everything has been put on hold until at least after the holidays, possibly longer. However, I have VERY big plans for this spring. So don't wander too far!
    Billy
    Stink-Eye Mob #696
    Facebook
  12. #70
    Registered User Goose42's Avatar
    Jun 2014
    PNW
    What is under the car cover in post 66???
    Or he is rolling down the street in his new slammed ride vaping out the window, enjoying the tow truck ride. - XJman
    2017 ISM Impreza 5MT Hatchback Sport
    2015 WRX COBB Surgeline Stage 2 Pro Tune (Sold)
    Journal-
    http://www.clubwrx.net/forums/builds...ml#post3579257
  13. #71
    Sep 2013
    Buckeye State
    Quote Originally Posted by Goose42 View Post
    That would be a 1971 Oldsmobile Delta 88 Royal in a spectacular maroon color with an all original 5.7L under the hood. It has an air ride system, so that beast rides like a boat. Unfortunately, this beauty is not mine. It would be my Fathers as this is our family business' warehouse. However, I do get to drive her quite frequently and I love it. I'll try to find a picture somewhere.
    Billy
    Stink-Eye Mob #696
    Facebook
  14. #72
    Jun 2014
    PNW
    Would love to see it, thank you sir!
    Journal-
  15. #73
    Sep 2013
    Buckeye State
    Well I hate to break it to you, but I can't find a picture...
    Billy
    Stink-Eye Mob #696
    Facebook
  16. #74
    Jun 2014
    PNW
    Quote Originally Posted by McBill View Post
    Psssst., take one! JK, thanks for looking.
    Journal-
  17. #75
    Sep 2013
    Buckeye State
    When we whip it out for the spring I'll try to remember to take one.
    Billy
    Stink-Eye Mob #696
    Facebook
