EugeneUtopia's 2010 FXT Project - Page 4
Page 4 of 10 FirstFirst 12345678910 LastLast
Results 46 to 60 of 145
This is a discussion on EugeneUtopia's 2010 FXT Project within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Derelique Super sick car man! Found this thread the other day and had to find it again ...
  1. #46
    Registered User EugeneUtopia's Avatar
    Sep 2012
    West Seattle
    Quote Originally Posted by Derelique View Post
    Super sick car man! Found this thread the other day and had to find it again to post how epic it is. Lol, well done.
    Thanks! I appreciate it!
  3. #47
    Sep 2012
    West Seattle
    Went to Drift Office to see what a different tune would look/feel like. I do still have a few quirks in the 92 octane pump gas tune and a LOT of quirks on the E85 tune.
    On the pump gas tune, I experience occasional stalling when the car is first started (cold or not) and I rev it 3K+ and let it drop down on it's own. It usually goes away quickly, and I really don't care about it.
    The thing that gets me is that frequently when I in the 2K - 3K range and under load (like going uphill) it will pulse (each pulse lasts about a second), as if it is starved for, or being given too much, fuel. This doesn't always happen though. There isn't any correlation that I've noticed. It just does it sometimes. It is VASTLY more pronounced on the E85 tune, which leads me to think that maybe I need a fuel pressure regulator. I certainly been a 3.5 bar map sensor.
    Another one displays very similarly, but happens when i corner hard. Well, to me it's hard cornering. Just cuts out.
    I am getting a retune at PIA the 2nd week of May, and Steve has told me that he is going to try and have a peer tuner onsite at the time, since there are little E85 quirks here and there that would benefit from a different informed perspective.
    Anywho.. back to the Drift Office tune. I have been told from a couple of sources that I trust that the crew at Drift Office is pretty awesome; Bill especially. So I brought it by to see how it may differ from the other current-mod based tunes i have.
    Here is the one I am coming off of. It's from PIA, and pretty stout. Keep in mind that at the time of this tune I had a slipping clutch. (The 451whp post is the tuner's estimate w/o the slipping clutch).
    Here is the Drift Office tune. Not as much HP, but who knows, that might be partly due to different dynos. My understanding is that the PIA dyno reads very conservatively and the Maxwell PowerSports dyno reads equally optimistic. This I can personally verify based on identical baseline runs between the two. Yes, yes, they were on different days, different times of the day, different elevations (I assume) and different atmospheric conditions. I don't claim to be the authority on the comparison. I can say that the mods were the same, the outside temp was within 5 degrees and overall the days were VERY similar. One read 345whp and the other read 309. I don't have any experience/information with the Drift Office dyno.
    Net result is, according to my butt dyno, if that the PIA feels faster, and probably is. I'll be able to tell soon, and run comparison runs between the two different pump gas tunes.
    The Drift office tune is easier and smoother on the street. The surging happens less, but it's still there, and still just as random.
    Next: Once I get the E85 tune, and it's 100%, I'll be a very happy boy. Based one previous gains on E85. Last numbers before the FMIC were 360whp on pump and 419 on E85. Most recent numbers after the FMIC were 387whp on pump and 427 on E85 BUT I had a slipping clutch and couldn't go past 4300rpm. That's (initial numbers) ~ 15% increase which would put me at 448, at a minimum. Then factor in the improved tune, map sensor, working clutch and fuel pressure regulator and think conservatively I'll be around 460-480whp. Well above my initial goal of ~350.
  4. #48
    Sep 2012
    West Seattle
    Updated the Simplified Mod list SHOWN HERE
  6. #49
    Sep 2012
    West Seattle
  7. #50
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    Love this build Fozzy ftw!
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
  8. #51
    Sep 2012
    West Seattle
    Well, I'm sitting in a restaurant, waiting for some people to arrive, which is the most time I've had to myself in a while. Time to update the build!
    South Bend clutch... where to start? I did a SUPER long break in on it... 1500 + miles long. 750 miles on < 9 psi of boost... usually much less. 500ish miles of 19 psi of boost, but no launching. Another 200 miles of full boost, still no launching. Tried 4 drag launches in 45 minutes. The clutch material melted and shed off the plate. Transmission shop tells me it was riveted on ONLY, no bonding agent at all.
    Went to Drift Office and had an Exedy twin clutch put in. Sooo much better. I've put in 500 miles of break in. We'll see how it launches very soon.
    Also had my 3.5 bar AEM map sensor. COBB map sensor adapter, Grimspeed master brake cylinder brace and COBB fuel pressure regulator installed. Add re-tune
    The E85 tune is MUCH smoother if not a bit too peaky. Car is now pushing 390 who on the 92 octane tune @ 23 psi, and the E85 tune is 472 whp at 26 psi. The Fozzy is STUPID FAST.
    Brake upgrades are now complete (sans caliprs) and it stops wonderfully. Could be better, but for the amount spent, I'm very happy.
  9. #52
    Sep 2012
    West Seattle
    I did a 1/4 drag launch (level ground, from a stand still) tonight. My launch 100% sucks, but the numbers are good, poor launch considered. If I could get a good launch, I'd be where I want to be.
    Per Access Port:
    60' = 2.819 sec
    330' = 5.787 sec
    0-60 = 4.610 sec
    1/8th mile = 8.194 sec @ 95.361mph
    1000' = 10.521 sec
    1/4 mile = 12.525 @ 113.005 mph
  10. #53
    Sep 2012
    West Seattle
    Things.... I'll clean this up a little later... after I look for a job :censored:
    GrimmSpeed Master Cylinder Brace:
    Cobb Fuel Pressure Regulator:
    (Bad photo... connection only... I'll get a better picture later)
    Cobb Map Sensor adapter and AEM 3.5 bar map sensor
  11. #54
    Sep 2012
    West Seattle
    I've neglected to update the mod list....
    Up to date, simplified mod list HERE...
  12. #55
    Sep 2012
    West Seattle
    Power-coated the TMIC (visible) tubing and strut brace. Also ceramic-coated the heat shield and down-pipe
    Before
    After
  13. #56
    Sep 2012
    West Seattle
    Did a quick dyno run today, now that the air leak between the MAF and turbo inlet has been fixed.
    The tune(s) need to be adjusted for the newfound oxygen. Until it is, I won't be able to hit 26-27psi again.
    Once it is adjusted, 500 whp should be attainable.
  14. #57
    Registered User XTi24's Avatar
    Oct 2012
    St. Louis
    Someday when you want to sell those headlights, let me know. Sick car.
    Sent from my Batphone using Tapatalk
    2015 STi Launch Edition - IAG Stg3 Block/catless/EWG/ELH/TMIC/FP Green
    2013 DCP FXT - TP Stage 2 - Cobb dp - Meagan Racing catback - 2011 WRX wheels/suspension
  15. #58
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    that sure is a nice Fozzy you built up. Good power and it looks nice, while still having room for stuff in the back.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
  16. #59
    Sep 2012
    West Seattle
    Thank you sir!
  17. #60
    Sep 2012
    West Seattle
    The place where I got them is no longer showing the blacked out option as available, but they still do have the chrome version... 09-11 Subaru Forester CCFL Halo Headlights- 02-AZ-SF09-PCC-RF-A
    Alternately, CarID still has both versions, but they are more expensive. Shouldn't be, since they are exactly the same thing from the same manufacturer... CG® 02-AZ-SF09-PBC-RF-A - Subaru Forester 2009-2011 Black CCFL Halo Projector Headlights with LEDs and Amber Reflector
    I won't be selling anytime soon because......... ↓↓↓
