It's been a while... - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on It's been a while... within the Builds forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Heide264 Maybe you should look into the reasons behind why your motor crapped out... before you replace ...
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    Maybe you should look into the reasons behind why your motor crapped out... before you replace it again. There is no reason to be replacing another motor without fixing the root cause.
    EDIT: in all seriousness, unless you are planning on running e85 or meth... I'd reconsider RAISING the compression ratio... especially if you already blew two blocks. A bit of reading on the subject would go a long ways.
    Plan to run an E85 tune, and down the road do meth (when money is available)
    Palmyra, NJ
    If you want something quick for a DD, then a fully built motor might not be the best thing for you. These kinds of things aren't usually reliable for many miles like a stock motor would be. And especially given you don't know the root cause of blowing up two motors, spending a ton of money on a build could just be a waste in the long run.
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    Quote Originally Posted by Mike193 View Post
    Quoted for local police.
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  6. #19
    May 2007
    orlando flawduh
    oh lawdddddddd. i cant.
    i love you guys.
    desiree
  7. #20
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    But there are only two E85 stations in jersey!! lets do meth together
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
  8. #21
    May 2010
    Pittsburgh, PA
    Still curious about your first two blocks. Replacing a part that failed before its lifespan is rarely the correct cure.
    You generally do E85 or meth... not both.
    Do you have a fuel system to support e85 from the getgo? I would keep in mind that it takes about 30% more fuel... and I doubt your e85 is 30% cheaper than premium - definitely a consideration for a DD.
    I'd really put my foot down pretty strongly that you shouldn't be raising the compression of these motors without either e85 or meth. They knock and explode as is (cough, first two blocks, cough).
    2011 STi Build Log
  9. #22
    Nov 2010
    Voorhees, NJ
    Quote Originally Posted by wrxtreme06 View Post
    i love you guys.
    We love you too Dez.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  10. #23
    Contributes Nothing ShiftingLanes's Avatar
    May 2013
    Riverdale, NJ
    This thread has beeeeeeen, so far awayyyyyyy
    And I bump it for another dayyyyyyy
    http://shiftinglanes.com
    '14 DGM WRX Limited Hatch
    I'm a build thread?
    Stink-eye Mob #49
