Brandon's 2012 ISM STI Build GR Sedan - Page 10
Page 10 of 24 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 136 to 150 of 358
This is a discussion on Brandon's 2012 ISM STI Build GR Sedan within the Builds forums, part of the Tech & Modifying & General Repairs category; Took the tranny out and replaced the clutch with a stage 2 Competition Clutch. Transmission Jack Tires off for better ...
  1. #136
    Registered User evans609's Avatar
    Oct 2013
    Newfoundland
    Transmission Jack
    Tires off for better access. 4 very sturdy jack stands underneath and ready to drop the transmission
    Transmission dropped
    The stock clutch on the left and the new Stage 2 clutch on the right
    And the new clutch installed in its new home.
    2012 ISM WRX STI
    321WHP 340WTQ
    http://www.clubwrx.net/forums/builds...-gr-sedan.html
    2010 OB Ralliart
  3. #137
    Oct 2013
    Newfoundland
    Some engine bay shots and pic of the meth lines. Engine bay is a bit dirty.
    One of the meth lines going to the back of the intercooler
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  4. #138
    Oct 2013
    Newfoundland
    Got a quick crappy pic of the meth gauge
    The plastic on the centre console is scratched up :\
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  5. #139
    Oct 2013
    Newfoundland
    Installing the new headunit. Taking the radio out was easy. Most wires where to easy to deal with. I soldered the wires together and used heat shrink on them. Couldnt get my steering controls to work so im going to take another look at that another time.
    Here the dash trim off
    Stereo out and just vents there along with the wiring.
    Getting the wires straightened out.
    Soldered them together and heat shrink.
    Putting the new stereo in
    New stereo in and dash trim on
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  6. #140
    Oct 2013
    Newfoundland
    Got new rubber coming in for the subie and the ralliart. Got the BF Goodwrich Sport Comp-2 in 245/40/18 for the subie and General Tire G-Max in 235/45/18 for the ralliart. Hoping to get the new rubber on the subie tomorrow and the rubber for the ralliart saturday.
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  7. #141
    Oct 2013
    Newfoundland
    Just ordered my Prosport Evo gauges. I ordered the EGT, Boost and Oil Pressure. All red illumination and all 52mm gauges. Also ordered a JCS Pods 3 gauge A-Pillar. And im hoping to get the ebcs, fuel pump, intercooler piping and plugs in this weekend or the next and also hoping to get the new inner fender well, front splash guard and the coilovers on next weekend. Also going to see what numbers im making when I get the few performance parts on.
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  8. #142
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by evans609 View Post
    I really like this photo.
  9. #143
    Oct 2013
    Newfoundland
    Really? lol Well thanks bud
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  10. #144
    Registered User Initial D's Avatar
    Apr 2014
    Wow have updated this in a while. Raymond, I didnt really notice any difference with the Strut tower bar. Maybe if pushed really hard you might notice a difference. And InitialD lol I loves my tea and coffee while working on a car haha
    nice build and love all these part pictures! I should follow in your footstep and get me one of those tea and coffee container hahaha
  11. #145
    Oct 2013
    Newfoundland
    Thanks bud lol im telling ya those tea and coffee containers make the difference hahaha
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  12. #146
    Oct 2013
    Newfoundland
    Update: My JCS a pillar cluster gauge is on its way here. Waiting to here back and see if my gauges have arrived in yet. Hoping to get my plugs, intercooler piping, AOS, fuel pump, ebcs, driver front fender well, front underside splash guard and coilovers on this weekend.
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  13. #147
    Apr 2014
  14. #148
    Oct 2013
    Newfoundland
    First thing I did was replace the inner fender well. First thing I did was put it up on a buddys lift and took the tire off.
    First pic is the damaged part of the inner well. This all happened when I was backing out of a friends yard and my front lip hooked into the ground and hauled the driver side of the bumper off breaking the clip joining the fender to the front bumper and numerous clips in the fender well and underneath the front bumper.
    So I removed the rest of the clips inside the inner fender well and seen in the pics.. (The pics are bright so I apologize.)
    and there are these 3 little clips that can be removed with a Phillips screw driver and also a flat top. In order to remove these you would have to take out 2 clips under the side skirt (be careful these clips are easy to break) and also haul out on the piece that contains the sti emblem (which is in between the side skirt and fender)
    After that I washed her up and and took a pic of the new fender well.
    What I use to wash my car
    And the inner fender well
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  15. #149
    Oct 2013
    Newfoundland
    Next I installed the DW65c fuel pump, Grimmspeed air oil separator and Electronic Boost Control Solenoid.
    Pics of the Fuel pump install are below.
    First thing you want to do is drive around or take the gas out of the tank. You want to be on gas light or the notch above where the gas light would come on. Then let it sit for a couple hours so the pressure inside the tank dies off.
    Then you take the back seat out by undoing the 2 pull clips under the seat towards the middle of the driver and passenger back seats. (be careful with these for they are easy to buckle.) Once the seat is off this is what youll see.
    You'll have 4 screws on what looks like a speaker was my first thought hah. Undo those screws and remove the cover and seal. Like below.
    Once that's done you'll have to undo 3 clips and a sensor. (its best to use shop towels or cloths to put around the plugs when undoing them for they will still leak gas)
    Undo a few screws and haul the assembly out.
    Next undo more screws, clips and a sensor on the pump housing. Empty the gas and wipe the housing out with a cloth.
    and this is the stock fuel pump.
    once thats all done install the new pump and basically do everything I just did but in reverse.
    The new pump
    The new pump installed.
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
  16. #150
    Oct 2013
    Newfoundland
    and back into the new housing.
    Installing back into the tank.
    and done!
    2012 ISM WRX STI
    321WHP 340WTQ
    2010 OB Ralliart
